Author Topic: Windows 7 & Groovymame 0.164 issues  (Read 7868 times)
xga
  • Last login:August 01, 2026, 11:01:59 am
« on: August 18, 2015, 10:00:11 am »
Hi All,
I've just installed Windows 7 Pro x64 and Groovymame64 0.164 on a notebook with an ATI 4330 video card.  I've followed the install guide here http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=290 and have Arcade_OSD running correctly with Super Resolutions and being able to display all the custom resolutions that I choose.  The problem is, when I run the Groovymame.exe, I receive the error message "SwitchRes: could not find a video mode that meets your specs".  Clicking "OK" takes me into the Mame menu, where I can see my roms.  Selecting a rom displays the same SwitchRes error mesage, clicking OK will then launch the rom, but stretches the display of the rom to the desktop resolution.
I've disabled UAC and given the Groovymame executable admin rights, but it still throws up a SwitchRes error messages and won't allow roms to work in their native resolution.
I've taken the logs of the Double Dragon rom (see below), but can't see anything obvious.  Can anyone see or know what might be wrong?
Code: [Select]
SwitchRes: v0.015h, Monitor: generic_15, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15625.00-15750.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
SwitchRes: \\.\DISPLAY1: ATI Mobility Radeon HD 4300 Series
SwitchRes: DeviceKey: System\CurrentControlSet\Control\Video\{36359DFE-17E4-4A5E-8C90-DE36639ADC1F}\0000
Switchres: Searching for custom video modes...
Switchres: [  1]  240x 224 @ 60 : DALDTMCRTBCD240x224x0x60 - Modeline "240x224_60 15.66KHz 59.98Hz" 5.01 240 256 280 320 224 234 237 261   -hsync -vsync
Switchres: [  2]  240x 240 @ 60 : DALDTMCRTBCD240x240x0x60 - Modeline "240x240_60 15.66KHz 59.98Hz" 5.01 240 256 280 320 240 242 245 261   -hsync -vsync
Switchres: [  3]  248x 224 @ 60 : DALDTMCRTBCD248x224x0x60 - Modeline "248x224_60 15.65KHz 59.98Hz" 5.26 248 264 288 336 224 234 237 261   -hsync -vsync
Switchres: [  4]  248x 240 @ 60 : DALDTMCRTBCD248x240x0x60 - Modeline "248x240_60 15.65KHz 59.98Hz" 5.26 248 264 288 336 240 242 245 261   -hsync -vsync
Switchres: [  5]  256x 224 @ 60 : DALDTMCRTBCD256x224x0x60 - Modeline "256x224_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 224 234 237 261   -hsync -vsync
Switchres: [  6]  256x 240 @ 60 : DALDTMCRTBCD256x240x0x60 - Modeline "256x240_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 240 242 245 261   -hsync -vsync
Switchres: [  7]  264x 224 @ 60 : DALDTMCRTBCD264x224x0x60 - Modeline "264x224_60 15.64KHz 59.92Hz" 5.63 264 280 312 360 224 234 237 261   -hsync -vsync
Switchres: [  8]  264x 240 @ 60 : DALDTMCRTBCD264x240x0x60 - Modeline "264x240_60 15.64KHz 59.92Hz" 5.63 264 280 312 360 240 242 245 261   -hsync -vsync
Switchres: [  9]  272x 224 @ 60 : DALDTMCRTBCD272x224x0x60 - Modeline "272x224_60 15.65KHz 59.97Hz" 5.76 272 288 320 368 224 234 237 261   -hsync -vsync
Switchres: [ 10]  280x 224 @ 60 : DALDTMCRTBCD280x224x0x60 - Modeline "280x224_60 15.64KHz 59.92Hz" 5.88 280 296 328 376 224 234 237 261   -hsync -vsync
Switchres: [ 11]  280x 240 @ 60 : DALDTMCRTBCD280x240x0x60 - Modeline "280x240_60 15.64KHz 59.92Hz" 5.88 280 296 328 376 240 242 245 261   -hsync -vsync
Switchres: [ 12]  288x 224 @ 60 : DALDTMCRTBCD288x224x0x60 - Modeline "288x224_60 15.65KHz 59.97Hz" 6.01 288 304 336 384 224 234 237 261   -hsync -vsync
Switchres: [ 13]  288x 240 @ 60 : DALDTMCRTBCD288x240x0x60 - Modeline "288x240_60 15.65KHz 59.97Hz" 6.01 288 304 336 384 240 242 245 261   -hsync -vsync
Switchres: [ 14]  296x 224 @ 60 : DALDTMCRTBCD296x224x0x60 - Modeline "296x224_60 15.64KHz 59.91Hz" 6.13 296 312 344 392 224 234 237 261   -hsync -vsync
Switchres: [ 15]  296x 240 @ 60 : DALDTMCRTBCD296x240x0x60 - Modeline "296x240_60 15.64KHz 59.91Hz" 6.13 296 312 344 392 240 242 245 261   -hsync -vsync
Switchres: [ 16]  304x 224 @ 60 : DALDTMCRTBCD304x224x0x60 - Modeline "304x224_60 15.64KHz 59.91Hz" 6.38 304 320 352 408 224 234 237 261   -hsync -vsync
Switchres: [ 17]  304x 240 @ 60 : DALDTMCRTBCD304x240x0x60 - Modeline "304x240_60 15.64KHz 59.91Hz" 6.38 304 320 352 408 240 242 245 261   -hsync -vsync
Switchres: [ 18]  320x 224 @ 60 : DALDTMCRTBCD320x224x0x60 - Modeline "320x224_60 15.64KHz 59.91Hz" 6.63 320 336 368 424 224 234 237 261   -hsync -vsync
Switchres: [ 19]  320x 240 @ 60 : DALDTMCRTBCD320x240x0x60 - Modeline "320x240_60 15.64KHz 59.91Hz" 6.63 320 336 368 424 240 242 245 261   -hsync -vsync
Switchres: [ 20]  328x 224 @ 60 : DALDTMCRTBCD328x224x0x60 - Modeline "328x224_60 15.65KHz 59.95Hz" 6.76 328 344 376 432 224 234 237 261   -hsync -vsync
Switchres: [ 21]  336x 240 @ 60 : DALDTMCRTBCD336x240x0x60 - Modeline "336x240_60 15.66KHz 60.00Hz" 6.89 336 352 384 440 240 242 245 261   -hsync -vsync
Switchres: [ 22]  344x 240 @ 60 : DALDTMCRTBCD344x240x0x60 - Modeline "344x240_60 15.65KHz 59.95Hz" 7.01 344 360 392 448 240 242 245 261   -hsync -vsync
Switchres: [ 23]  352x 224 @ 60 : DALDTMCRTBCD352x224x0x60 - Modeline "352x224_60 15.66KHz 59.98Hz" 7.39 352 368 408 472 224 234 237 261   -hsync -vsync
Switchres: [ 24]  352x 240 @ 60 : DALDTMCRTBCD352x240x0x60 - Modeline "352x240_60 15.66KHz 59.98Hz" 7.39 352 368 408 472 240 242 245 261   -hsync -vsync
Switchres: [ 25]  360x 224 @ 60 : DALDTMCRTBCD360x224x0x60 - Modeline "360x224_60 15.65KHz 59.94Hz" 7.51 360 376 416 480 224 234 237 261   -hsync -vsync
Switchres: [ 26]  360x 240 @ 60 : DALDTMCRTBCD360x240x0x60 - Modeline "360x240_60 15.65KHz 59.94Hz" 7.51 360 376 416 480 240 242 245 261   -hsync -vsync
Switchres: [ 27]  368x 224 @ 60 : DALDTMCRTBCD368x224x0x60 - Modeline "368x224_60 15.65KHz 59.98Hz" 7.64 368 384 424 488 224 234 237 261   -hsync -vsync
Switchres: [ 28]  368x 240 @ 60 : DALDTMCRTBCD368x240x0x60 - Modeline "368x240_60 15.65KHz 59.98Hz" 7.64 368 384 424 488 240 242 245 261   -hsync -vsync
Switchres: [ 29]  376x 240 @ 60 : DALDTMCRTBCD376x240x0x60 - Modeline "376x240_60 15.65KHz 59.94Hz" 7.76 376 392 432 496 240 242 245 261   -hsync -vsync
Switchres: [ 30]  384x 224 @ 60 : DALDTMCRTBCD384x224x0x60 - Modeline "384x224_60 15.63KHz 59.90Hz" 7.88 384 400 440 504 224 234 237 261   -hsync -vsync
Switchres: [ 31]  384x 240 @ 60 : DALDTMCRTBCD384x240x0x60 - Modeline "384x240_60 15.63KHz 59.90Hz" 7.88 384 400 440 504 240 242 245 261   -hsync -vsync
