Author Topic: GroovyMame Super Resolution Win7 issue  (Read 7035 times)
MuguiWara
  • Last login:December 10, 2017, 03:36:38 pm
« on: January 25, 2015, 12:44:51 pm »
Hi everyone,
I'm trying to use Groovymame/Vmmaker with the super resolution feature, Whatever i do, I always hand up with all my resolutions locked.
Here my configuration,
OS : Windows 7 64
processor : I5
Graphic Card : ATI 4890
Monitor : manual MS2930 form a blast city configured in 15khz only for know
crt_emudriver 13.1.1.2b_w7_64 /vmmaker+arcade OSD 1.4
GroovyMame 0.157 switchRes 015e
All my vmmaker, groovymame, arcadeOsd exec files are in admin mode
mame.ini file
I've already tried changing
lock_system_modes         0
lock_unsupported_modes    0
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   ..\..\Roms\CPS;..\..\Roms\CPS2;..\..\Roms\CPS3;..\..\Roms\NeoGeo MVS;..\..\Roms\MAME;..\..\Roms\ShmupMame;..\..\Roms\Cave;..\..\Roms\ShmupMame;
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  0
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
update_in_pause           0
debugscript
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
console                   0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   custom
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              2
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15450-16050, 50-65, 3.190, 4.750, 6.450, 0.191, 0.191, 1.164, 0, 0, 192, 288, 448, 576
#15450-16050, 50-65, 3.190, 4.750, 6.450, 0.191, 0.191, 1.164, 0, 0, 192, 288, 448, 576
# 31000-32000, 50-65, 0.330, 3.580, 1.750, 0.316, 0.063, 1.137, 0, 0, 480, 512, 0, 0
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD DEBUGGING OPTIONS
log                       1
verbose                   1
debug                     0
debugger                  auto
oslog                     0
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                2560x0
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# WINDOWS DEBUGGING OPTIONS
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
prescale                  1
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
vmmaker.ini file
Code: [Select]
; VideoModeMaker - Options
; 1. MAME
; Path for Mame executable, in case we want to extract xml information from it.
MameExe = "H:\HeavyBox\Hyperspin\Emulators\MAME\mame64.exe"
; Path for Mame ini folder, in case we want to create an ini file for each game.
; Important: existing ini files will be overwritten.
IniPath = "H:\HeavyBox\Hyperspin\Emulators\MAME\ini\"
; Mame options.
ListFromXML = 0 ; Processes Mame XML and get video mode list from it
GenerateXML = 0 ; Extracts XML from Mame (only needed once)
OnlyListMain = 0 ; Only list resolutions for games contained in MameMain.txt
GenerateInis = 0 ; Creates an ini file for each Mame game, in the IniPath folder
SDLMame = 0 ; Use SDLMame specific options
; Monitor orientation
MonitorHorizontal = 1 ; 0 = Rotating monitor: horizontal and vertical games at their native resolution
;     Suitable for users that physically rotate their CRTs
; 1 = Horizontal monitor: horizontal games run at their native resolution and
;     vertical games are rotated to fit in horizontal monitor
RotatingDesktop = 0 ; Specifies if both desktop and monitor are rotated
; Aspect ratio for vertical games on horizontal monitor
; 4:3 (keeps original aspect ratio)
; 3:3 (stretches to square format)
; 3:4 (stretches to full screen)
; h:v (custom aspect ratio)
VerticalAspect = "4:3"
; 2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
MonitorType = "CUSTOM"
; Monitor CUSTOM. These values will be used if MonitorType = "CUSTOM"
; monitor_specs_0-6 = "HfreqMin-HfreqMax, VfreqMin,VfreqMax, HFrontPorch, HSyncPulse, HBackPorch, VfrontPorch, VSyncPulse, VBackPorch, HSyncPol, VSyncPol, ActiveLinesLimit, VirtualLinesLimit"
; * HfreqMin-HfreqMax: Minimum and maximum horizontal frequency, in Hz. Defines the range of horizontal frequencies the monitor is capable to sync.
; The higher the horizontal frequency, the higher the vertical resolution available for the same vertical refresh.
; The higher the horizontal frequency, the higher the vertical refresh available for the same vertical resolution.
; The higher the horizontal frequency, the lower the horizontal amplitude of active video (narrower picture).
; * VFreqMin-VfreqMax: Minimum and maximum vertical frequency, in Hz, Defines the range of vertical frequencies the monitor is capable to sync.
