Author Topic: Out the Loop For A While. Ideal Setup for CRT Monitor as of July 2015??  (Read 3292 times)
lettuce
  • Make It So!
Ok so i haven't being using GM for its intended purpose (Arcade Monitor) for over 2 years now, i have in the past just being using GM on my main PC and and LCD screen!. I have a dedicated PC for this project that will eventually go in a cab im building, i have...
25" 15khz CRT Arcade Monitor
Radeon HD2400
i3 intel Haswell cpu
J-Pac (to help protect the monitor)
What flavour of GM is recommended atm the Linux based GroovyArcade live-CD method or windows based install?? I kind of like the GroovyArcade live_CD method as it seems to be self contained with its own frontend but not sure if its as well supported as the windows version of GM. Do i need to take any special steps as im going to be ining a J-Pac at all?
adder
I don't think the jpac would cause you any problems but that said I don't use one so not sure on that
perhaps try the live CD first and try lots of games, and see if it works for you
or if you wanted to setup without the live CD, have a look here:
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=290
lettuce
  • Make It So!
Thanks for the link to the guide, the thing putting me off using the GroovyArcade Live CD is that it looks to be fairly old build now, is there not a more recent build?
DoogyRev
  • Last login:July 04, 2019, 08:24:49 am
Try the beta builds.
lettuce
  • Make It So!
whats the url for the beta builds please?
lettuce
  • Make It So!
Which is the better method for creating and switch resolutions?, as isnt it only Windows 7 build of GM that uses Super Resolution method which helps keep all games centre on the monitor??
Calamity
  • Moderator
  • Last login:Today at 01:14:24 pm
  • Quote me with care
You can use super resolutions for any OS supported by GM.
Steps to create a log:
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Windows 7 64-bit and a compatible Radeon (your 2400 isn't) flashed with ATOM-15, using super resolutions and frame delay.
lettuce
  • Make It So!
So the ATOM-15 CFW just allow you to view the bios and boot screen on 15khz monitors??, can a card that has been flashed with ATOM-15 be flash back to its original form?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
As long as you keep a copy of the original BIOS, yes
DoogyRev