Switchres: [ 32]  400x 224 @ 60 : DALDTMCRTBCD400x224x0x60 - Modeline "400x224_60 15.63KHz 59.90Hz" 8.13 400 416 456 520 224 234 237 261   -hsync -vsync
Switchres: [ 33]  400x 232 @ 60 : DALDTMCRTBCD400x232x0x60 - Modeline "400x232_60 15.63KHz 59.90Hz" 8.13 400 416 456 520 232 238 241 261   -hsync -vsync
Switchres: [ 34]  400x 240 @ 60 : DALDTMCRTBCD400x240x0x60 - Modeline "400x240_60 15.63KHz 59.90Hz" 8.13 400 416 456 520 240 242 245 261   -hsync -vsync
Switchres: [ 35]  400x 248 @ 60 : DALDTMCRTBCD400x248x0x60 - Modeline "400x248_60 16.12KHz 59.91Hz" 8.51 400 416 456 528 248 250 253 269   -hsync -vsync
Switchres: [ 36]  416x 224 @ 60 : DALDTMCRTBCD416x224x0x60 - Modeline "416x224_60 15.63KHz 59.87Hz" 8.50 416 432 472 544 224 234 237 261   -hsync -vsync
Switchres: [ 37]  432x 224 @ 60 : DALDTMCRTBCD432x224x0x60 - Modeline "432x224_60 15.64KHz 59.93Hz" 8.76 432 448 488 560 224 234 237 261   -hsync -vsync
Switchres: [ 38]  432x 240 @ 60 : DALDTMCRTBCD432x240x0x60 - Modeline "432x240_60 15.64KHz 59.93Hz" 8.76 432 448 488 560 240 242 245 261   -hsync -vsync
Switchres: [ 39]  432x 248 @ 60 : DALDTMCRTBCD432x248x0x60 - Modeline "432x248_60 16.15KHz 60.03Hz" 9.43 432 456 504 584 248 250 253 269   -hsync -vsync
Switchres: [ 40]  448x 224 @ 60 : DALDTMCRTBCD448x224x0x60 - Modeline "448x224_60 15.65KHz 59.96Hz" 9.39 448 472 520 600 224 234 237 261   -hsync -vsync
Switchres: [ 41]  448x 240 @ 60 : DALDTMCRTBCD448x240x0x60 - Modeline "448x240_60 15.65KHz 59.96Hz" 9.39 448 472 520 600 240 242 245 261   -hsync -vsync
Switchres: [ 42]  456x 232 @ 60 : DALDTMCRTBCD456x232x0x60 - Modeline "456x232_60 15.67KHz 60.05Hz" 9.53 456 480 528 608 232 238 241 261   -hsync -vsync
Switchres: [ 43]  456x 240 @ 60 : DALDTMCRTBCD456x240x0x60 - Modeline "456x240_60 15.67KHz 60.05Hz" 9.53 456 480 528 608 240 242 245 261   -hsync -vsync
Switchres: [ 44]  464x 224 @ 60 : DALDTMCRTBCD464x224x0x60 - Modeline "464x224_60 15.66KHz 60.02Hz" 9.65 464 488 536 616 224 234 237 261   -hsync -vsync
Switchres: [ 45]  480x 224 @ 60 : DALDTMCRTBCD480x224x0x60 - Modeline "480x224_60 15.65KHz 59.95Hz" 9.89 480 504 552 632 224 234 237 261   -hsync -vsync
Switchres: [ 46]  480x 240 @ 60 : DALDTMCRTBCD480x240x0x60 - Modeline "480x240_60 15.65KHz 59.95Hz" 9.89 480 504 552 632 240 242 245 261   -hsync -vsync
Switchres: [ 47]  480x 464 @ 60 : DALDTMCRTBCD480x464x0x60 - Modeline "480x464_60 15.62KHz 59.95Hz" 9.87 480 504 552 632 464 474 479 521 interlace  -hsync -vsync
Switchres: [ 48]  480x 480 @ 60 : DALDTMCRTBCD480x480x0x60 - Modeline "480x480_60 15.62KHz 59.95Hz" 9.87 480 504 552 632 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 49]  496x 224 @ 60 : DALDTMCRTBCD496x224x0x60 - Modeline "496x224_60 15.66KHz 60.01Hz" 10.15 496 520 568 648 224 234 237 261   -hsync -vsync
Switchres: [ 50]  496x 240 @ 60 : DALDTMCRTBCD496x240x0x60 - Modeline "496x240_60 15.66KHz 60.01Hz" 10.15 496 520 568 648 240 242 245 261   -hsync -vsync
Switchres: [ 51]  496x 480 @ 60 : DALDTMCRTBCD496x480x0x60 - Modeline "496x480_60 15.65KHz 60.07Hz" 10.14 496 520 568 648 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 52]  512x 224 @ 60 : DALDTMCRTBCD512x224x0x60 - Modeline "512x224_60 15.65KHz 59.98Hz" 10.52 512 536 584 672 224 234 237 261   -hsync -vsync
Switchres: [ 53]  512x 240 @ 60 : DALDTMCRTBCD512x240x0x60 - Modeline "512x240_60 15.65KHz 59.98Hz" 10.52 512 536 584 672 240 242 245 261   -hsync -vsync
Switchres: [ 54]  512x 400 @ 60 : DALDTMCRTBCD512x400x0x60 - Modeline "512x400_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 400 442 447 521 interlace  -hsync -vsync
Switchres: [ 55]  512x 432 @ 60 : DALDTMCRTBCD512x432x0x60 - Modeline "512x432_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 432 458 463 521 interlace  -hsync -vsync
Switchres: [ 56]  512x 448 @ 60 : DALDTMCRTBCD512x448x0x60 - Modeline "512x448_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 448 466 471 521 interlace  -hsync -vsync
Switchres: [ 57]  512x 480 @ 60 : DALDTMCRTBCD512x480x0x60 - Modeline "512x480_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 58]  544x 480 @ 60 : DALDTMCRTBCD544x480x0x60 - Modeline "544x480_60 15.62KHz 59.95Hz" 11.12 544 568 624 712 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 59]  560x 240 @ 60 : DALDTMCRTBCD560x240x0x60 - Modeline "560x240_60 15.65KHz 59.97Hz" 11.52 560 584 640 736 240 242 245 261   -hsync -vsync
Switchres: [ 60]  576x 224 @ 60 : DALDTMCRTBCD576x224x0x60 - Modeline "576x224_60 15.66KHz 60.02Hz" 11.78 576 600 656 752 224 234 237 261   -hsync -vsync
Switchres: [ 61]  576x 400 @ 60 : DALDTMCRTBCD576x400x0x60 - Modeline "576x400_60 15.64KHz 60.03Hz" 11.76 576 600 656 752 400 442 447 521 interlace  -hsync -vsync
Switchres: [ 62]  576x 432 @ 60 : DALDTMCRTBCD576x432x0x60 - Modeline "576x432_60 15.64KHz 60.03Hz" 11.76 576 600 656 752 432 458 463 521 interlace  -hsync -vsync
Switchres: [ 63]  600x 240 @ 60 : DALDTMCRTBCD600x240x0x60 - Modeline "600x240_60 15.68KHz 60.08Hz" 12.17 600 624 680 776 240 242 245 261   -hsync -vsync
Switchres: [ 64]  640x 224 @ 60 : DALDTMCRTBCD640x224x0x60 - Modeline "640x224_60 15.67KHz 60.05Hz" 13.04 640 664 728 832 224 234 237 261   -hsync -vsync
Switchres: [ 65]  640x 240 @ 60 : DALDTMCRTBCD640x240x0x60 - Modeline "640x240_60 15.67KHz 60.05Hz" 13.04 640 664 728 832 240 242 245 261   -hsync -vsync
Switchres: [ 66]  640x 400 @ 60 : DALDTMCRTBCD640x400x0x60 - Modeline "640x400_60 15.60KHz 59.88Hz" 12.98 640 664 728 832 400 442 447 521 interlace  -hsync -vsync
Switchres: [ 67]  640x 480 @ 60 : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.60KHz 59.88Hz" 12.98 640 664 728 832 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 68]  648x 240 @ 60 : DALDTMCRTBCD648x240x0x60 - Modeline "648x240_60 15.64KHz 59.93Hz" 13.14 648 672 736 840 240 242 245 261   -hsync -vsync
Switchres: [ 69]  664x 496 @ 60 : DALDTMCRTBCD664x496x0x60 - Modeline "664x496_60 16.16KHz 59.96Hz" 14.09 664 696 760 872 496 499 504 539 interlace  -hsync -vsync
Switchres: [ 70]  672x 224 @ 60 : DALDTMCRTBCD672x224x0x60 - Modeline "672x224_60 15.64KHz 59.91Hz" 13.76 672 704 768 880 224 234 237 261   -hsync -vsync
Switchres: [ 71]  672x 240 @ 60 : DALDTMCRTBCD672x240x0x60 - Modeline "672x240_60 15.64KHz 59.91Hz" 13.76 672 704 768 880 240 242 245 261   -hsync -vsync
Switchres: [ 72]  704x 240 @ 60 : DALDTMCRTBCD704x240x0x60 - Modeline "704x240_60 15.66KHz 59.99Hz" 14.53 704 736 808 928 240 242 245 261   -hsync -vsync
