Author Topic: Audio issue with Mala  (Read 6260 times)
limner
  • Last login:June 08, 2015, 06:59:42 pm
« on: February 19, 2015, 07:02:29 am »
hi
i've installed Mala and used the frontend audio options.
I enabled the frontend audio and used "Fade in/out" option and i noticed that when i entered a game the is no audio and when exit the game and return to the frontend the audio i again working.
After this i reentered a game and went to desktop (without closing mame) and i noticed that "Wave volume" is zero when in a game and max when in frontend Mala.
I disabled the option "Fade in/out" and as result i had again volume up in game and mala.
Is "Fate in/ou" option not working? Is it a bug?
empardopo
  • Last login:October 03, 2026, 12:29:13 pm
    • My personal forum
Re: Audio issue with Mala
« Reply #1 on: February 19, 2015, 10:00:31 am »
Can you put a screenshot of your MALA setup?
Are you using the last version of MALA?
Greetings.
limner
« Reply #2 on: February 19, 2015, 09:24:47 pm »
i resolve the problem removing "fade out/in" option: mala lower volume entering the game but raise the volume only when exiting the game (re-entering mala frontend)
it seems to be a bug.
i use the last version of mala
« Reply #3 on: February 19, 2015, 09:35:24 pm »
Its most definitely a bug I have run into it.
Someone may have come up with a complicated work around but the reality is that its yet another example of the unfortunate lack of development for Mala.
limner
« Reply #4 on: February 20, 2015, 08:59:10 am »
ok, if it is a bug is better that anyone knows, also because is not critical:
-> Do not use "fate in/out" music option in the Mala Gui because il will lower to Zero level the music/sound during the games and will raise again only in Mala Frontend. (It is a bug)
empardopo
    • My personal forum
« Reply #5 on: February 23, 2015, 03:10:27 am »
You could test it using the last version of MALA.
I'll try test it too.
Greetings.
