Author Topic: Need some help with Mala 1.74  (Read 3657 times)
Incantator
  • Last login:February 03, 2015, 11:56:12 pm
« on: February 02, 2015, 09:18:41 pm »
Hello. I've used MameUI or something until lately, but decided to look for some new 'frontends' and learn more about arcade emulating stuff. So I installed Mala, but I couln't play a single game successfully so I came here.
I did everything correctly with the instruction listed on http://malafe.net/index.php?page=docshelp, except designating the snap directory; I think 'snap' means the pictures of each game so that one can browse games more easily, but I don't have the compilation so I just left it blank.
I refreshed the list and it looks like this:
So I press 1, and it loads to 100%, and it revert backs to this screen again. The log is like this:
015-02-03  10:42:16.89   Info: BuildGameListMenu: Adding New Menu 1 All Games
2015-02-03  10:42:16.90   Info: BuildGameListMenu: Adding New Menu 2 Most Played Games
2015-02-03  10:42:17.10   Info: LoadVideo:  \grdians NOT found
2015-02-03  10:42:17.10   Info: DisplayVideo: Master Did not Load : \grdians
2015-02-03  10:42:17.10   Info: LoadVideo:  \ NOT found
2015-02-03  10:42:17.10   Info: DisplayVideo: Clone did not Load : \grdians
2015-02-03  10:42:18.63   Info: Saving Names
2015-02-03  10:42:18.65   Info: GameListSave tmp: saving 83 games
2015-02-03  10:42:57.56   Info: SaveBiosList
2015-02-03  10:42:57.57   Info: Collecting games
2015-02-03  10:43:00.57   Info: Collect game Option: Only add Games with roms found
2015-02-03  10:43:01.57   Info: Collect game Option: Add Games even if rom not found
2015-02-03  10:43:02.58   Info: Collect game Option: Add non working Games
2015-02-03  10:43:03.58   Info: Collect game Option: Add Masters and Non Masters
2015-02-03  10:43:04.58   Info: Starting Game collection now
2015-02-03  10:43:04.59   Info: BuildFromXMLFile: Creating Game list from XML File
2015-02-03  10:43:04.59   Info: Loading mame XML File
2015-02-03  10:43:06.55   Info: Loading catver.ini File
2015-02-03  10:43:06.65   Info: Loading controls.ini data
2015-02-03  10:43:06.65   Info: Loading nplayers.ini data
2015-02-03  10:43:06.65   Error: BuildFromXMLFile: No nplayers.ini file set!
2015-02-03  10:43:06.94   Info: Starting game search
2015-02-03  10:43:06.94   Info: Using xml file: D:\휴식\Games\Arcade\Mame\mame.xml
2015-02-03  10:43:06.94   Info: MAME Version from XML: 158
2015-02-03  10:44:48.59   Info: Finished game search
2015-02-03  10:44:48.62   Info: Finished Game list from XML File
2015-02-03  10:44:51.02   Info: 84 Games added to list
2015-02-03  10:44:51.02   Info: Created using: Rom Info File: D:\휴식\Games\Arcade\Mame\mame.xml
2015-02-03  10:44:51.02   Info: Catver File: D:\휴식\Games\Arcade\Mame\catver.ini
2015-02-03  10:44:51.03   Info: Controls File: D:\휴식\Games\Arcade\Mame\controls.ini
2015-02-03  10:44:51.03   Info: Players File:
2015-02-03  10:44:51.03   Info: MAME: Loading Game Names
2015-02-03  10:44:51.07   Info: Saving game list: D:\휴식\Games\Arcade\MaLa174_001\MaLa174\All Games.mlg
2015-02-03  10:44:51.09   Info: FormActivate:
2015-02-03  10:44:52.16   Info: LoadVideo:  \3dobios NOT found
2015-02-03  10:44:52.16   Info: DisplayVideo: Master Did not Load : \3dobios
2015-02-03  10:44:52.16   Info: LoadVideo:  \ NOT found
2015-02-03  10:44:52.17   Info: DisplayVideo: Clone did not Load : \3dobios
2015-02-03  10:45:05.02   Info: KeyDownAction: Scrolling At Maximum Speed. Enable Display Delay with min exceptions if this is too slow
2015-02-03  10:45:06.53   Info: LoadVideo:  \airlbios NOT found
2015-02-03  10:45:06.53   Info: DisplayVideo: Master Did not Load : \airlbios