Switchres: [ 73]  704x 480 @ 60 : DALDTMCRTBCD704x480x0x60 - Modeline "704x480_60 15.61KHz 59.94Hz" 14.49 704 736 808 928 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 74]  720x 480 @ 60 : system mode
mode_locked
Switchres: [ 75]  800x 600 @ 60 : system mode
mode_locked
Switchres: [ 76] 1024x 768 @ 60* : system mode
Switchres: [ 77] 1280x 240 @ 60 : DALDTMCRTBCD1280x240x0x60 - Modeline "1280x240_60 15.66KHz 59.99Hz" 25.93 1280 1328 1448 1656 240 242 245 261   -hsync -vsync
Switchres: [ 78] 1280x 720 @ 60 : system mode
mode_locked
Switchres: [ 79] 1366x 768 @ 60 : system mode
mode_locked
SwitchRes: Found 74 custom of 79 active video modes
SwitchRes: -resolution was forced as 2560x0
SwitchRes: -resolution value not available: 2560x0
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.015h:[roms\ddragon.zip] Calculating best video mode for 256x240@57.444855 orientation: normal
SwitchRes: [ 240]x[ 224]_(60=59.9847Hz) - locked
SwitchRes: [ 240]x[ 240]_(60=59.9847Hz) - locked
SwitchRes: [ 248]x[ 224]_(60=59.9770Hz) - locked
SwitchRes: [ 248]x[ 240]_(60=59.9770Hz) - locked
SwitchRes: [ 256]x[ 224]_(60=59.9732Hz) - locked
SwitchRes: [ 256]x[ 240]_(60=59.9732Hz) - locked
SwitchRes: [ 264]x[ 224]_(60=59.9157Hz) - locked
SwitchRes: [ 264]x[ 240]_(60=59.9157Hz) - locked
SwitchRes: [ 272]x[ 224]_(60=59.9693Hz) - locked
SwitchRes: [ 280]x[ 224]_(60=59.9157Hz) - locked
SwitchRes: [ 280]x[ 240]_(60=59.9157Hz) - locked
SwitchRes: [ 288]x[ 224]_(60=59.9655Hz) - locked
SwitchRes: [ 288]x[ 240]_(60=59.9655Hz) - locked
SwitchRes: [ 296]x[ 224]_(60=59.9119Hz) - locked
SwitchRes: [ 296]x[ 240]_(60=59.9119Hz) - locked
SwitchRes: [ 304]x[ 224]_(60=59.9119Hz) - locked
SwitchRes: [ 304]x[ 240]_(60=59.9119Hz) - locked
SwitchRes: [ 320]x[ 224]_(60=59.9080Hz) - locked
SwitchRes: [ 320]x[ 240]_(60=59.9080Hz) - locked
SwitchRes: [ 328]x[ 224]_(60=59.9540Hz) - locked
SwitchRes: [ 336]x[ 240]_(60=59.9962Hz) - locked
SwitchRes: [ 344]x[ 240]_(60=59.9502Hz) - locked
SwitchRes: [ 352]x[ 224]_(60=59.9847Hz) - locked
SwitchRes: [ 352]x[ 240]_(60=59.9847Hz) - locked
SwitchRes: [ 360]x[ 224]_(60=59.9425Hz) - locked
SwitchRes: [ 360]x[ 240]_(60=59.9425Hz) - locked
SwitchRes: [ 368]x[ 224]_(60=59.9808Hz) - locked
SwitchRes: [ 368]x[ 240]_(60=59.9808Hz) - locked
SwitchRes: [ 376]x[ 240]_(60=59.9425Hz) - locked
SwitchRes: [ 384]x[ 224]_(60=59.9004Hz) - locked
SwitchRes: [ 384]x[ 240]_(60=59.9004Hz) - locked
SwitchRes: [ 400]x[ 224]_(60=59.9004Hz) - locked
SwitchRes: [ 400]x[ 232]_(60=59.9004Hz) - locked
SwitchRes: [ 400]x[ 240]_(60=59.9004Hz) - locked
SwitchRes: [ 400]x[ 248]_(60=59.9145Hz) - locked
SwitchRes: [ 416]x[ 224]_(60=59.8659Hz) - locked
SwitchRes: [ 432]x[ 224]_(60=59.9310Hz) - locked
SwitchRes: [ 432]x[ 240]_(60=59.9310Hz) - locked
SwitchRes: [ 432]x[ 248]_(60=60.0260Hz) - locked
SwitchRes: [ 448]x[ 224]_(60=59.9617Hz) - locked
SwitchRes: [ 448]x[ 240]_(60=59.9617Hz) - locked
SwitchRes: [ 456]x[ 232]_(60=60.0536Hz) - locked
SwitchRes: [ 456]x[ 240]_(60=60.0536Hz) - locked
SwitchRes: [ 464]x[ 224]_(60=60.0192Hz) - locked
SwitchRes: [ 480]x[ 224]_(60=59.9540Hz) - locked
SwitchRes: [ 480]x[ 240]_(60=59.9540Hz) - locked
SwitchRes: [ 480]x[ 464]_(60=59.9501Hz) - locked
SwitchRes: [ 480]x[ 480]_(60=59.9501Hz) - locked
SwitchRes: [ 496]x[ 224]_(60=60.0115Hz) - locked
SwitchRes: [ 496]x[ 240]_(60=60.0115Hz) - locked
SwitchRes: [ 496]x[ 480]_(60=60.0691Hz) - locked
SwitchRes: [ 512]x[ 224]_(60=59.9770Hz) - locked
SwitchRes: [ 512]x[ 240]_(60=59.9770Hz) - locked
SwitchRes: [ 512]x[ 400]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 432]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 448]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 480]_(60=60.0345Hz) - locked
SwitchRes: [ 544]x[ 480]_(60=59.9501Hz) - locked
SwitchRes: [ 560]x[ 240]_(60=59.9693Hz) - locked
SwitchRes: [ 576]x[ 224]_(60=60.0153Hz) - locked
SwitchRes: [ 576]x[ 400]_(60=60.0307Hz) - locked
SwitchRes: [ 576]x[ 432]_(60=60.0307Hz) - locked
SwitchRes: [ 600]x[ 240]_(60=60.0843Hz) - locked
SwitchRes: [ 640]x[ 224]_(60=60.0498Hz) - locked
SwitchRes: [ 640]x[ 240]_(60=60.0498Hz) - locked
SwitchRes: [ 640]x[ 400]_(60=59.8848Hz) - locked
SwitchRes: [ 640]x[ 480]_(60=59.8848Hz) - locked
SwitchRes: [ 648]x[ 240]_(60=59.9310Hz) - locked
SwitchRes: [ 664]x[ 496]_(60=59.9555Hz) - locked
SwitchRes: [ 672]x[ 224]_(60=59.9080Hz) - locked
SwitchRes: [ 672]x[ 240]_(60=59.9080Hz) - locked
SwitchRes: [ 704]x[ 240]_(60=59.9885Hz) - locked
SwitchRes: [ 704]x[ 480]_(60=59.9386Hz) - locked
SwitchRes: [ 720]x[ 480]_[60=60.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[60=60.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[60=60.0000Hz] - locked
SwitchRes: [1280]x[ 240]_(60=59.9923Hz) - locked
SwitchRes: [1280]x[ 720]_[60=60.0000Hz] - locked
SwitchRes: [1366]x[ 768]_[60=60.0000Hz] - locked
SwitchRes: Setting option -noswitchres
Video: Monitor 000000000856FDE8 = "\\.\DISPLAY1" (primary)
Direct3D: Warning - Unable find any D3D9 DLLs; disabling post-effect rendering
Direct3D: Using Direct3D 9
window_proc: WM_NCACTIVATE
blit_lock = TRUE
Direct3D: Configuring adapter #0 = ATI Mobility Radeon HD 4300 Series
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 8192x8192
Direct3D: Device created at 1024x768
blit_unlock = TRUE
window_proc: WM_PAINT
Blitting thread created
winwindow_video_window_create: blit_lock = TRUE
Blitting thread started
RawInput: APIs detected
Input: Adding Mouse #0: PS/2 Compatible Mouse
Input: Adding Gun #0: PS/2 Compatible Mouse
Input: Adding Kbd #0: Standard PS/2 Keyboard
DirectInput: Using DirectInput 8
blit_lock = FALSE
window_proc: WM_PAINT:END
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Region ':maincpu' created
Region ':sub' created
Region ':soundcpu' created
Region ':gfx1' created
Region ':gfx2' created
Region ':gfx3' created
Region ':adpcm' created
Region ':proms' created
Starting Double Dragon (Japan) ':'
Optional shared pointer 'darktowr_mcu' not found
  (missing dependencies; rescheduling)
Starting HD6309 ':maincpu'
Starting Timer ':scantimer'
Starting HD63701 ':sub'
Starting M6809 ':soundcpu'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Video Screen ':screen'
Starting Speaker ':mono'
Starting YM2151 ':fmsnd'
Starting MSM5205 ':adpcm1'
Starting MSM5205 ':adpcm2'
Average speed: 100.01% (30 seconds)
blit_lock = TRUE
window_proc: WM_DESTROY
blit_lock = TRUE
Blitting thread destroyed