; * HFrontPorch, HSyncPulse, HBackPorch: Horizontal timing and geometry, values in µs
; * VfrontPorch, VSyncPulse, VBackPorch: Vertical timing and geometry, values in ms
; * HSyncPol,VSyncPol: polarities, not in use! defaults to negative.
; * ActiveLinesLimit: Vertical resolutions until ActiveLinesLimit value included, are generated as progressive, regardless the possibility
;                           of obtaining the required vertical refresh value.
; * VirtualLinesLimit: Vertical resolutions above ActiveLinesLimit and below VirtualLinesLimit are virtualized, that is, an interlaced resolution
;                            bigger that the native one is generated, with the right refresh, and "hardware stretch" is applied.
;                            Vertical resolutions above VirtulaLinesLimit are generated as interlaced, without any stretching.
;monitor_specs0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 400
monitor_specs0 15450.00-16050.00, 55-65, 3.19, 4.75, 6.45, 0.191, 0.191, 1.164, 0, 0, 288, 448
;monitor_specs1 23900.00-24900.00, 55-65, 2.87, 3.0, 4.44, 0.451, 0.164, 1.148, 0, 0, 480, 768
;monitor_specs0 31000.00-32000.00, 55-65, 0.33, 3.58, 1.75, 0.316, 0.063, 1.137, 0, 0, 576, 768
; Tolerance for horizontal frequency, in kHz, enables extending the range defined by [ HfreqMin, HfreqMax ]
; The resulting allowed frequency range will be [ HfreqMin - HfreqTolerance, HfreqMax + HfreqTolerance ]
HfreqTolerance = 0.010
; 3. MODELINE GENERATOR
; Total number of modelines to generate. Here are the recommended values for each driver version:
; CRT_Emudriver, based on Catalyst 6.5: 160 modes (accepts up to 200, but above 160 HyperSpin will refuse to load)
; CRT_Emudriver, based on Catalyst 9.3: 120 modes (accepts some more but above 120 you can get some blue screens)
; Regular Catalyst                    : 60 modes (won't accept any more)
TotalModes = 120
; If enabled, only creates modes with 32 bits per pixel color depth
Only32BPPModes = 0
; Method for mode table generation. If Mame xml is processed, that will create a lot of different video modes, so the mode table
; will be optimized keeping the most relevant ones, and dropping the rest, to keep below the TotalModes value.
; 0 = Static table: modelines are generated keeping their original vertical refresh. This method is intended to be used in
;     combination with ini files for each game.
; 1 = Dynamic table: a table of dummy modes is created using xres and yres values while ignoring vfreq. This method is intended
;     to be used in combination with Switchres or Groovymame. No ini files are required using this method (you should disable the
;     GenerateInis option).
; 2 = Magic table: a table of 'magic resolutions' is created, by ignoring xres and vfreq and just keeping yres. This method greatly reduces
;     the total number of modes in the list. It's only supported by GroovyMAME, and is intended as a workaround for the Hyperspin issue.
ModeTableMethod_Custom = 0
ModeTableMethod_XML = 1
; Minimum resolution values (these will be used instead of lower values)
XresMin_XML = 240
YresMin_XML = 240
YresRound_XML = 4
XresMin_Custom = 240
YresMin_Custom = 160
YresRound_Custom = 0
; Minimum dotclock value allowed by the video card, in MHz (i.e. DotClockMin = 7.010)
DotClockMin = 0
; Number of iterations used by the mode generator [0,5]. The higher the number of iterations, the bigger the accuracy of the vertical
; refreshed obtained, normally at the cost of increasing the horizontal frequency strictly required.
Iterations = 0
; Specifies if the refresh label is multiplied by 10 before rounding (experimental).
VFreqLabelx10 = 0
; 4. DRIVER
; Display name to use as target
DisplayName = "\\.\DISPLAY1"
; Path for the driver folder
DriverPath = ".\driver\"
; If UpdateRegistry is enabled, UpdateDriver will only work if the driver version found in DriverPath matches the one installed
; in the system.
UpdateRegistry = 1 ; Specifies if the video card registry section will be updated with the new video modes
; (will only work in combination with CRT_EMUDriver).
UpdateDriver = 0 ; Specifies if the driver files in DriverPath will be updated with the new video modes, for
; future installations.
AnyCatalyst = 0 ; Allows modelines to be installed for any Catalyst version. This option is experimental and
; known to produce some problems.
If someone can tell me what i've done wrong or what i'm missing, that will greatly help me, I've been on it all day long.
