Author Topic: [SOLVED] What aspect ratio is your typical arcade game?  (Read 9948 times)
TheOnlyShad0w
  • Last login:November 24, 2016, 03:45:48 pm
« on: October 09, 2015, 07:40:59 pm »
I'm going to be using a 32" LED TV place vertically in my cabinet, however I want to cover the top and bottom areas of the display since the entirety of the 16:9 TV won't be used. I was under the assumption that the tallest aspect ratio would have been 3:4 (3 across, 4 tall). Is that correct?
I'd plug everything into my monitor and just test games directly but I don't have my monitor yet and I want to get an idea of dimensions in Sketchup before building anything.
Thanks in advance!
« Last Edit: October 09, 2015, 08:27:22 pm by TheOnlyShad0w »
Slippyblade
Re: What aspect ratio is your typical arcade game?
« Reply #1 on: October 09, 2015, 07:53:44 pm »
You are correct.  Arcade games used standard CRT tubes which were a 4:3 ration.  The vertical games used the same tubes and just mounted them sideways in the cabinet.
TheOnlyShad0w
« Reply #2 on: October 09, 2015, 08:00:39 pm »
Cool. So was that the tallest they got? Were there any games that were every taller than 4:3 in a vertical orientation? I just need to be sure before I block off part of my screen that could have been utilized.
Slippyblade
« Reply #3 on: October 09, 2015, 08:22:31 pm »
Nothing "taller".  There were a few games that used multiple 4:3 CRT's in a horizontal layout to get a super wider display.  Darius is the poster child of doing that.
TheOnlyShad0w
« Reply #4 on: October 09, 2015, 08:27:10 pm »
Interesting! Well I guess that's all I needed. Thanks!