xga
Re: Windows 7 & Groovymame 0.164 issues
« Reply #1 on: August 18, 2015, 10:02:24 am »
In case it helps, here is my mame.ini :
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
console                   0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   generic_15
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              2
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                2560x0
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       6
shadow_mask_usize         0.1875
shadow_mask_vsize         0.1875
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.03
round_corner              0.03
reflection                0.03
vignetting                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
and my VMMaker.ini :
Code: [Select]
; VideoModeMaker - Options
; 1. MAME
; Path for Mame executable, in case we want to extract xml information from it.
MameExe = "C:\Mame\mame64.exe"
; Path for Mame ini folder, in case we want to create an ini file for each game.
; Important: existing ini files will be overwritten.
IniPath = "\Emu\Mame\ini\"
; Mame options.
ListFromXML = 0 ; Processes Mame XML and get video mode list from it
GenerateXML = 0 ; Extracts XML from Mame (only needed once)
OnlyListMain = 0 ; Only list resolutions for games contained in MameMain.txt
GenerateInis = 0 ; Creates an ini file for each Mame game, in the IniPath folder
SDLMame = 0 ; Use SDLMame specific options
; Monitor orientation
MonitorHorizontal = 1 ; 0 = Rotating monitor: horizontal and vertical games at their native resolution
;     Suitable for users that physically rotate their CRTs
; 1 = Horizontal monitor: horizontal games run at their native resolution and
;     vertical games are rotated to fit in horizontal monitor
RotatingDesktop = 0 ; Specifies if both desktop and monitor are rotated
; Aspect ratio for vertical games on horizontal monitor
; 4:3 (keeps original aspect ratio)
; 3:3 (stretches to square format)
; 3:4 (stretches to full screen)
; h:v (custom aspect ratio)
VerticalAspect = "4:3"
; 2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
MonitorType = "CUSTOM"
; Monitor CUSTOM. These values will be used if MonitorType = "CUSTOM"
; monitor_specs_0-6 = "HfreqMin-HfreqMax, VfreqMin,VfreqMax, HFrontPorch, HSyncPulse, HBackPorch, VfrontPorch, VSyncPulse, VBackPorch, HSyncPol, VSyncPol, ActiveLinesLimit, VirtualLinesLimit"
; * HfreqMin-HfreqMax: Minimum and maximum horizontal frequency, in Hz. Defines the range of horizontal frequencies the monitor is capable to sync.
; The higher the horizontal frequency, the higher the vertical resolution available for the same vertical refresh.
; The higher the horizontal frequency, the higher the vertical refresh available for the same vertical resolution.
; The higher the horizontal frequency, the lower the horizontal amplitude of active video (narrower picture).
; * VFreqMin-VfreqMax: Minimum and maximum vertical frequency, in Hz, Defines the range of vertical frequencies the monitor is capable to sync.
; * HFrontPorch, HSyncPulse, HBackPorch: Horizontal timing and geometry, values in µs
; * VfrontPorch, VSyncPulse, VBackPorch: Vertical timing and geometry, values in ms
; * HSyncPol,VSyncPol: polarities, not in use! defaults to negative.
; * ActiveLinesLimit: Vertical resolutions until ActiveLinesLimit value included, are generated as progressive, regardless the possibility
;                           of obtaining the required vertical refresh value.
; * VirtualLinesLimit: Vertical resolutions above ActiveLinesLimit and below VirtualLinesLimit are virtualized, that is, an interlaced resolution
;                            bigger that the native one is generated, with the right refresh, and "hardware stretch" is applied.
;                            Vertical resolutions above VirtulaLinesLimit are generated as interlaced, without any stretching.
monitor_specs0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 400
; Tolerance for horizontal frequency, in kHz, enables extending the range defined by [ HfreqMin, HfreqMax ]
; The resulting allowed frequency range will be [ HfreqMin - HfreqTolerance, HfreqMax + HfreqTolerance ]
HfreqTolerance = 0.010
; 3. MODELINE GENERATOR
; Total number of modelines to generate. Here are the recommended values for each driver version:
; CRT_Emudriver, based on Catalyst 6.5: 160 modes (accepts up to 200, but above 160 HyperSpin will refuse to load)
; CRT_Emudriver, based on Catalyst 9.3: 120 modes (accepts some more but above 120 you can get some blue screens)
; Regular Catalyst                    : 60 modes (won't accept any more)
TotalModes = 120
; If enabled, only creates modes with 32 bits per pixel color depth
Only32BPPModes = 0
; Method for mode table generation. If Mame xml is processed, that will create a lot of different video modes, so the mode table
; will be optimized keeping the most relevant ones, and dropping the rest, to keep below the TotalModes value.
; 0 = Static table: modelines are generated keeping their original vertical refresh. This method is intended to be used in
;     combination with ini files for each game.
; 1 = Dynamic table: a table of dummy modes is created using xres and yres values while ignoring vfreq. This method is intended
;     to be used in combination with Switchres or Groovymame. No ini files are required using this method (you should disable the
;     GenerateInis option).
; 2 = Magic table: a table of 'magic resolutions' is created, by ignoring xres and vfreq and just keeping yres. This method greatly reduces
;     the total number of modes in the list. It's only supported by GroovyMAME, and is intended as a workaround for the Hyperspin issue.
ModeTableMethod_Custom = 0
ModeTableMethod_XML = 1
; Minimum resolution values (these will be used instead of lower values)
XresMin_XML = 240
YresMin_XML = 224
YresRound_XML = 4
XresMin_Custom = 240
YresMin_Custom = 160
YresRound_Custom = 0
; Minimum dotclock value allowed by the video card, in MHz (i.e. DotClockMin = 7.010)
DotClockMin = 0
; Number of iterations used by the mode generator [0,5]. The higher the number of iterations, the bigger the accuracy of the vertical
; refreshed obtained, normally at the cost of increasing the horizontal frequency strictly required.
Iterations = 0
; Specifies if the refresh label is multiplied by 10 before rounding (experimental).
