Author Topic: Cannot get GUN#2 recognized in MAME, both guns show up as GUN#1  (Read 56789 times)
sevenseal
  • Last login:February 13, 2023, 09:59:14 am
  • Tapatalk User
Re: Cannot get GUN#2 recognized in MAME, both guns show up as GUN#1
« Reply #80 on: July 30, 2016, 07:54:26 pm »
i have tried out your compiled of the 175, and it works out great with the dual lightguns...
i tried to apply your diff to 176
does not match what there...
so i tried to add the code manually
could not get it to compiled for 176, too many errors, something seem to be missing code wise
i did a comparsion of the input_rawinput.cpp file you had added with your patch v5 and compared to original input_rawinput.cpp in 175...
the changes dont seem match what is in the input_rawinput.cpp.diff you had made.
so i did a comparsion on 176's input_rawinput.cpp with the your included one... could not make it compile
all i have to say is that your compile seem to work well on 175...
« Last Edit: July 31, 2016, 10:38:23 am by sevenseal »
Sorn
  • Last login:July 09, 2018, 08:56:19 pm
« Reply #81 on: July 31, 2016, 05:04:39 pm »
Big update today! :)
@argonlefou,
Big thanks to you for your suggestions and help. As you mentioned, my biggest mistake was the use of the GetScreenPos and PointerToScreen functions. This caused a lot of issues. Can you explain quickly the purpose of those?
What I do now, is use the normalize function provided in Mame that is also used in 0171, like this:
Code: [Select]
// update the X/Y positions
lightgun.lX = normalize_absolute_axis(rawinput.data.mouse.lLastX, 0, INPUT_ABSOLUTE_MAX);
lightgun.lY = normalize_absolute_axis(rawinput.data.mouse.lLastY, 0, INPUT_ABSOLUTE_MAX);
I didn't have to separate the devices in the different tables. The "process_event" procedure validates if it's a relative or absolute device.
@Sorn,
Can you test this one?
**Very important**, you have to set back the "lightgunprovider" to "auto" in mame.ini (which is best since it's the default)
http://www.filedropper.com/mamearcade64_11
I'm very happy with the result. You'll probably tell me that the pointer in tab menu doesn't follow the crosshair, but I can guarantee you that I'm processing using the real absolute values for the lightgun and relative for mouse. Maybe the UI is using something different, I can't tell. But, for me, the crosshair tracks perfectly the gun.
I also test, 2 mice, 2 lightguns, 1 mouse and 1 lightgun, etc, and it works fine.
Hope you'll get same result.
Thanks for all the testing.
Note this is still based on Mame0175.
Thanks very much all!
Pitou!
CONGRATULATIONS!!!!  :cheers: :notworthy: :applaud: ....You've done it!
" You'll probably tell me that the pointer in tab menu doesn't follow the crosshair" .....
Same thing occurs in 0171. It does not seem to have any effect on the accuracy once in game so who cares ? :)
Testing between v11 and 0171, I can notice NO difference whatsoever. I think any variances at this point are variances that exist within the aimtrak calibration itself, and not from any of your input code!
Really excited that you got it working with the win32 drivers, everything is deadly accurate now. Gun 1/2 shows up as it should, everything is 100% in order.
Would really like to try to compile your source (once you've done 0176) now and get mkchamps no-nag/hiscore working so I can slap this in my setup :)
And lets keep our fingers crossed that your patch will make its way to 0177, that maintainers will keep the input code and that you wont have to do anymore updating! I also responded on the mametesters bug report to confirm that all is well. I think it would probably be best to port it to 0176 to make sure there are no regressions in any code, and they will likely get it merged for 0177!
Out of interest has anyone tried the new mame with dual guns to see if its fixed?
Ime still running .170 for this reason.
I just tested 0176 now, same issue persists. However im sure if you give Pitou a day or so he will port the changes to 0176 and it will be posted here. He can also finally submit his patch through the mametesters bug report I created so we can get his patch added to the official repository!
« Last Edit: July 31, 2016, 05:10:51 pm by Sorn »
Pitou
  • Last login:March 10, 2026, 04:16:11 pm
« Reply #82 on: July 31, 2016, 09:19:55 pm »
Great news!
Thanks to all for the help. Without you, I don't think I would have make it.
Ok I didn't notice. I'm happy to see the behavior is the same. :)
Actually it's the rawinput API, just to be precise. :)
I'm really glad it works fine as before :)
Now...
Here is an official mame 0.176 64-bit arcade only binary:
http://www.filedropper.com/mamearcade64official
Here is mame 0.176 64-bit arcade only binary with MKChamp patch:
http://www.filedropper.com/mamearcade64mkchamp
Also attached is the patch_v5_0176.zip
Next step is the pull request and merge!
