Author Topic: Manually update GroovyMAME on GroovyArcade Install  (Read 3954 times)
robbo43
  • Last login:April 04, 2021, 09:25:51 pm
« on: October 18, 2015, 11:09:21 am »
Hi all,
Have had a good look around, but can't find a guide on how to manually update GroovyMAME in GroovyArcade. The latest version within the system update menu is version 0.160, but I would like to update to 0.165. Any guides / tutorials around on how to do this?
Cheers
Rob
robbo43
Re: Manually update GroovyMAME on GroovyArcade Install
« Reply #1 on: October 19, 2015, 01:39:36 pm »
Hi All,
I managed to work this out. It is as easy as replacing the groovymame file in folder usr/local/games/bin. I would suggest renaming existing file to groovymame.old so it can be restored.
The key issue is to extract the downloaded .tar.bz2 archive in Linux. I was using 7zip in windows and the emulator would not load.
Transfer the .tar.bz2 file to usr/local/games/bin folder then type: tar xvjf filename.tar.bz2
The last step is to delete the mame.xml file in home/.advance. When starting the frontend a new mame.xml file will be generated for the version of GroovyMame you are running.
This can all be done over the network from a windows PC using WINSCP with Putty installed to execute the .tar.bz2 extraction commands.
Cheers
Rob
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #2 on: October 20, 2015, 05:21:26 am »
Thank you robbo43 for sharing the upgrade process.
Deleting the mame.xml file is not a mandatory step, the front-end (advandemenuplus) will regenerate it at first launch.