VFreqLabelx10 = 0
; 4. DRIVER
; Display name to use as target
DisplayName = "\\.\DISPLAY1"
; Path for the driver folder
DriverPath = ".\Driver\"
; If UpdateRegistry is enabled, UpdateDriver will only work if the driver version found in DriverPath matches the one installed
; in the system.
UpdateRegistry = 1 ; Specifies if the video card registry section will be updated with the new video modes
; (will only work in combination with CRT_EMUDriver).
UpdateDriver = 0 ; Specifies if the driver files in DriverPath will be updated with the new video modes, for
; future installations.
AnyCatalyst = 0 ; Allows modelines to be installed for any Catalyst version. This option is experimental and
; known to produce some problems.
Calamity
  • Moderator
  • Last login:September 28, 2026, 10:32:04 am
  • Quote me with care
« Reply #2 on: August 18, 2015, 12:31:15 pm »
Your trying to use super resolutions but haven't created them beforehand. Read the instructions in resllist-super.txt  and use vmmaker with admin rights.
Steps to create a log:
xga
« Reply #3 on: August 18, 2015, 06:07:40 pm »
Many thanks for your reply, Calamity.
I'm fairly certain that I followed the instructions in resllist-super.txt the first time, but have run them again.
I had deleted the original "ReslList.txt" file and then renamed "resllist-super.txt" to "ReslList.txt".
You can see that my VMMaker.ini file (shown in my first post above) has the correct settings of :
ListFromXML = 0
GenerateXML = 0
I have VMMaker set to run as admin, but launched it manually as admin anyway.  Here is the output I receive on screen :
Code: [Select]
:: VideoModeMaker :: - version 1.4 - by Calamity - 2008/2014
ATI Mobility Radeon HD 4300 Series \\.\DISPLAY1 connected\Registry\Machine\Syste
ATI Mobility Radeon HD 4300 Series \\.\DISPLAY2 disconnected\Registry\Machine\Sy
stem\CurrentControlSet\Control\Video\{36359DFE-17E4-4A5E-8C90-DE36639ADC1F}\0001
RDPDD Chained DD \\.\DISPLAYV1 disconnected\Registry\Machine\System\CurrentContr
olSet\Control\Video\{DEB039CC-B704-4F53-B43E-9DD4432FA2E9}\0000
RDP Encoder Mirror Driver \\.\DISPLAYV2 disconnected\Registry\Machine\System\Cur
rentControlSet\Control\Video\{42cf9257-1d96-4c9d-87f3-0d8e74595f78}\0000
RDP Reflector Display Driver \\.\DISPLAYV3 disconnected\Registry\Machine\System\
CurrentControlSet\Control\Video\{b043b95c-5670-4f10-b934-8ed0c8eb59a8}\0000
CRT_EmuDriver 1.2 found! Based on Catalyst 13.1
 31 different video modes found.
Generating dynamic mode table... 12 redundant video modes found.
Reducing mode list... 0 video modes dropped.
 19 modelines generated.
Storing modelines in system registry...
System must be restarted for the changes to take effect.
Finished. Press any key...
Reboot Windows.  Confirmed that mame.ini has the following entries :
resolution 2560x0
cleanstretch 2
Launch Groovymame and still receive the same error messages / results.  :'(
Any other ideas on what I might have done wrong?
Calamity
  • Moderator
« Reply #4 on: August 18, 2015, 06:10:53 pm »
Post log.
xga
« Reply #5 on: August 18, 2015, 06:18:57 pm »
In case it helps with troubleshooting, here's the contents of my ModeInfo.txt, Modeline.txt, ModeList.txt and RegMdlns.txt files.  These are the only files that I can see that updated when I re-ran VMMaker.exe again.
ModeInfo.txt :
Code: [Select]
Modeline "640x480_60 15.62KHz 59.95Hz" 12.980 640 664 728 832 480 482 487 521 interlace -hsync -vsync
Vfreq = 59.950470 Hz
Hfreq = 15,617.10 kHz
DotClock = 12,993,425
                (h)µs  ch          (v)µs  ln
Total video 64.03 104 16680.44 521
Active video 49.26  80 15367.77 480
Front porch 1.85   3    64.03   2
Sync pulse 4.93   8   160.08   5
Back porch 8.00  13 2177.10  34
Total blanking 14.78  24 1312.66  41
____________________________________________________________________________________________
Modeline "664x496_59 15.91KHz 59.04Hz" 13.860 664 696 760 872 496 499 504 539 interlace -hsync -vsync
Vfreq = 59.040043 Hz
Hfreq = 15,911.29 kHz
DotClock = 13,874,647
                (h)µs  ch          (v)µs  ln
Total video 62.85 109 16937.66 539
Active video 47.86  83 15586.41 496
Front porch 2.31   4    94.27   3
Sync pulse 4.61   8   157.12   5
Back porch 8.07  14 2199.70  35
Total blanking 14.99  26 1351.24  43
Modeline "664x496_60 16.18KHz 60.06Hz" 14.090 664 696 760 872 496 499 504 539 interlace -hsync -vsync
Vfreq = 60.055477 Hz
Hfreq = 16,184.95 kHz
DotClock = 14,113,277
                (h)µs  ch          (v)µs  ln
Total video 61.79 109 16651.27 539
Active video 47.05  83 15322.88 496
Front porch 2.27   4    92.68   3
Sync pulse 4.53   8   154.46   5
Back porch 7.94  14 2162.50  35
Total blanking 14.74  26 1328.39  43
Modeline "728x544_54 15.85KHz 54.02Hz" 15.110 728 760 832 952 544 547 552 587 interlace -hsync -vsync
Vfreq = 54.018322 Hz
Hfreq = 15,854.38 kHz
DotClock = 15,093,367
                (h)µs  ch          (v)µs  ln
Total video 63.07 119 18512.24 587
Active video 48.23  91 17156.15 544
Front porch 2.12   4    94.61   3
Sync pulse 4.77   9   157.69   5
Back porch 7.95  15 2207.59  35
Total blanking 14.84  28 1356.09  43
Modeline "2560x240_60 15.66KHz 60.00Hz" 52.120 2560 2664 2912 3328 240 242 245 261 -hsync -vsync
Vfreq = 60.004051 Hz
Hfreq = 15,661.06 kHz
DotClock = 52,120,000
                (h)µs  ch          (v)µs  ln
Total video 63.85 416 16665.54 261
Active video 49.12 320 15324.64 240
Front porch 2.00  13   127.71   2
Sync pulse 4.76  31   191.56   3
Back porch 7.98  52 1021.64  16
Total blanking 14.74  96 1340.91  21
Modeline "2560x248_60 16.14KHz 60.00Hz" 54.230 2560 2672 2928 3360 248 250 253 269 -hsync -vsync
Vfreq = 59.999557 Hz
Hfreq = 16,139.88 kHz
DotClock = 54,230,000
                (h)µs  ch          (v)µs  ln
Total video 61.96 420 16666.79 269
Active video 47.21 320 15365.66 248
Front porch 2.07  14   123.92   2
Sync pulse 4.72  32   185.87   3
Back porch 7.97  54   991.33  16
Total blanking 14.75 100 1301.12  21
Modeline "2560x256_58 16.20KHz 58.48Hz" 54.430 2560 2672 2928 3360 256 258 261 277 -hsync -vsync
Vfreq = 58.481606 Hz
Hfreq = 16,199.40 kHz
DotClock = 54,430,000
                (h)µs  ch          (v)µs  ln
Total video 61.73 420 17099.39 277
Active video 47.03 320 15803.05 256
Front porch 2.06  14   123.46   2
Sync pulse 4.70  32   185.19   3
Back porch 7.94  54   987.69  16
Total blanking 14.70 100 1296.34  21
Modeline "2560x264_57 16.20KHz 56.84Hz" 54.430 2560 2672 2928 3360 264 266 269 285 -hsync -vsync
Vfreq = 56.840015 Hz
                (h)µs  ch          (v)µs  ln
Total video 61.73 420 17593.24 285
Active video 47.03 320 16296.90 264
Modeline "2560x272_55 16.20KHz 55.29Hz" 54.430 2560 2672 2928 3360 272 274 277 293 -hsync -vsync
Vfreq = 55.288071 Hz
                (h)µs  ch          (v)µs  ln
Total video 61.73 420 18087.08 293
Active video 47.03 320 16790.74 272
Modeline "2560x280_54 16.20KHz 53.82Hz" 54.430 2560 2672 2928 3360 280 282 285 301 -hsync -vsync
Vfreq = 53.818619 Hz
                (h)µs  ch          (v)µs  ln
Total video 61.73 420 18580.93 301
Active video 47.03 320 17284.59 280
Modeline "2560x288_52 16.20KHz 52.43Hz" 54.430 2560 2672 2928 3360 288 290 293 309 -hsync -vsync
Vfreq = 52.425255 Hz
                (h)µs  ch          (v)µs  ln
Total video 61.73 420 19074.77 309
Active video 47.03 320 17778.43 288
Modeline "2560x400_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 400 442 447 521 interlace -hsync -vsync
