Author Topic: Sony trinitron Scart TV issue  (Read 2113 times)
peakymonster
  • Last login:January 15, 2016, 07:46:05 pm
« on: December 01, 2015, 02:36:57 pm »
Hey guys new to this forum , would any of you guys have any experience with the following tv
I need to access the service menu but the code I found online doesn't work
It's Press , standby, display , 5 , vol +, the power on , but unfortunately pressing
Key 5 on the remote brings it straight out of standby . Any ideas thanks
I've included pics of the set which I got for free .
markc74
  • Last login:May 23, 2026, 08:25:35 am
  • Flipping out
Re: Sony trinitron Scart TV issue
« Reply #1 on: December 01, 2015, 07:06:05 pm »
Im pretty sure I've used that model or something similar before. It's defo a combo like that. Are you using the original remote control? If not then it might not be working as you'd expect.
Try finding the manual online which helped me.
Quick google on phone brought up this: http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/KV29F1A/KV29F1K/KV29F1R/KV29F1U/
adder
« Reply #2 on: December 01, 2015, 07:18:40 pm »
looks like mark has found the correct manual, cool :)
so.....see, section 4 of that manual for the solution...
----- direct link:  http://freeservicemanuals.info/servicemanuals/download/Sony/kv-29f1a.pdf
peakymonster
« Reply #3 on: December 01, 2015, 09:00:08 pm »
Thanks for the replys guys I'll take a look cheers
peakymonster
« Reply #4 on: December 01, 2015, 09:28:33 pm »
Well there loads of great info in the manual cheers guys . turns out I was pressing a wrong key the writing on the buttons has worn away with age , was trying to turn it on with the standby button . lol this set is way to heavy to put in a cabinet like I was planning , was expecting a smaller set when I collected it. Hopefully its up to the job ,☺
