Author Topic: Scart to VGA SyncBlaster Cable  (Read 3636 times)
Mr-Megalo
  • Last login:July 13, 2006, 08:36:28 am
  • Piano fingered Capcom Addict
« on: January 21, 2004, 09:41:12 am »
Hiya all,
I was browsing Maplin.co.uk and came across a Scart to VGA SyncBlaster Cable , order number A38BF, can anybodytell me if this can be used in anyway with arcade monitors or arcade projector screens ? it sounds like an interesting little cable but im still a bit confused to its use besides use with plasma tv. cheers
« Last Edit: April 12, 2005, 04:22:14 am by EvilAngelous »
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
Re:Scart to VGA SyncBlaster Cable
« Reply #1 on: January 21, 2004, 02:39:00 pm »
It's a cable with a sync seperator in it. This basically means it takes the composite video from the SCART plug and gets the H- and V-sync from it. The seperate H- and V-sync are then sent to the VGA compatible monitor along with the RGB signals.
It is not limited to projectors only. A multisync arcade monitor like the Hantarex Polostar can use this device directly. Most PC monitors cannot though.
The cable is very expensive though. You can easily make one yourself using this circuit: http://www.national.com/ds/LM/LM1881.pdf
