Author Topic: MaLa Recognizing Buttons After "Emulator" Started  (Read 5619 times)
DaredevilDave
  • Last login:August 01, 2024, 03:29:25 pm
  • Yes, I really am still working on it!
« on: September 01, 2016, 02:58:40 am »
MaLa is recognizing my arcade cabinet buttons even after I launch a PC game or app (kodi), and RELAUNCHING the same game every time I hit it. MaLa does not have focus at this point.
This doesn't happen when I run Mame from MaLa.
Using Windows 7 64
Should I maybe use Joy2Key instead of allowing Joystick control directly in MaLa?
« Last Edit: September 01, 2016, 03:43:34 pm by DaredevilDave »
"Computer Space" (1st coin-op game ever) for MAME Front Ends Available Now!
http://forum.arcadecontrols.com/index.php/topic,155041.0.html
My Custom Motorcycle Cabinet Build For Custom Game (Daredevil Dave):
http://forum.arcadecontrols.com/index.php/topic,151106.0.html
DaredevilDave
Re: MaLa Recognizing Buttons After "Emulator" Started
« Reply #1 on: September 01, 2016, 04:28:55 pm »
Looks like I solved my own problem - or rather JoyToKey did. :)
(if anyone has a solution that doesn't involve JoyToKey I'm still interested)
If anyone else has this problem, download JoyToKey, set up a new profile for each program - in my case MaLa and KODI (xbmc).
Make sure to set it to revert to the "default" profile if neither program has focus in Windows. You have a few options here.
So far so good. Not the ideal solution, but it works fine. If it still does after more testing I will purchase it ;)
http://joytokey.net/en/
« Last Edit: September 01, 2016, 04:33:49 pm by DaredevilDave »