Vfreq = 59.998154 Hz
Hfreq = 15,629.52 kHz
DotClock = 51,890,000
                (h)µs  ch          (v)µs  ln
Total video 63.98 415 16667.18 521
Active video 49.34 320 12796.30 400
Front porch 2.00  13 1343.61  42
Sync pulse 4.63  30   159.95   5
Back porch 8.02  52 4734.63  74
Total blanking 14.65  95 3870.88 121
Modeline "2560x416_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 416 450 455 521 interlace -hsync -vsync
                (h)µs  ch          (v)µs  ln
Active video 49.34 320 13308.15 416
Front porch 2.00  13 1087.69  34
Back porch 8.02  52 4222.78  66
Total blanking 14.65  95 3359.03 105
Modeline "2560x432_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 432 458 463 521 interlace -hsync -vsync
                (h)µs  ch          (v)µs  ln
Active video 49.34 320 13820.00 432
Front porch 2.00  13   831.76  26
Back porch 8.02  52 3710.93  58
Total blanking 14.65  95 2847.18  89
Modeline "2560x448_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 448 466 471 521 interlace -hsync -vsync
                (h)µs  ch          (v)µs  ln
Active video 49.34 320 14331.86 448
Front porch 2.00  13   575.83  18
Back porch 8.02  52 3199.07  50
Total blanking 14.65  95 2335.32  73
Modeline "2560x464_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 464 474 479 521 interlace -hsync -vsync
                (h)µs  ch          (v)µs  ln
Active video 49.34 320 14843.71 464
Front porch 2.00  13   319.91  10
Back porch 8.02  52 2687.22  42
Total blanking 14.65  95 1823.47  57
Modeline "2560x480_60 15.63KHz 60.00Hz" 51.890 2560 2664 2904 3320 480 482 487 521 interlace -hsync -vsync
                (h)µs  ch          (v)µs  ln
Active video 49.34 320 15355.56 480
Front porch 2.00  13    63.98   2
Back porch 8.02  52 2175.37  34
Total blanking 14.65  95 1311.62  41
Modeline "2560x496_60 16.17KHz 60.00Hz" 54.330 2560 2672 2928 3360 496 499 504 539 interlace -hsync -vsync
Vfreq = 59.998672 Hz
Hfreq = 16,169.64 kHz
DotClock = 54,330,000
                (h)µs  ch          (v)µs  ln
Total video 61.84 420 16667.04 539
Active video 47.12 320 15337.38 496
Front porch 2.06  14    92.77   3
Sync pulse 4.71  32   154.61   5
Back porch 7.95  54 2164.55  35
Total blanking 14.72 100 1329.65  43
Modeline "2560x544_55 16.14KHz 55.00Hz" 54.240 2560 2672 2928 3360 544 547 552 587 interlace -hsync -vsync
Vfreq = 55.001217 Hz
Hfreq = 16,142.86 kHz
DotClock = 54,240,000
                (h)µs  ch          (v)µs  ln
Total video 61.95 420 18181.42 587
Active video 47.20 320 16849.56 544
Front porch 2.06  14    92.92   3
Sync pulse 4.72  32   154.87   5
Back porch 7.96  54 2168.14  35
Total blanking 14.75 100 1331.86  43
xga
« Reply #6 on: August 18, 2015, 06:20:40 pm »
Modeline.txt :
Code: [Select]
ModeList.txt :
Code: [Select]
[idx] Resolution Request   [roms] System Name            Result    [idx] Mode Label     rng[Vfreq Hz  Vfreq diff.  Hz][roms] System Names
[  1] 640 x 480 @ 60.000000[0001][desktop]...............R:in/V:OK [  1] 640 x 480 @ 60 [0][59.950470 d= -0.049530 Hz][0001]/[desktop]
[  2]2560 x 240 @ 60.000000[0001][super].................R:OK/V:OK [  2]2560 x 240 @ 60 [0][60.004051 d= +0.004051 Hz][0001]/[super]
[  3]2560 x 248 @ 60.000000[0001][super].................R:OK/V:OK [  3]2560 x 248 @ 60 [0][59.999557 d= -0.000443 Hz][0001]/[super]
[  4]2560 x 256 @ 60.000000[0001][super].................R:OK/V:-- [  4]2560 x 256 @ 58 [0][58.481606 d= -1.518394 Hz][0001]/[super]
[  5]2560 x 264 @ 60.000000[0001][super].................R:OK/V:-- [  5]2560 x 264 @ 57 [0][56.840015 d= -3.159985 Hz][0001]/[super]
[  6]2560 x 272 @ 60.000000[0001][super].................R:OK/V:-- [  6]2560 x 272 @ 55 [0][55.288071 d= -4.711929 Hz][0001]/[super]
[  7]2560 x 280 @ 60.000000[0001][super].................R:OK/V:-- [  7]2560 x 280 @ 54 [0][53.818619 d= -6.181381 Hz][0001]/[super]
[  8]2560 x 288 @ 60.000000[0001][super].................R:OK/V:-- [  8]2560 x 288 @ 52 [0][52.425255 d= -7.574745 Hz][0001]/[super]
[  9]2560 x 296 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 10]2560 x 304 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 11]2560 x 320 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 12]2560 x 336 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 13]2560 x 344 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 14]2560 x 352 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 15]2560 x 360 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 16]2560 x 368 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 17]2560 x 376 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 18]2560 x 384 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 19]2560 x 392 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 20]2560 x 400 @ 60.000000[0001][super].................R:in/V:OK [ 20]2560 x 400 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 21]2560 x 416 @ 60.000000[0001][super].................R:in/V:OK [ 21]2560 x 416 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 22]2560 x 432 @ 60.000000[0001][super].................R:in/V:OK [ 22]2560 x 432 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 23]2560 x 448 @ 60.000000[0001][super].................R:in/V:OK [ 23]2560 x 448 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 24]2560 x 464 @ 60.000000[0001][super].................R:in/V:OK [ 24]2560 x 464 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 25]2560 x 480 @ 60.000000[0001][super].................R:in/V:OK [ 25]2560 x 480 @ 60 [0][59.998154 d= -0.001846 Hz][0001]/[super]
[ 26]2560 x 496 @ 60.000000[0001][super].................R:in/V:OK [ 26]2560 x 496 @ 60 [0][59.998672 d= -0.001328 Hz][0001]/[super]
[ 27]2560 x 512 @ 59.000000[0001][super].................R:vi/V:OK [ 27] 664 x 496 @ 59 [0][59.040043 d= +0.040043 Hz][0001]/[super]
[ 28]2560 x 544 @ 55.000000[0001][super].................R:in/V:OK [ 28]2560 x 544 @ 55 [0][55.001217 d= +0.001217 Hz][0001]/[super]
[ 29]2560 x 560 @ 54.000000[0001][super].................R:vi/V:OK [ 29] 728 x 544 @ 54 [0][54.018322 d= +0.018322 Hz][0001]/[super]
[ 30]2560 x 768 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
[ 31]2560 x 800 @ 60.000000[0001][super].................R:vi/V:OK [  9] 664 x 496 @ 60 [0][60.055477 d= +0.055477 Hz][0013]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]/[super]
RegMdlns.txt :
Code: [Select]
HKR,, DALDTMCRTBCD640x480x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,08,32,00,00,06,40,00,00,06,64,00,00,00,64,00,00,05,21,00,00,04,80,00,00,04,82,00,00,\
00,05,00,00,12,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,EC,77
HKR,, DALR6 CRT640x480x0x60, %REG_BINARY%,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,01,00,00,00,00,00,00,00
HKR,, DALDTMCRTBCD664x496x0x59, %REG_BINARY%,\
00,00,00,0E,00,00,08,72,00,00,06,64,00,00,06,96,00,00,00,64,00,00,05,39,00,00,04,96,00,00,04,99,00,00,\
00,05,00,00,13,86,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,EB,8C
HKR,, DALR6 CRT664x496x0x59, %REG_BINARY%,\
HKR,, DALDTMCRTBCD664x496x0x60, %REG_BINARY%,\
00,05,00,00,14,09,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,EB,75
HKR,, DALR6 CRT664x496x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD728x544x0x54, %REG_BINARY%,\
00,00,00,0E,00,00,09,52,00,00,07,28,00,00,07,60,00,00,00,72,00,00,05,87,00,00,05,44,00,00,05,47,00,00,\
