Author Topic: Groovymame 160 Direct Draw help  (Read 2538 times)
Giddygoon
  • Last login:March 22, 2022, 04:13:04 am
« on: April 10, 2015, 10:42:18 am »
Hi All,
I have been using GMs since 154 which I use in a Naomi Net City running on a 31khz monitor...... no probs until the recent update
I missed an upgrade of two, so I went from GM 157 to 160
My GM ini file had ddraw selected and had always worked great, but now I get a blank screen with the game sound running in the back ground. If i change the new GM ini file to Auto then I have game graphics in full screen....
So is ddraw dead or broken?
I was never a fan of Direct3d before because the games looked a little to blocky on 31khz monitor
So what to do, I have read a lot about this OpenGL thing but I dont think that has anything to do with this problem
I know i'm supposed to attach a log but I was wondering what would be the best basic settings from here on
I have a Nanao 2932 31khz
ATI 1650 Graphics card
Intel Core2 3.ghz
GM 160
latest VMaker
Thanks for any help
« Last Edit: April 10, 2015, 10:43:56 am by Giddygoon »
Calamity
  • Moderator
  • Last login:July 19, 2025, 04:03:33 am
  • Quote me with care
Re: Groovymame 160 Direct Draw help
« Reply #1 on: April 10, 2015, 11:33:16 am »
Hi Giddygoon,
The same settings should work, -video ddraw works fine here (0.160, XP 64). However -video d3d looks exactly the same as ddraw with GroovyMAME. OpenGL is not usable. Have you tried launching the games from command line?
Steps to create a log:
Giddygoon
« Reply #2 on: April 10, 2015, 11:55:37 am »
Hi Calamity,
I launch mine via a front end called AtomicFE..... which I think is run the GM via command line, but I will try it later tonight
Im glad you have confirmed that ddraw is fine, but if Direct3d is the same then even better
in the GM mame ini file should i set it to GENERIC_31 or is it Arcade Monitor 31 or is it VGA for my monitor??
also do I go for lock supported modes on of off?
Or should just start a new GM ini file and leave it on default for my 31khz monitor
Sorry for all the questions
BTW I just wanted to say this is the go to mame emu for accurate arcade play, Thanks very much for this great project!!!
« Last Edit: April 10, 2015, 11:58:54 am by Giddygoon »
Calamity
  • Moderator
« Reply #3 on: April 10, 2015, 12:00:20 pm »
That's a good idea. Leave all default options but the monitor option, use arcade_31: http://forum.arcadecontrols.com/index.php/topic,116023.0.html
Giddygoon
« Reply #4 on: April 10, 2015, 01:03:03 pm »
Great!!!
Thanks for the info, I'll go back to my cab and start again
Giddygoon
« Reply #5 on: April 11, 2015, 03:50:34 am »
Yes, yes, yes!!!!
Everything is running just like it was, pefect frame sync and full screen, no sound sound stuttering
As you said set to Arcade_31 and just leave default
Thanks again, loving Groovymame 160