Thank you in advance for helping me.
« Last Edit: January 27, 2015, 04:00:26 pm by MuguiWara »
MuguiWara
Re: GroovyMame Super Resolition Win7 issue
« Reply #1 on: January 25, 2015, 12:45:26 pm »
Some log launching street fighter 2 championship edition
mame64.exe sf2ce -v > log.txt
Code: [Select]
SwitchRes: v0.015d, Monitor: ms2930, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15450.00-16050.00,50.00-65.00,3.190,4.750,6.450,0.191,0.191,1.164,0,0,192,288,448,576
SwitchRes: Monitor range 23900.00-24900.00,50.00-65.00,2.870,3.000,4.440,0.451,0.164,1.148,0,0,384,400,0,0
SwitchRes: Monitor range 31000.00-32000.00,50.00-65.00,0.330,3.580,1.750,0.316,0.063,1.137,0,0,480,512,0,0
SwitchRes: \\.\DISPLAY1: ATI Radeon HD 4800 Series
SwitchRes: DeviceKey: System\CurrentControlSet\Control\Video\{83CC9448-CE05-4EF0-AF6E-5A6D8E60D88C}\0000
Switchres: Searching for custom video modes...
Switchres: [  1]  240x 160 @ 60 : DALDTMCRTBCD240x160x0x60 - Modeline "240x160_60 15.45KHz 59.64Hz" 4.82 240 256 280 312 160 201 204 259   -hsync -vsync
Switchres: [  2]  240x 200 @ 60 : DALDTMCRTBCD240x200x0x60 - Modeline "240x200_60 15.45KHz 59.64Hz" 4.82 240 256 280 312 200 221 224 259   -hsync -vsync
Switchres: [  3]  248x 192 @ 60 : DALDTMCRTBCD248x192x0x60 - Modeline "248x192_60 15.47KHz 59.95Hz" 4.95 248 264 288 320 192 216 219 258   -hsync -vsync
Switchres: [  4]  256x 192 @ 60 : DALDTMCRTBCD256x192x0x60 - Modeline "256x192_60 15.46KHz 59.91Hz" 5.07 256 272 296 328 192 216 219 258   -hsync -vsync
Switchres: [  5]  256x 224 @ 60 : DALDTMCRTBCD256x224x0x60 - Modeline "256x224_60 15.46KHz 59.91Hz" 5.07 256 272 296 328 224 232 235 258   -hsync -vsync
Switchres: [  6]  256x 239 @ 55 : DALDTMCRTBCD256x239x0x55 - Modeline "256x239_55 15.46KHz 55.01Hz" 5.07 256 272 296 328 239 251 254 281   -hsync -vsync
Switchres: [  7]  256x 240 @ 55 : DALDTMCRTBCD256x240x0x55 - Modeline "256x240_55 15.46KHz 55.40Hz" 5.07 256 272 296 328 240 251 254 279   -hsync -vsync
Switchres: [  8]  256x 240 @ 60 : DALDTMCRTBCD256x240x0x60 - Modeline "256x240_60 15.91KHz 60.03Hz" 5.60 256 280 312 352 240 244 247 265   -hsync -vsync
Switchres: [  9]  256x 244 @ 60 : DALDTMCRTBCD256x244x0x60 - Modeline "256x244_60 16.02KHz 59.56Hz" 5.64 256 280 312 352 244 248 251 269   -hsync -vsync
Switchres: [ 10]  256x 256 @ 55 : DALDTMCRTBCD256x256x0x55 - Modeline "256x256_55 15.49KHz 55.31Hz" 5.08 256 272 296 328 256 259 262 280   -hsync -vsync
Switchres: [ 11]  320x 224 @ 60 : DALDTMCRTBCD320x224x0x60 - Modeline "320x224_60 15.47KHz 59.97Hz" 6.56 320 344 376 424 224 232 235 258   -hsync -vsync
Switchres: [ 12]  320x 240 @ 55 : DALDTMCRTBCD320x240x0x55 - Modeline "320x240_55 15.45KHz 54.98Hz" 6.55 320 344 376 424 240 252 255 281   -hsync -vsync
Switchres: [ 13]  320x 244 @ 60 : DALDTMCRTBCD320x244x0x60 - Modeline "320x244_60 15.97KHz 59.35Hz" 6.77 320 344 376 424 244 248 251 269   -hsync -vsync
Switchres: [ 14]  320x 256 @ 55 : DALDTMCRTBCD320x256x0x55 - Modeline "320x256_55 15.45KHz 54.98Hz" 6.55 320 344 376 424 256 260 263 281   -hsync -vsync
Switchres: [ 15]  336x 224 @ 60 : DALDTMCRTBCD336x224x0x60 - Modeline "336x224_60 15.45KHz 59.90Hz" 6.80 336 360 392 440 224 232 235 258   -hsync -vsync
Switchres: [ 16]  384x 240 @ 60 : DALDTMCRTBCD384x240x0x60 - Modeline "384x240_60 15.73KHz 59.60Hz" 7.93 384 408 448 504 240 243 246 264   -hsync -vsync
Switchres: [ 17]  544x 242 @ 60 : DALDTMCRTBCD544x242x0x60 - Modeline "544x242_60 16.01KHz 59.97Hz" 11.40 544 584 640 712 242 246 249 267   -hsync -vsync
Switchres: [ 18]  640x 200 @ 60 : DALDTMCRTBCD640x200x0x60 - Modeline "640x200_60 15.46KHz 59.93Hz" 12.74 640 680 744 824 200 220 223 258   -hsync -vsync