00,05,00,00,15,11,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,E9,A7
HKR,, DALR6 CRT728x544x0x54, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x240x0x60, %REG_BINARY%,\
00,00,00,0C,00,00,33,28,00,00,25,60,00,00,26,64,00,00,02,48,00,00,02,61,00,00,02,40,00,00,02,42,00,00,\
00,03,00,00,52,12,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C6,4D
HKR,, DALR6 CRT2560x240x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x248x0x60, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,02,69,00,00,02,48,00,00,02,50,00,00,\
00,03,00,00,54,23,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C5,32
HKR,, DALR6 CRT2560x248x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x256x0x58, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,02,77,00,00,02,56,00,00,02,58,00,00,\
00,03,00,00,54,43,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C5,06
HKR,, DALR6 CRT2560x256x0x58, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x264x0x57, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,02,85,00,00,02,64,00,00,02,66,00,00,\
00,03,00,00,54,43,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C4,EE
HKR,, DALR6 CRT2560x264x0x57, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x272x0x55, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,02,93,00,00,02,72,00,00,02,74,00,00,\
00,03,00,00,54,43,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C4,D6
HKR,, DALR6 CRT2560x272x0x55, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x280x0x54, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,03,01,00,00,02,80,00,00,02,82,00,00,\
00,03,00,00,54,43,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C4,BE
HKR,, DALR6 CRT2560x280x0x54, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x288x0x52, %REG_BINARY%,\
00,00,00,0C,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,03,09,00,00,02,88,00,00,02,90,00,00,\
00,03,00,00,54,43,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C4,A6
HKR,, DALR6 CRT2560x288x0x52, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x400x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,00,00,00,04,42,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C4,04
HKR,, DALR6 CRT2560x400x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x416x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,16,00,00,04,50,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C3,EC
HKR,, DALR6 CRT2560x416x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x432x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,32,00,00,04,58,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C3,D4
HKR,, DALR6 CRT2560x432x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x448x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,48,00,00,04,66,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C3,BC
HKR,, DALR6 CRT2560x448x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x464x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,64,00,00,04,74,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C3,A4
HKR,, DALR6 CRT2560x464x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x480x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,20,00,00,25,60,00,00,26,64,00,00,02,40,00,00,05,21,00,00,04,80,00,00,04,82,00,00,\
00,05,00,00,51,89,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C3,8C
HKR,, DALR6 CRT2560x480x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x496x0x60, %REG_BINARY%,\
00,00,00,0E,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,05,39,00,00,04,96,00,00,04,99,00,00,\
00,05,00,00,54,33,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C2,25
HKR,, DALR6 CRT2560x496x0x60, %REG_BINARY%,\
HKR,, DALDTMCRTBCD2560x544x0x55, %REG_BINARY%,\
00,00,00,0E,00,00,33,60,00,00,25,60,00,00,26,72,00,00,02,56,00,00,05,87,00,00,05,44,00,00,05,47,00,00,\
00,05,00,00,54,24,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,C1,9E
HKR,, DALR6 CRT2560x544x0x55, %REG_BINARY%,\
HKR,, DALNonStandardModesBCD, %REG_BINARY%,\
06,40,04,80,00,00,00,60,06,64,04,96,00,00,00,59,06,64,04,96,00,00,00,60,07,28,05,44,00,00,00,54,\
25,60,02,40,00,00,00,60,25,60,02,48,00,00,00,60,25,60,02,56,00,00,00,58,25,60,02,64,00,00,00,57,\
25,60,02,72,00,00,00,55,25,60,02,80,00,00,00,54,25,60,02,88,00,00,00,52,25,60,04,00,00,00,00,60,\
25,60,04,16,00,00,00,60,25,60,04,32,00,00,00,60,25,60,04,48,00,00,00,60,25,60,04,64,00,00,00,60,\
25,60,04,80,00,00,00,60,25,60,04,96,00,00,00,60,25,60,05,44,00,00,00,55
HKR,, DALRestrictedModesBCD, %REG_BINARY%,\
03,20,02,00,00,00,00,00,03,20,02,40,00,00,00,00,04,00,03,00,00,00,00,00,05,12,03,84,00,00,00,00,\
06,40,04,00,00,00,00,00,08,00,06,00,00,00,00,00,10,24,07,68,00,00,00,00,11,52,08,64,00,00,00,00,\
12,80,10,24,00,00,00,00,16,00,12,00,00,00,00,00,17,92,13,44,00,00,00,00,18,00,14,40,00,00,00,00,\
19,20,10,80,00,00,00,00,19,20,12,00,00,00,00,00,19,20,14,40,00,00,00,00,20,48,15,36,00,00,00,00
Calamity
  • Moderator
« Reply #7 on: August 18, 2015, 06:21:09 pm »
It's just a log what I need, I wish everyone posted their logs.
xga
« Reply #8 on: August 18, 2015, 06:25:31 pm »
Really sorry, Calamity.  I thought that  I had included the log in my first post for Double Dragon (mame64.exe roms\ddragon.zip -v > ddragon.txt .  I've attached to this post just in case.  If there's some other way that I should be generating logs, please let me know.  Thanks.
« Last Edit: August 18, 2015, 06:33:54 pm by xga »
Calamity
  • Moderator
« Reply #9 on: August 18, 2015, 06:27:15 pm »
Hi xga, I don't think that's the NEW log after you run vmmaker.
xga
« Reply #10 on: August 18, 2015, 06:30:56 pm »
Arrgghhh.  My bad.  Sorry!  Here is the new version that I just ran.
Code: [Select]
Switchres: [  1]  640x 480 @ 60 : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.60KHz 59.88Hz" 12.98 640 664 728 832 480 482 487 521 interlace  -hsync -vsync
Switchres: [  2]  664x 496 @ 60 : DALDTMCRTBCD664x496x0x60 - Modeline "664x496_60 16.16KHz 59.96Hz" 14.09 664 696 760 872 496 499 504 539 interlace  -hsync -vsync
Switchres: [  3]  720x 480 @ 60 : system mode
mode_locked
Switchres: [  4]  800x 600 @ 60 : system mode
mode_locked
Switchres: [  5] 1024x 768 @ 60* : system mode
Switchres: [  6] 1280x 720 @ 60 : system mode
mode_locked
Switchres: [  7] 1366x 768 @ 60 : system mode
mode_locked
SwitchRes: Found 2 custom of 7 active video modes
Video: Monitor 00000000003A7A68 = "\\.\DISPLAY1" (primary)
blit_lock = TRUE
blit_unlock = TRUE
blit_lock = FALSE
Average speed: 100.01% (9 seconds)
blit_lock = TRUE
blit_lock = TRUE
Calamity
  • Moderator
« Reply #11 on: August 18, 2015, 06:45:04 pm »
The super resolutions are not showing. It looks like this might be an issue of running from a laptop where the resolutions not supported by the main screen are filtered out. Try replacing the 2560x modes in resllist.txt by 1280x. If it works, try using 1600x instead. Modify the -resolution option in mame.ini accordingly.
xga
« Reply #12 on: August 18, 2015, 06:48:51 pm »
Thanks Calamity.  I will try that now and report back.  Is it odd that Arcade_OSD seems to work fine on the laptop screen though?  I can choose a number of different 15KHz resolutions and they all appear to display properly.
xga
« Reply #13 on: August 18, 2015, 07:04:36 pm »
Ok.
Modified all 2560 entries in resllist.txt to 1280.
Re-ran VMMaker.exe.
Rebooted.
Modified mame.ini to resolution  1280x0.
