May 14, 2026, 12:25:16 am
Does the screen roll vertically or horizontally?
just curious have u done tests to see what the highest frequency setting (15725-16100) your tv can cope with. the reason I ask is, although sony's are renowned for coping with high scan rates, I had a sony trinitron in the past which was one of the later ones, with a more 'flatter/not so rounded corners' screen, and I found it couldn't cope with scan rates much higher than 16000, so I got rid of it (mind you I don't know if there was something wrong with that tv, or some of my other settings were causing problems, but still -thought I would mention this)