2015-02-03  10:45:06.53   Info: LoadVideo:  \ NOT found
2015-02-03  10:45:06.54   Info: DisplayVideo: Clone did not Load : \airlbios
2015-02-03  10:45:12.74   Info: LoadVideo:  \kof2000 NOT found
2015-02-03  10:45:12.74   Info: DisplayVideo: Master Did not Load : \kof2000
2015-02-03  10:45:12.74   Info: LoadVideo:  \ NOT found
2015-02-03  10:45:12.74   Info: DisplayVideo: Clone did not Load : \kof2000
2015-02-03  10:45:13.81   Info: Saving game list: D:\휴식\Games\Arcade\MaLa174_001\MaLa174\All Games.mlg
2015-02-03  10:45:13.84   Info: Starte: Current Memory used: 303,700 K
2015-02-03  10:45:13.87   Info: Starte: Cancel any Display & Video Delay due to game start
2015-02-03  10:45:13.88   Info: Set dir: D:\휴식\Games\Arcade\Mame\
2015-02-03  10:45:13.88   Info: Starte:: Starting Game : kof2000 .Create process: mame.exe kof2000
2015-02-03  10:45:24.87   Info: Starte: Ending Game:  >>>>>>>>>>>>>>>>> Quit:
2015-02-03  10:45:24.88   Info: Starte: Resfreshing hi score. Running D:\휴식\Games\Arcade\MaLa174_001\MaLa174\hi\hi.bat kof2000
2015-02-03  10:45:24.89   Info: Current Memory used: 304,216 K
2015-02-03  10:45:24.89   Info: Ended Game: Set back dir: D:\휴식\Games\Arcade\MaLa174_001\MaLa174\
2015-02-03  10:45:24.90   Info: Focus: Force main form into focus. ++++++++++++++Does it help?++++++++++++++++
2015-02-03  10:45:24.95   Info: FormActivate:
2015-02-03  10:45:24.96   Info: Layout Video: Starting delay timer after game quit
2015-02-03  10:45:25.97   Info: LoadVideo:  \kof2000 NOT found
2015-02-03  10:45:25.97   Info: DisplayVideo: Master Did not Load : \kof2000
2015-02-03  10:45:25.98   Info: LoadVideo:  \ NOT found
2015-02-03  10:45:26.00   Info: DisplayVideo: Clone did not Load : \kof2000
2015-02-03  10:50:34.54   Info: LoadVideo:  \su2000 NOT found
2015-02-03  10:50:34.54   Info: DisplayVideo: Master Did not Load : \su2000
2015-02-03  10:50:34.54   Info: LoadVideo:  \ NOT found
2015-02-03  10:50:34.54   Info: DisplayVideo: Clone did not Load : \su2000
2015-02-03  10:50:37.91   Info: Saving game list: D:\휴식\Games\Arcade\MaLa174_001\MaLa174\All Games.mlg
2015-02-03  10:50:37.92   Info: Starte: Current Memory used: 304,244 K
2015-02-03  10:50:37.92   Info: Starte: Cancel any Display & Video Delay due to game start
2015-02-03  10:50:37.94   Info: Set dir: D:\휴식\Games\Arcade\Mame\
2015-02-03  10:50:37.94   Info: Starte:: Starting Game : kof2000 .Create process: mame.exe kof2000
2015-02-03  10:50:40.82   Info: Starte: Ending Game:  >>>>>>>>>>>>>>>>> Quit:
2015-02-03  10:50:40.83   Info: Starte: Resfreshing hi score. Running D:\휴식\Games\Arcade\MaLa174_001\MaLa174\hi\hi.bat kof2000
2015-02-03  10:50:40.83   Info: Current Memory used: 304,276 K
2015-02-03  10:50:40.83   Info: Ended Game: Set back dir: D:\휴식\Games\Arcade\MaLa174_001\MaLa174\
2015-02-03  10:50:40.84   Info: Focus: Force main form into focus. ++++++++++++++Does it help?++++++++++++++++
2015-02-03  10:50:40.87   Info: FormActivate:
2015-02-03  10:50:40.89   Info: Layout Video: Starting delay timer after game quit
2015-02-03  10:50:41.90   Info: LoadVideo:  \kof2000 NOT found
2015-02-03  10:50:41.90   Info: DisplayVideo: Master Did not Load : \kof2000
2015-02-03  10:50:41.90   Info: LoadVideo:  \ NOT found
2015-02-03  10:50:41.90   Info: DisplayVideo: Clone did not Load : \kof2000
2015-02-03  10:54:36.26   Info: popMainPopup:
2015-02-03  10:54:36.26   Info: BuildGameListMenu: Adding New Menu 1 All Games
2015-02-03  10:54:36.26   Info: BuildGameListMenu: Adding New Menu 2 Most Played Games
2015-02-03  10:54:37.46   Info: FormClose
2015-02-03  10:54:37.46   Info: FormClose: There are no active plugins to close.
