Author Topic: Attempting to create some 3d Printable star wars yoke handles  (Read 4562 times)
menace
« on: October 15, 2016, 07:25:46 am »
Edit:
I have two yoke handle grips that I would like to replicate so that I can get them 3d printed.  One for spy hunter and one for road blasters/star wars etc.
I tried my hand tracing the spy hunter one into sketchup and although it was coming along--I am a gross newbie (downloaded the program wednesday lol).
To be continued...
« Last Edit: October 21, 2016, 09:59:27 am by menace »
05SRT4
  • Check out my Pow Pow
Re: Sketchup pro wanted to recreate some yoke handles
« Reply #1 on: October 15, 2016, 04:26:16 pm »
why not upload the photos and measurements so everyone can have a hack at it?
JDFan
« Reply #2 on: October 15, 2016, 05:00:40 pm »
^This --- You never know when someone might be a bit bored and decide to give it a try and if the files are available they can do so without committing to anything beforehand - rather than having to contact you and arrange to get the files which might not be received until the free time has past.
menace
« Reply #3 on: October 16, 2016, 08:34:06 am »
Fair enough--Here's the grip from a roadblaster/star wars type yoke:
And one for inspiration :)
menace
« Reply #4 on: October 16, 2016, 08:37:21 am »
As an aside--Maybe scale them a bit bigger--they are a shade less than 5" tall and it seems like a slightly larger handle would fit our adult hands more comfortably--just a thought...
Buick455
  • Last login:August 19, 2026, 07:34:24 am
  • I MUSTA WRECKED IT!
« Reply #5 on: October 16, 2016, 02:46:50 pm »
idk how well it will work as I have never used it but since you have the grips on hand maybe try 123D Catch to create your models..
 http://www.123dapp.com/catch
menace
« Reply #6 on: October 17, 2016, 08:17:09 am »
Trying it now!--thanks for the link!
EvilNuff
« Reply #7 on: October 18, 2016, 11:36:15 am »
I have long wondered why there aren't good 3d print models of star wars yoke parts.  I will watch with avid interest your progress so please post any results. :)
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #8 on: October 20, 2016, 01:00:27 pm »
I made a quick exterior model of my SW yoke for my SWYM project:
http://forum.arcadecontrols.com/index.php/topic,138836.msg1434581.html#msg1434581
The renderings attached to that post show the level of detail that I generated. Enough to make my mount, but not enough to reproduce handles.
If this makes for a good starting point for somebody to make detailed models, here are my old SolidWorks files. I no longer have access to SolidWorks, so I can't verify the parts. Let me know if something's missing. Unzip both files into the same folder. Yoke.SLDASM is the top assembly.
Good luck.
-Jason
« Last Edit: October 20, 2016, 07:12:24 pm by jasonbar »
menace
« Reply #9 on: October 21, 2016, 07:28:00 am »
Thanks Jason!  I've sent them along to my brother who crafted up this--great starting point!  The plan will to make two halves of the yoke so switches can be mounted.  I plan on using regular easy to find cherry switches.  The shaft diameter will be 5/8" which is also the outside diameter of a piece of standard 1/2" copper pipe..This might change after a trip to home depot.
JimmyU
  • Last login:July 20, 2026, 06:54:44 am
  • I believe I can fly!
Re: Attempting to create some 3d Printable star wars yoke handles
« Reply #10 on: October 21, 2016, 11:21:48 am »
Does anybody know which plastic the old handles were made of? I think most 3D printers use ABS now.
menace
« Reply #11 on: October 21, 2016, 12:41:46 pm »
They were cast aluminum so yeah there'll be some details lost to anot her Era.   I've tried his prototype handles and other than being very light they have the right feel.
menace
« Reply #12 on: October 23, 2016, 07:59:55 am »
I had some free time yesterday afternoon so I started the yoke body.  I used my plans from a decade ago...http://arcadecontrols.com/hosted/yoke/
And modified them for 1/2" copper tubing--the X-axis shaft is 3/8" x3" black steel gas pipe threaded into the wood body--much beefier than the lamp tubes I used on the previous incarnation.  I also used plastic bushings on the shaft for a smoother quieter movement--no more squeeky wood on metal.   Next step is finding some good return to center springs-I think a microsoft steering wheel may make a donation in that regard.
(sorry for the crazy background--its halloween central around here  ;D)
The thumb buttons...
« Last Edit: October 23, 2016, 08:03:56 am by menace »
menace
« Reply #13 on: October 30, 2016, 08:15:44 am »
first prototype--red triggers were the discretion of the printer--I like the contrast!  Its a two part clamshell type assembly with the 5/8" hole for mounting to the 1/2" copper pipe.
This took 12 hours to print  :dizzy:
menace
« Reply #14 on: October 30, 2016, 08:19:40 am »
fully operational base--my return to center rate is off so I think I need beefier springs.
menace
« Reply #15 on: November 10, 2016, 05:20:08 pm »
Prototype from the printer!
« Reply #16 on: November 10, 2016, 05:54:53 pm »
That's not too shabby!  Just needs a good sanding and an acetone bath and it'll be funky fresh!
Definitely interested in a set or the plans
matsadona
  • Last login:Yesterday at 08:00:25 am
« Reply #17 on: November 11, 2016, 08:56:38 am »
This is definitely something I'm interested in, since my old SW cabinet without a yoke could need some love and be played properly again :)
