Author Topic: Ikea Scrap MDF  (Read 8166 times)
CanadianRyGuy
  • Last login:April 02, 2021, 07:41:53 am
Ikea Scrap MDF
« on: May 12, 2015, 09:34:44 pm »
Has anyone thought to look at Ikea's scratch and dent area for cheap MDF wood. Any reasons why this might be a bad idea?
JDFan
Re: Ikea Scrap MDF
« Reply #1 on: May 12, 2015, 11:41:37 pm »
Most of the IKEA stuff that I've seen are Particle board rather than MDF and even the scratch and dent stuff usually costs more than a sheet of MDF from the local Hardware stores (never hurts to look though  - also check the miscut wood section of the hardware store.)
dmckean
  • Last login:September 18, 2026, 10:10:04 pm
Re: Ikea Scrap MDF
« Reply #2 on: May 20, 2015, 05:40:32 pm »
A lot of it is not even particle board and instead some sort of constrained layer construction with lots of air gaps to keep weight down.
Homietheclown
  • Last login:April 01, 2016, 10:28:15 am
Re: Ikea Scrap MDF
« Reply #3 on: May 21, 2015, 11:32:12 pm »
I've done this at Home Depot before. I've gotten quite a few pieces of wood cheap. 70% off.
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
Re: Ikea Scrap MDF
« Reply #4 on: May 23, 2015, 10:10:14 am »
You can price match at Home Depot for MDF and also have them pre cut it into more manageable sides. I price matched some 4 x 8 x 3/4 for $30-32 CAD.
CanadianRyGuy
Re: Ikea Scrap MDF
« Reply #5 on: May 24, 2015, 08:15:00 pm »
Do they charge for cuts? Where did you price match from/Where should I look for better prices? Rona/Home Hardware/Others?
JDFan
Re: Ikea Scrap MDF
« Reply #6 on: May 25, 2015, 10:06:14 am »
IIRC Home Depot will do 2 cuts per panel free and then charge $0.10 or $0.20 per cut after that - and will only do straight cuts through the panel (ie. cutting the 4x8 panel into 2 4x4 or 2 2x4 and 1 4x4 etc.) - no diagonal or partial cuts (ie. cutting one 2x2 corner section out of the 4x8 - though you can get that by doing a 2x4 cut and then cutting that into 2 2x2 pieces) - so best to figure out the layout first and then have them do the cuts they will do and then do the rest at home.
eds1275
  • Last login:September 23, 2026, 09:21:31 am
  • Rock and Roll!
Re: Ikea Scrap MDF
« Reply #7 on: June 05, 2015, 12:13:34 pm »
MDF is cheap to begin with.
Suilenrocc
  • Last login:January 03, 2016, 06:33:53 pm
Re: Ikea Scrap MDF
« Reply #8 on: September 02, 2015, 10:16:49 pm »
My vote is for new MDF... I wouldn't think leftover Ikea furniture would hold up well.  I'd choose MDF over plywood too, despite it being heavier, less prone to warp.
EvilNuff
Re: Ikea Scrap MDF
« Reply #9 on: September 03, 2015, 11:22:43 am »
The Ikea stuff isn't really MDF.  It is usually hollow particle board filled with cardboard.
