Author Topic: HLSL not working. Using DirectX 11, MameUIFX 0.159, Hyperspin, RocketLauncher  (Read 4323 times)
Carlisimo
  • Last login:October 10, 2017, 12:58:03 am
Although my ROMS play fine right now, both standalone and with HyperSpin, I can't get either to show HLSL scanlines.  I have enabled HLSL within the mame.ini file and also enabled the menu options within RocketLauncherUI (Mame > Modules > MAME.ahk > Edit Global Module Settings, set HLSL within Settings and MAME to HLSL set to "true" (tried "ini" as well).  Nothing works.  Again, I verified that I have DirectX 11 running.  I'm on Windows 7. Any help would be greatly appreciated.  Thank you.
teknikfrik
  • Last login:August 31, 2016, 05:42:43 am
Have you checked the raster.ini file in MAME? It overrides the main ini file for raster games.
Made the MAME cabinet playable before it was finished... not quite finished, yet ;)
Carlisimo
Thanks for the reply.  Right now I don't have a raster.ini file (MAMEUIFX 0.159 > ini).   Is it created if I make some changes within the MAMEUIFX or do I need to create or copy one from somewhere else?  Again, thanks for the guidance.  I really appreciate it.
B2K24
  • Last login:June 10, 2025, 10:17:56 am
You don't want to be using such an old version of MAME when it comes to HLSL. Setup from scratch a clean install of version 0.175 and your HLSL with MAME experience will greatly improve.
Carlisimo
@B2K24 thanks for the quick reply.  I've tried in the past to upgrade ROMS to a later version of MAME but was unsuccessful in doing so.  What do you suggest as the easiest/best way to upgrade my 0.159 ROMS to 0.175 so I can run them on the newer emulator version?
  • Last login:Today at 05:45:09 pm
In case you didn't follow the link in the PM I sent when I deleted your two earlier posts, Carlisimo, here is the relevant part of Rule 5.   :police:
Need a ROM to complete your MAME collection? Don't bother to post here. If someone posts such a request, please don't answer it -- no direct answers, no hints, no private messages.
Way to be a dick about it.
A simple "please don't post links to ROMs" would have sufficed.
