Author Topic: Strange Behavior From CRT_Emudriver and Win7 64 Pro  (Read 2025 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: July 08, 2015, 12:18:33 am »
Recently installed Win 7 64 and CRT_Emudriver and for the most part things are going sweet! I have noticed a lot of Vert games are not being displayed properly. I am doing a dual boot set up currently with XP64 on a separate drive. Here are logs from XP 64 and Win7 64 for comparison. Everything is being ran on the same HW. Any help would be great. So, far Win7 is promising. Even got MameWah up and running!
My old user name was marlborroman13, but I kicked the habit many years ago!
AMDman13
Re: Strange Behavior From CRT_Emudriver and Win7 64 Pro
« Reply #1 on: July 08, 2015, 12:40:02 am »
Also, it appears that the problem is only intermittent. Here is a long from when it was displayed properly.
Calamity
  • Moderator
  • Last login:June 16, 2026, 03:08:29 pm
  • Quote me with care
« Reply #2 on: July 08, 2015, 04:25:57 am »
I think the intermittent factor there was running GM with/without admin privileges.
(make sure to always use admin privileges so GM can access the registry)
Steps to create a log:
AMDman13
« Reply #3 on: July 08, 2015, 11:04:12 am »
Calamity you nailed it! Thank you. I also set my frontend to run as admin. Problem is solved.
Thanks again!