Switchres: [ 19]  640x 480 @ 72 : system mode
mode_locked
Switchres: [ 20]  640x 480 @ 75 : system mode
mode_locked
Switchres: [ 21]  640x 480 @ 85 : system mode
mode_locked
Switchres: [ 22]  720x 480 @ 59 : system mode
mode_locked
Switchres: [ 23]  720x 480 @ 60 : system mode
mode_locked
Switchres: [ 24]  720x 576 @ 50 : system mode
mode_locked
Switchres: [ 25]  800x 600 @ 56 : system mode
mode_locked
Switchres: [ 26]  800x 600 @ 60 : system mode
mode_locked
Switchres: [ 27]  800x 600 @ 70 : system mode
mode_locked
Switchres: [ 28]  800x 600 @ 72 : system mode
mode_locked
Switchres: [ 29]  800x 600 @ 75 : system mode
mode_locked
Switchres: [ 30]  800x 600 @ 85 : system mode
mode_locked
Switchres: [ 31] 1024x 768 @ 60 : system mode
mode_locked
Switchres: [ 32] 1024x 768 @ 70 : system mode
mode_locked
Switchres: [ 33] 1024x 768 @ 72 : system mode
mode_locked
Switchres: [ 34] 1024x 768 @ 75 : system mode
mode_locked
Switchres: [ 35] 1024x 768 @ 85 : system mode
mode_locked
Switchres: [ 36] 1152x 864 @ 60 : system mode
mode_locked
Switchres: [ 37] 1152x 864 @ 70 : system mode
mode_locked
Switchres: [ 38] 1152x 864 @ 75 : system mode
mode_locked
Switchres: [ 39] 1152x 864 @ 85 : system mode
mode_locked
Switchres: [ 40] 1280x 720 @ 50 : system mode
mode_locked
Switchres: [ 41] 1280x 720 @ 59 : system mode
mode_locked
Switchres: [ 42] 1280x 720 @ 60 : system mode
mode_locked
Switchres: [ 43] 1280x 800 @ 60 : system mode
mode_locked
Switchres: [ 44] 1280x 800 @ 75 : system mode
mode_locked
Switchres: [ 45] 1280x 800 @ 85 : system mode
mode_locked
Switchres: [ 46] 1280x1024 @ 60 : system mode
mode_locked
Switchres: [ 47] 1280x1024 @ 70 : system mode
mode_locked
Switchres: [ 48] 1280x1024 @ 75 : system mode
mode_locked
Switchres: [ 49] 1280x1024 @ 85 : system mode
mode_locked
Switchres: [ 50] 1600x1200 @ 60 : system mode
mode_locked
Switchres: [ 51] 1600x1200 @ 75 : system mode
mode_locked
Switchres: [ 52] 1600x1200 @ 85 : system mode
mode_locked
SwitchRes: Found 18 custom of 52 active video modes
SwitchRes: -resolution was forced as 2560x0
SwitchRes: -resolution value not available: 2560x0
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.015d:[sf2ce] Calculating best video mode for 384x224@59.637405 orientation: normal
SwitchRes: [ 240]x[ 160]_(60=59.6448Hz) - locked
SwitchRes: [ 240]x[ 200]_(60=59.6448Hz) - locked
SwitchRes: [ 248]x[ 192]_(60=59.9535Hz) - locked
SwitchRes: [ 256]x[ 192]_(60=59.9109Hz) - locked
SwitchRes: [ 256]x[ 224]_(60=59.9109Hz) - locked
SwitchRes: [ 256]x[ 239]_(55=55.0071Hz) - locked
SwitchRes: [ 256]x[ 240]_(55=55.4014Hz) - locked
SwitchRes: [ 256]x[ 240]_(60=60.0340Hz) - locked
SwitchRes: [ 256]x[ 244]_(60=59.5613Hz) - locked
SwitchRes: [ 256]x[ 256]_(55=55.3107Hz) - locked
SwitchRes: [ 320]x[ 224]_(60=59.9651Hz) - locked
SwitchRes: [ 320]x[ 240]_(55=54.9751Hz) - locked
SwitchRes: [ 320]x[ 244]_(60=59.3532Hz) - locked
SwitchRes: [ 320]x[ 256]_(55=54.9751Hz) - locked
SwitchRes: [ 336]x[ 224]_(60=59.8992Hz) - locked
SwitchRes: [ 384]x[ 240]_(60=59.5985Hz) - locked
SwitchRes: [ 544]x[ 242]_(60=59.9663Hz) - locked
SwitchRes: [ 640]x[ 200]_(60=59.9264Hz) - locked
SwitchRes: [ 640]x[ 480]_[72=72.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[75=75.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[85=85.0000Hz] - locked
SwitchRes: [ 720]x[ 480]_[59=59.0000Hz] - locked
SwitchRes: [ 720]x[ 480]_[60=60.0000Hz] - locked