2015-02-03  10:54:38.15   Info: FormClose: Video1 Window now Closed
2015-02-03  10:54:38.15   Info: FormClose: Video2 Window now Closed
2015-02-03  10:54:38.15   Info: FormClose: Muazc Not Playing
2015-02-03  10:54:38.15   Info: Writing params to ini file
2015-02-03  10:54:39.69   Info: Muzac: Saving Playlist from Memory to FILE : D:\휴식\Games\Arcade\MaLa174_001\MaLa174\mala.pls
2015-02-03  10:54:39.69   Info: Muzac: Saving Playlist. Number of Songs to save= 0
2015-02-03  10:54:39.81   Info: Screensaver: ScreenSaver Form Destroyed
2015-02-03  10:54:39.81   Info: FormClose: ShowTaskbar
2015-02-03  10:54:39.82   Info: Showing taskbar
2015-02-03  10:54:39.82   Info: Closing MaLa v1.74  [1.7.4.0]
2015-02-03  10:54:39.82   Info: **************************************************************************
2015-02-03  10:54:39.83   Info: **************************************************************************
2015-02-03  10:54:39.83   Info: FormActivate:
, which, of course, honestly I don't understand. I just downloaded the rom file http://www.emuparadise.me/M.A.M.E._-_Multiple_Arcade_Machine_Emulator_ROMs/The_King_of_Fighters_2000/14044 for testing, and various bios files from somewhere which was called '1.57 bios pack' or something (I really don't know anything technical; I do remember that I needed that bios files when I used old MameUI so I just did the same thing here).
My setting looks like this:
If someone needs more information, I'll upload it. I think this question seems way too basic in this forum, but couldn't find any better forum though.
Thanks.
Slippyblade
Re: Need some help with Mala 1.74
« Reply #1 on: February 02, 2015, 09:47:35 pm »
First step anytime you have Front End problems is to try to run the game from the command line.  Doing THAT will tell you if you've got proper ROMS (parent/child stuff), correct versions, etc.
Incantator
« Reply #2 on: February 02, 2015, 10:02:58 pm »
Thanks for the suggestion. I tried it with the vanilla Mame 0.158 and the game (king of fighters 2000) works fine. I put the neogeo bios too. Don't know what's the problem with the Mala though.
« Last Edit: February 02, 2015, 10:20:58 pm by Incantator »
empardopo
  • Last login:April 24, 2026, 05:26:35 pm
    • My personal forum
« Reply #3 on: February 03, 2015, 03:50:00 am »
I'm not sure but perhaps your problem it's the path of mame. I don't see very good this picture.
Try to change mame to other directory and change the setup in MALA too.
Greetings.
Btw, there is a new version of MALA (1.820).I recommend using it.
« Last Edit: February 03, 2015, 03:53:36 am by empardopo »
Incantator
« Reply #4 on: February 03, 2015, 04:32:47 am »
empardopo, thanks! I changed the path and it works now. It's a bit strange though.
At first, my roms were in Arcade/Roms/Kof2000/ and I checked 'search the subfolders' option, the path being Arcade/Roms. Funny thing is that the game is shown in the list but doesn't work as I've mentioned. This time I put the roms in Arcade/Roms/ and still left the option checked and this time it works (with the path being unchanged). Maybe I have mistaken the meaning of 'search the subfolders'? I want to put roms in each seperate folders... Is there any way I can do it?
And... may I ask some more questions about Mala?
1. Is there any way to get rid of BIOS files from the list automatically? It's too tedious to do it manually.
2. Do I have to make a 'snap' folder and take a screenshot of each game by myself or is there any compilation or something so that I can just use the pictures?
Thanks for helping me :)
« Last Edit: February 03, 2015, 06:35:01 am by Incantator »
empardopo
    • My personal forum
« Reply #5 on: February 03, 2015, 09:47:45 am »
1.- You can try this
From command line (in your mame directory) mame.exe -listxml > file.xml
Then in MALA, you must choose your generated file.xml like Rom info file(XML).
2.- In internet you could find some compilations of snaps!
Greetings!
nullPointer
  • Last login:January 23, 2021, 10:09:31 pm
« Reply #6 on: February 03, 2015, 12:44:26 pm »
Emumovies is pretty much the de facto standard for this sort of thing.  Some folks balk at having to pay for a service of this nature, but it really is totally worth it IMO.
Incantator
« Reply #7 on: February 03, 2015, 06:17:08 pm »
empardopo// The command line you mean is the space where you put the directory strings, right? (I'm not native at English so just wanted to make it sure I've understood correctly). I did what you said. A black window (command-line interface) pops up briefly and disappears. The xml file seemed not changed at all. Anyway, I opened Mala again, relocated the xml file to the supposedly changed one, refresh, but still NEOGEO is proudly shown in the list ;D  :'(
nullPointer// Thanks for the suggestion, but since I'm constrained myself to using laptop at the moment, I'm not going to download a bunch of roms anyway so paying for the few snapshots don't seem to be a good idea now. Maybe I should just take those by myself or look for any compilation for a little more.
And I thought version higher than 1.8 was denoted as 'Beta' but those seem to work fine, right? I'll also use the latest version.
DudeRegular
« Reply #8 on: February 03, 2015, 07:07:46 pm »
1.82 is a beta but it added 7z support for rom files. Pretty handy with the merged sets.
empardopo
    • My personal forum
« Reply #9 on: February 04, 2015, 06:06:18 am »
I've heard problems using new versions of mame. Perhaps, that could be your problem.
Try to check it with an older version of mame. For example, the 0.106 is a very popular version of mame.
Btw, I'm not native English. :-)
