Author Topic: Hitachi GMK-25FS2 service literature ?  (Read 1724 times)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« on: May 13, 2015, 07:21:39 pm »
an Arcade Route op brought this in today- DOA
looking for a schematic as there are a pair of resistors in the SMPS burnt beyond recognition.
startup caps are bad as well. but, of course,  can identify those .
no joy with any search engine .
anyone ??
TIA
MonMotha
Re: Hitachi GMK-25FS2 service literature ?
« Reply #1 on: May 15, 2015, 09:26:31 pm »
These are found on Neo 29 cabinets.  Might get you some more info.
I have an operator's manual which includes some troubleshooting flowcharts and other info, but no schematic.  It's also in Japanese.
Would you like me to scan it in?
I can also get you pictures or measurements off known working units if necessary or if you have stuff burnt beyond recognition.
qrz
« Reply #2 on: May 15, 2015, 09:58:59 pm »
tnx
 but, doubt that the chart will be of any use .   even in Engrish
the startup caps were each several hundred ohms of ESR
the resistors in question are also in the primary side and part of a timing network.
should have posted ref#'s.
will try to so do in a couple of days
MonMotha
« Reply #3 on: May 16, 2015, 01:28:21 am »
Crap, I just noticed you said 25FS2, not 29FS2.
I only have the 29".  I have a friend with the 25" version, though, so I can probably get info, but it may take a while as he's super remote and generally uncomfortable with working on monitors.
Of course, if it's similar to the 29", what I have may be useful enough.  Probably not the case for the timing section, though :\
qrz
« Reply #4 on: May 18, 2015, 05:00:49 pm »
the reference numbers to ID are
R905 and
R906
edit:
customer brought in a working unit.
of course, same resistors burnt.  :badmood:
measured as
R905   4.7 ohm .5W
R906   15 ohm .5W
replaced both with a 1 Watt of same resistances, along with
C902  4.7uF/160 V  replaced w/10uF/250V   105 degree
C906  2.2uF/160 V  replaced w/2.2uF/200V  105 degree
works fine now   ;D
« Last Edit: May 20, 2015, 02:42:33 pm by qrz »