SwitchRes: [ 720]x[ 576]_[50=50.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[56=56.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[60=60.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[70=70.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[72=72.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[75=75.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[85=85.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[60=60.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[70=70.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[72=72.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[75=75.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[85=85.0000Hz] - locked
SwitchRes: [1152]x[ 864]_[60=60.0000Hz] - locked
SwitchRes: [1152]x[ 864]_[70=70.0000Hz] - locked
SwitchRes: [1152]x[ 864]_[75=75.0000Hz] - locked
SwitchRes: [1152]x[ 864]_[85=85.0000Hz] - locked
SwitchRes: [1280]x[ 720]_[50=50.0000Hz] - locked
SwitchRes: [1280]x[ 720]_[59=59.0000Hz] - locked
SwitchRes: [1280]x[ 720]_[60=60.0000Hz] - locked
SwitchRes: [1280]x[ 800]_[60=60.0000Hz] - locked
SwitchRes: [1280]x[ 800]_[75=75.0000Hz] - locked
SwitchRes: [1280]x[ 800]_[85=85.0000Hz] - locked
SwitchRes: [1280]x[1024]_[60=60.0000Hz] - locked
SwitchRes: [1280]x[1024]_[70=70.0000Hz] - locked
SwitchRes: [1280]x[1024]_[75=75.0000Hz] - locked
SwitchRes: [1280]x[1024]_[85=85.0000Hz] - locked
SwitchRes: [1600]x[1200]_[60=60.0000Hz] - locked
SwitchRes: [1600]x[1200]_[75=75.0000Hz] - locked
SwitchRes: [1600]x[1200]_[85=85.0000Hz] - locked
SwitchRes: Setting option -noswitchres
Video: Monitor 0000000000010001 = "\\.\DISPLAY1" (primary)
DirectDraw: Using DirectDraw 7
Blitting thread created
winwindow_video_window_create: blit_lock = TRUE
Blitting thread started
window_proc: WM_NCACTIVATE
DirectDraw: Configuring device ATI Radeon HD 4800 Series
DirectDraw: primary surface created: 640x480x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 384x224
DirectDraw: blit surface created: 384x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
blit_unlock = TRUE
window_proc: WM_PAINT
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
blit_lock = FALSE
window_proc: WM_PAINT:END
RawInput: APIs detected
Input: Adding Mouse #0: Souris HID
Input: Adding Gun #0: Souris HID
Input: Adding Kbd #0: Périphérique clavier PIH
Input: Adding Kbd #1: Microsoft USB Dual Receiver Wireless Keyboard (Mouse and Keyboard Center)
Input: Adding Mouse #1: Souris HID
Input: Adding Gun #1: Souris HID
DirectInput: Using DirectInput 7
Unable to load winpcap: 7e
Region ':maincpu' created
Region ':gfx' created
Region ':audiocpu' created
Region ':oki' created
Region ':aboardplds' created
Region ':bboardplds' created
Region ':cboardplds' created
Starting Street Fighter II': Champion Edition (World 920513) ':'
Optional device 'msm2' not found
Optional device 'msm1' not found
Optional device 'm48t35' not found
Optional shared pointer 'output' not found
Optional shared pointer 'objram2' not found
Optional shared pointer 'objram1' not found
Optional shared pointer 'qsound_ram2' not found
Optional shared pointer 'qsound_ram1' not found
  (missing dependencies; rescheduling)
Starting M68000 ':maincpu'
Starting Z80 ':audiocpu'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Speaker ':mono'
Starting YM2151 ':2151'
Starting OKI6295 ':oki'
Average speed: 100.00% (2 seconds)
blit_lock = TRUE
window_proc: WM_DESTROY
blit_lock = TRUE
Blitting thread destroyed
Sound: buffer overflows=3 underflows=0
Calamity
  • Moderator
  • Last login:August 29, 2026, 03:10:20 pm
  • Quote me with care
« Reply #2 on: January 25, 2015, 12:54:35 pm »
Check this:
http://forum.arcadecontrols.com/index.php/topic,143136.msg1484489.html#msg1484489
(Hopefully as soon as I have some free time I'll be releasing a fix for this unfamous detection issue at driver level).