Have fun!
Pitou!
« Last Edit: August 01, 2016, 11:01:33 am by Pitou »
Sorn
« Reply #83 on: July 31, 2016, 09:49:11 pm »
Great news!
Now...
Also attachached is the patch_v5_0176.zip
Have fun!
Pitou!
YOU'RE THE MAN NOW DOG!
sevenseal
  • Tapatalk User
« Reply #84 on: July 31, 2016, 10:22:58 pm »
Great news!
Now...
Have fun!
Pitou!
thank you, i will give this a try
Pitou
« Reply #85 on: August 02, 2016, 12:47:19 am »
Pull request submitted to Mamedev. Let's hope it's gonna make it for 0.177!
Pitou!
justindarc
  • Last login:December 29, 2016, 02:16:15 pm
« Reply #86 on: August 02, 2016, 01:30:09 am »
Pitou!
w00t!! Great work Pitou!! Many, many thanks for fixing this \o/
Pitou
« Reply #87 on: August 02, 2016, 10:54:46 am »
Big thanks to you justindarc for the pull request procedure help.
This was a successful team work effort. Everyone deserve credit! :)
Pitou!
appear
  • Last login:August 26, 2016, 04:38:44 pm
« Reply #88 on: August 26, 2016, 04:28:06 pm »
Hi
I just got two guns and I ran into this problem :)
The 176 binaries are down. Could someone be so kind as to upload them one again? Thank you so much!!
Pitou
« Reply #89 on: August 27, 2016, 10:49:21 am »
@appear,
0.177 will be released next week, if you want to wait just a bit. :)
Pitou!
Sorn
« Reply #90 on: August 27, 2016, 06:39:05 pm »
Hi
Here you go -
http://www.xbins.org/iriez/mamearcade64_MKChamp.7z
@Pitou - Looking forward to next week! :) Could you post here when it goes live? I will have forgotten about this in roughly 10 minutes so a reminder would be nice :)
Pitou
« Reply #91 on: August 28, 2016, 11:16:21 pm »
@Sorn,
I will do!
I also did another patch to fix hit offsets for Laser Ghost and the developers did accept it! :)
You can have a look here in case you're interested in this game:
http://mametesters.org/view.php?id=1455
https://github.com/mamedev/mame/commit/fac1d64c58847ae190f60ee942264cd08d723db3
https://github.com/mamedev/mame/commit/931d6f5b628ecdfc19956316a18da9fdacdd8177
Big thanks to R. Belmont (rb6502) and Happp for the merge!
I'm also looking forward to 0.177!
Pitou!
Sorn
« Reply #92 on: August 29, 2016, 06:37:31 pm »
@Sorn,
I will do!
Pitou!
Cool game, never seen it! Thanks :)
Pitou
« Reply #93 on: August 31, 2016, 08:08:20 am »
@Sorn,
Mame 0.177 is out.
Check it out!
Pitou!
Titchgamer
« Reply #94 on: August 31, 2016, 03:35:16 pm »
Are both guns working in the new version again?
Pitou
« Reply #95 on: August 31, 2016, 05:20:58 pm »
Yes it should.
Titchgamer
« Reply #96 on: August 31, 2016, 07:44:04 pm »
Ile give it a shot over the weekend.
Ime still running .170 to get round this prob.
Sorn
« Reply #97 on: August 31, 2016, 09:11:36 pm »
Yes it should.
Awesome!!!! When I have 10 minutes to play I will give it a whirl.
http://mamedev.org/?p=430
We've integrated a fix for Aimtrack Dual Lightguns on windows from new contributor Pitou
woohooo!!! congratulations :) Very happy to be a contributing part (even if indirect) of the MAME project.
Carlisimo
  • Last login:October 10, 2017, 12:58:03 am
« Reply #98 on: July 27, 2017, 12:39:12 pm »
Has anyone verified that 0.177 has resolved this issue?   I'm running 0.179 and still have the same problem as identified within this thread.   My specifics are described here:
http://forum.arcadecontrols.com/index.php/topic,154850.0.html
Sorn
« Reply #99 on: July 27, 2017, 02:38:32 pm »
Thats a bummer to hear. I'll ping Pitou and see if he knows whats up. I assumed these fixes were merged into the main branch long ago, but maybe not?
Titchgamer
« Reply #100 on: July 27, 2017, 05:25:53 pm »
I never did get around to testing this!
Sorry, but .170 defo works lol
Pitou
« Reply #101 on: July 31, 2017, 11:37:49 am »
Merge was done couple of versions ago.
I will try to test it this week.
Thanks for reporting.
Pitou!
Pitou
« Reply #102 on: July 31, 2017, 09:31:03 pm »
Just tested with Mame 0.188 and Police Trainer and everything is fine.
Pitou!