Now when I start Groovymame, I receive the error message "Unable to create ddraw object" and clicking "Ok" kills Groovymame and takes me back to the desktop.
Running mame64.exe roms\ddrgaon.zip -v > ddragon.txt actually starts the Double Dragon rom, but the resolution is very squashed (think short and full width of the screen), it's playing at 104% and the sound is off / running faster / higher than normal.
Here's the log.
Code: [Select]
mode_locked
mode_locked
Switchres: [  6] 1280x 240 @ 60 : DALDTMCRTBCD1280x240x0x60 - Modeline "1280x240_60 15.66KHz 59.99Hz" 25.93 1280 1328 1448 1656 240 242 245 261   -hsync -vsync
Switchres: [  7] 1280x 248 @ 60 : DALDTMCRTBCD1280x248x0x60 - Modeline "1280x248_60 16.14KHz 60.01Hz" 27.12 1280 1336 1464 1680 248 250 253 269   -hsync -vsync
Switchres: [  8] 1280x 400 @ 60 : DALDTMCRTBCD1280x400x0x60 - Modeline "1280x400_60 15.63KHz 59.99Hz" 25.88 1280 1328 1448 1656 400 442 447 521 interlace  -hsync -vsync
Switchres: [  9] 1280x 416 @ 60 : DALDTMCRTBCD1280x416x0x60 - Modeline "1280x416_60 15.63KHz 59.99Hz" 25.88 1280 1328 1448 1656 416 450 455 521 interlace  -hsync -vsync
Switchres: [ 10] 1280x 432 @ 60 : DALDTMCRTBCD1280x432x0x60 - Modeline "1280x432_60 15.63KHz 59.99Hz" 25.88 1280 1328 1448 1656 432 458 463 521 interlace  -hsync -vsync
Switchres: [ 11] 1280x 448 @ 60 : DALDTMCRTBCD1280x448x0x60 - Modeline "1280x448_60 15.63KHz 59.99Hz" 25.88 1280 1328 1448 1656 448 466 471 521 interlace  -hsync -vsync
Switchres: [ 12] 1280x 464 @ 60 : DALDTMCRTBCD1280x464x0x60 - Modeline "1280x464_60 15.63KHz 59.99Hz" 25.88 1280 1328 1448 1656 464 474 479 521 interlace  -hsync -vsync
Switchres: [ 13] 1280x 480 @ 60 : DALDTMCRTBCD1280x480x0x60 - Modeline "1280x480_60 15.78KHz 60.56Hz" 26.25 1280 1336 1456 1664 480 482 488 521 interlace  -hsync -vsync
Switchres: [ 14] 1280x 496 @ 60 : DALDTMCRTBCD1280x496x0x60 - Modeline "1280x496_60 16.17KHz 60.01Hz" 27.17 1280 1336 1464 1680 496 499 504 539 interlace  -hsync -vsync
Switchres: [ 15] 1280x 720 @ 60 : system mode
mode_locked
Switchres: [ 16] 1366x 768 @ 60 : system mode
mode_locked
SwitchRes: Found 11 custom of 16 active video modes
SwitchRes: -resolution was forced as 1280x0
   rng(0): 1280 x 240_57.445p 15.625 [integ] scale(5, 1, 1) diff(0.00, 0.00, 0.0000) ratio(5.000, 1.000)
SwitchRes: [1280]x[ 248]_(60=60.0074Hz)
   rng(0): 1280 x 248_57.445p 15.625 [integ] scale(5, 1, 1) diff(0.00, 0.00, 0.0000) ratio(5.000, 1.033)
SwitchRes: [1280]x[ 400]_(60=59.9923Hz)
   rng(0):  out of range
SwitchRes: [1280]x[ 416]_(60=59.9923Hz)
SwitchRes: [1280]x[ 432]_(60=59.9923Hz)
SwitchRes: [1280]x[ 448]_(60=59.9923Hz)
   rng(0): 1280 x 448_57.445i 15.654 [fract] scale(5, 1, 1) diff(0.00, 76.47, 0.0000) ratio(5.000, 1.867)
SwitchRes: [1280]x[ 464]_(60=59.9923Hz)
   rng(0): 1280 x 464_57.445i 15.654 [fract] scale(5, 1, 1) diff(0.00, 76.47, 0.0000) ratio(5.000, 1.933)
SwitchRes: [1280]x[ 480]_(60=60.5566Hz)
   rng(0): 1280 x 480_57.445i 15.654 [integ] scale(5, 2, 1) diff(0.00, 0.00, 0.0000) ratio(5.000, 2.000)
SwitchRes: [1280]x[ 496]_(60=60.0074Hz)
   rng(0): 1280 x 496_57.445i 15.654 [integ] scale(5, 2, 1) diff(0.00, 0.00, 0.0000) ratio(5.000, 2.067)
SwitchRes: [roms\ddragon.zip] (1) horizontal (256x240@57.44)->(1280x240@57.44)
SwitchRes: Modeline "1280x240_60 15.63KHz 57.44Hz" 25.88 1280 1328 1448 1656 240 247 250 272   -hsync -vsync
Switchres: saving    DALDTMCRTBCD1280x240x0x60 - Modeline "1280x240_60 15.66KHz 59.99Hz" 25.93 1280 1328 1448 1656 240 242 245 261   -hsync -vsync
Switchres: updating  DALDTMCRTBCD1280x240x0x60 - Modeline "1280x240_60 15.63KHz 57.44Hz" 25.88 1280 1328 1448 1656 240 247 250 272   -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -multithreading
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nohwstretch
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nofilter
SwitchRes: Setting option -prescale 1
Video: Monitor 00000000003DFDE8 = "\\.\DISPLAY1" (primary)
blit_lock = TRUE
Direct3D: Device created at 1280x240
blit_unlock = TRUE
blit_lock = FALSE
Average speed: 103.85% (37 seconds)
Switchres: restoring DALDTMCRTBCD1280x240x0x60 - Modeline "1280x240_60 15.66KHz 59.99Hz" 25.93 1280 1328 1448 1656 240 242 245 261   -hsync -vsync
blit_lock = TRUE
blit_lock = TRUE
xga
« Reply #14 on: August 18, 2015, 07:07:08 pm »
I should add that I've just checked Arcade_OSD and all of the 15KHz resolutions have gone and the lowest resolution I can select now is 640 x 480.
Edit - Actually, if I scroll down the selection, there are some 1280 x 240 resolutions that I can select, but when I select those, they're obviously displaying in 1280 by 240 e.g. short and full width of the screen.
« Last Edit: August 18, 2015, 07:10:48 pm by xga »
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #15 on: August 18, 2015, 10:00:48 pm »
Just an FYI, I've just done a fresh install of win 7 pro and GM .164 as well, and everything is working fine.
But this is with a proper pc and a HD4350..
Calamity
  • Moderator
« Reply #16 on: August 19, 2015, 08:40:45 am »
Hi xga,
Your log shows a single display device available, that's possible the problem. You must see TWO display devices if you're using a laptop. First one is the internal lcd, second one the vga output. You must configure a extended desktop from the display properties dialog to achieve this. Don't use the typical hotkeys or whatever to clone the display through vga because it won't work that way. Then use the -screen \\.\DISPLAY1 or -screen \\.\DISPLAY2 from MAME to point to the right output.
xga
  • Last login:August 01, 2026, 11:01:59 am
« Reply #17 on: August 20, 2015, 07:22:09 pm »
Thanks Calamity.  I wasn't aware of the -screen switch command and had just been using the "fn" + "F4" key to cycle to the VGA connection.
Just as a test (and before your last post), I installed XP (32bit) so I could dual boot between Windows 7 and XP and try and rule out there being an issue with the notebook.  I set up GroovyMAME and CRT_Emudriver in the normal way and got Switchres working without errors, switching to native resolutions and outputting to my 15KHz arcade monitor.  One thing I did notice, Double Dragon was running at 104% (sound was pitched up / running faster) and Shinobi was running at 99%.  Other roms like Final Fight and Street Fighter II were running exactly on 100%.  I've got Multithreading enabled, but not sure what could be causing the speed difference with some roms.  I did take a log of Double Dragon running at 104% but I'm not near the computer to post at the moment.  I wonder if installing XP 64bit would make any difference?
Anyway, I think I have ruled out there being an issue with the  notebook, so I am going to try a fresh install of Windows 7 again and see if I can get it working.
