Author Topic: WG K7000 update!!!  (Read 1170 times)
Joselv81
  • Last login:November 10, 2015, 10:20:02 pm
WG K7000 update!!!
« on: October 04, 2015, 03:43:56 am »
Well first off great to be a part of the community. Well it has been a rough week, just got a cabinet that included x-arcade joystick and buttons thats good I guess. Had some troublw getting the connections right but finally got it. Now my issue is that I setup a vga cable to my monitor after using a jamma adapter and had issues with the monitor I was thinking that was the problem. Turns out it wasn't the monitor would not hold sync all the time. I tried changing it to vga it works better i would say but now the issue is that I see three of my drsktops and they all look terrible. I am thinking it might be a horizontal issue but don't want to mess with it too much as I am not very experienced. If anyone had had this issue and got it fixed or has any input please let me know,  I am to the point of taking the darn thing out and putting in a lcd but that might be too small.  TIA
Update: Well I think I have the 15khz installed correctly now I had two displays and then boom back to three so I know I am doing something right. Here are some of  my specs of anyone can help I am running a Nvidia g210 with Windows 7 x64 have soft15khz but at times gives me a runtime error 13 I've tried arcadeosd but to no avail cant seem to understand Powerstrip either. Really any help would be appreciated thanks again.
« Last Edit: October 06, 2015, 11:07:24 pm by Joselv81 »
SailorSat
  • Last login:March 02, 2026, 11:07:22 pm
    • For Amusement Only e.V.
Re: WG K7000
« Reply #1 on: October 05, 2015, 02:31:29 am »
You DO feed it with a 15kHz Signal? - It won't work with a plain VGA Signal.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Joselv81
Re: WG K7000
« Reply #2 on: October 05, 2015, 04:57:39 am »
Well i am trying to setup powerstrip and soft15k but soft gives me runtime error 13 and powestrip can really get into it ahould i try and install a second monitor first?
