Author Topic: Disabling the "There are known problems" MAME message  (Read 5152 times)
JohnnyG
  • Last login:October 09, 2016, 06:25:16 pm
« on: September 20, 2016, 08:50:04 pm »
I am using HyperSpin with RockerLauncher to launch MAME64 0.175 and several of the ROM's come up with the message "There are known problems with this machine".  In a lot of cases it is simply because the qsound.bin ROM needs to be redumped and nobody seems to be able to do so.
Anyhow, I have read that there were ways to disable this message in the past (though I could be reading that wrong), but I am not seeing any simple way to do so with the 0.175 version.  Can someone tell me if this is possible, and if so, how to go about doing so?  When so many games are having this issue, it is really annoying.
Any help would be greatly appreciated.  Thanks!
thomas_surles
Re: Disabling the "There are known problems" MAME message
« Reply #1 on: September 20, 2016, 08:57:53 pm »
You need to compile it is believe. Though I've never gotten around to it.
« Reply #2 on: September 20, 2016, 09:28:24 pm »
Look up bruh. It's pinned at the top of the forum you just posted in.
JohnnyG
« Reply #3 on: September 20, 2016, 11:36:00 pm »
Is that recompiling it with hiscore diff?  Is that what you're referring to?
« Reply #4 on: September 20, 2016, 11:46:28 pm »
Yes compiling your own allows a patch that puts the option to toggle nag screens in your mame config.
« Reply #5 on: September 29, 2016, 04:40:46 pm »
Alternatively, you could run GroovyMAME which has them pre-compiled for you.  But that's opening up another can of worms, since you need to configure your system (CRTemu driver) for GroovyMAME.
Might be worth it in the long run though...  GroovyMAME kicks ass.
DeL
