Author Topic: No picture with universal chassis from aliexpress  (Read 3587 times)
amplibax
  • Last login:March 29, 2024, 06:41:05 am
« on: September 02, 2015, 09:19:49 pm »
I bought a few universal chassis from Aliexpress for myself and a  couple friends to try out. I have a Mortal Kombat with a 25K7000 that has issues with the chassis so I figured I would try one out. I realize the Chinese universal chassis are not the same quality as an original but I wanted to give one a go anyway.
I hooked everything up. I of course double checked the yoke readings on my tube first and everything checked out good, but I unfortunately get no image at all, no neck glow, etc. I have tested two of these so far and I have the same issue. Is there anything I could be missing? I have the power, neckboard ground, yoke connections and video input all connected.
Here is a pic of the chassis I have:
Has anyone had any luck with this exact chassis? I have also tried it with a different tube and iso.
Ken Layton
  • Guru
  • Technician
Re: No picture with universal chassis from aliexpress
« Reply #1 on: September 04, 2015, 03:04:20 pm »
What is the brand and model of that replacement chassis?
Pictures of how you connected it. I hope you did not plug the power cord into a wall outlet since this chassis appears to require an  isolation transformer.
Did this chassis come with instructions or schematic?
Did you Americanize it first before powering it up?
« Last Edit: September 04, 2015, 03:06:18 pm by Ken Layton »
amplibax
« Reply #2 on: September 04, 2015, 11:30:18 pm »
It's connected correctly. I didn't plug it into the wall. It's plugged into an iso.
There were no instructions or schematic.  The only information I have on the brand or model number is what is on the picture I posted. Looks like the brand is "Se-Cai"
Here is a link to the item:
http://www.aliexpress.com/item/SC-25-29-CGA-CRT-monitor-arcade-chassis-Arcade-Parts-for-Arcade-Game-Machine-Coin-operator/618618401.html?spm=2114.01020208.3.2.zNDOeu&ws_ab_test=201407_4,201444_6,201409_1
I bought 3 of these. I tested two of them and they didn't work and them the third one worked. I think two of them may be DOA
What do you mean by Americanizing it?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 05, 2015, 12:25:19 am »
Americanizing means removing the phony baloney non-standard Chinese/Japanese video signal connector and power cord and replacing with American standard connectors & cord.
http://forum.arcadecontrols.com/index.php/topic,97584.msg1029468.html#msg1029468
These universal monitor chassis do NOT come configured for conventional USA standard cables or connectors out of the box. So in essence they are not plug n play until they get Americanized.
« Last Edit: September 05, 2015, 12:27:02 am by Ken Layton »
grantspain
« Reply #4 on: September 05, 2015, 04:32:51 am »
the vast majority of chinese built chassis are absolute rubbish,i must have tested 20 different types in the last 10 years-most either arrive non working or fail in quick time.
the only chassis from the far east i wouid bother with are wei ya or rodotron
there is a reason they are priced at $33
Ken Layton
  • Guru
  • Technician
« Reply #5 on: September 05, 2015, 12:14:03 pm »
I found some other company also selling this Se-Cai chassis:
http://arcadejapan.co.uk/Se-Cai-CGA-Monitor-Chassis-25%22-29%22-15khz
In the fine print it says this chassis does not provide an output to a degaussing coil (that's not good).
Here's another one:
http://timeharvest.net/sc-21-inch-cga-crt-monitor-arcade-chassis-arcade-accessories-for-arcade-game-machinecoin-operator-cabinetamusement-mchine-p-734.html
« Last Edit: September 05, 2015, 02:49:16 pm by Ken Layton »
