Author Topic: TXFBM019TB2 LCD Display - What kinda Stuff can I hook to it?  (Read 1691 times)
djfender
  • Last login:April 13, 2020, 04:13:15 pm
  • I play with sega, not ladies' hearts.
« on: October 16, 2015, 05:24:19 am »
OK so I got some supposedly brand new because it still had the plastic on them (2) TXFBM019TB2 Panasonic 7 Inch Displays, legend has it they're used in pachinko machines and can take RAW Composite Sync CGA.
I tried wiring it to my PSOne, PS2 and PS3 on YPbPr Cables, the picture shows but rolls and waves.
The Dreamcast did this weird rolling into a stable split video thing like Occulus Rift on 31khz VGA. (I bet if I had a VGA BOX with the pins set for 15khz RGB instead of a Tomee Cable it would probably spit out CGA)
Soft15khz worked for a *while* until the picture slowly drifted off (curse you unshielded cables!!!)
So, Besides a Straight up JAMMA board, what could I interface this with?
is there a way to get anything into it without a GBS8100?
Should I just Sell them?
Would anyone be willing to trade a single LCD for an X-In-One Jamma box?
« Last Edit: October 16, 2015, 05:55:37 am by djfender »
Is that a Sanwa in your pocket or are you just happy to see me?
"Hotrodded" Hanaho Hotrod w/Kade MiniArcade 2.0 on Leonardo
lilshawn
  • Last login:Yesterday at 07:22:30 pm
  • Last login:May 19, 2026, 11:21:47 am
Re: TXFBM019TB2 LCD Display - What kinda Stuff can I hook to it?
« Reply #2 on: October 19, 2015, 11:38:44 pm »
I use one of these on my JAMMA test rig, The Troubleshooter II:
http://forum.arcadecontrols.com/index.php/topic,134993.msg1393166.html#msg1393166
« Reply #3 on: October 19, 2015, 11:39:44 pm »
Oh, and if you are interested in selling one, send me a PM with your price.
djfender
« Reply #4 on: October 22, 2015, 08:19:42 am »
http://forums.arcade-museum.com/showthread.php?t=203790
It turns out one of my junked playstations is capable of outputting composite sync, so I'm probably going to hard solder one of these to the motherboard and then use it for my other project which is building a solid state board so I can dump certain Arcade games into it.
