Author Topic: hiding os on mala start  (Read 1344 times)
kpop
  • Last login:April 24, 2020, 11:30:13 pm
« on: July 11, 2015, 11:40:12 pm »
having trouble figuring this out, ive used instant sheller to hide xp to boot into mala on my bartop,but finding it is stopping xpadder from booting up also, as it stops explorer running which i need to exit from the emulators i have set up,how are you guys working around this?
Jollywest
  • Last login:Today at 05:32:32 am
Re: hiding os on mala start
« Reply #1 on: July 12, 2015, 04:54:57 am »
This should help;
http://forum.arcadecontrols.com/index.php/topic,80737.0.html
MaLa Launcher 1.0 by TheShanMan
kpop
« Reply #2 on: July 12, 2015, 06:26:12 am »
cool looks just like the program i need,do you know if it will work without explorer.exe running?
Jollywest
« Reply #3 on: July 12, 2015, 11:36:22 am »
Do you run MaLa as your windows shell? Do you wish you had a good way to launch background tasks (like CPWizard) when windows boots up, without having to resort to installing a RunAsService type of program? Well here's the answer...
Install this plugin, create a "Launch" subdirectory under Plugins, and put some shortcuts in there. They will be launched when MaLa starts up, just like the start menu's Startup folder does if you have explorer as your shell.
It can be found on the MaLa plugin webpage: http://malafe.net/index.php?page=plugins
Enjoy!
Sounds like it  ;)
kpop
« Reply #4 on: July 15, 2015, 12:31:52 am »
thankyou very much, that did the trick. ;D