Steps to create a log:
MuguiWara
« Reply #3 on: January 25, 2015, 01:57:43 pm »
thanks for your answer.
I've tried the 1600x workaround it did not help. I guess i will have to wait for the fix or do the resistor thing.
here the log
Code: [Select]
SwitchRes: v0.015d, Monitor: custom, Orientation: horizontal, Modeline generation: enabled
Switchres: [ 17]  512x 448 @ 60 : DALDTMCRTBCD512x448x0x60 - Modeline "512x448_60 15.49KHz 59.91Hz" 10.16 512 544 592 656 448 465 471 517 interlace  -hsync -vsync
Switchres: [ 18]  512x 478 @ 50 : DALDTMCRTBCD512x478x0x50 - Modeline "512x478_50 15.47KHz 49.99Hz" 10.15 512 544 592 656 478 531 537 619 interlace  -hsync -vsync
Switchres: [ 19]  512x 480 @ 54 : DALDTMCRTBCD512x480x0x55 - Modeline "512x480_54 15.47KHz 55.36Hz" 10.15 512 544 592 656 480 502 508 559 interlace  -hsync -vsync
Switchres: [ 20]  512x 512 @ 54 : DALDTMCRTBCD512x512x0x55 - Modeline "512x512_54 15.52KHz 55.32Hz" 10.18 512 544 592 656 512 518 524 561 interlace  -hsync -vsync
Switchres: [ 21]  544x 242 @ 60 : DALDTMCRTBCD544x242x0x60 - Modeline "544x242_60 16.01KHz 59.97Hz" 11.40 544 584 640 712 242 246 249 267   -hsync -vsync
Switchres: [ 22]  640x 200 @ 60 : DALDTMCRTBCD640x200x0x60 - Modeline "640x200_60 15.46KHz 59.93Hz" 12.74 640 680 744 824 200 220 223 258   -hsync -vsync
Switchres: [ 23]  640x 480 @ 60* : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.91KHz 59.94Hz" 13.24 640 680 744 832 480 487 493 531 interlace  -hsync -vsync
Switchres: [ 24]  640x 480 @ 72 : system mode
Switchres: [ 25]  640x 480 @ 75 : system mode
Switchres: [ 26]  640x 480 @ 85 : system mode
Switchres: [ 27]  640x 480 @ 90 : system mode
Switchres: [ 28]  640x 480 @100 : system mode
Switchres: [ 29]  640x 480 @120 : system mode
Switchres: [ 30]  640x 480 @160 : system mode
Switchres: [ 31]  640x 480 @200 : system mode
Switchres: [ 32]  720x 480 @ 30 : system mode
Switchres: [ 33]  720x 480 @ 59 : system mode
Switchres: [ 34]  720x 480 @ 60 : system mode
Switchres: [ 35]  720x 576 @ 24 : system mode
Switchres: [ 36]  720x 576 @ 50 : system mode
Switchres: [ 37]  768x 512 @ 54 : DALDTMCRTBCD768x512x0x55 - Modeline "768x512_54 15.53KHz 55.36Hz" 15.28 768 816 888 984 512 518 524 561 interlace  -hsync -vsync
Switchres: [ 38]  800x 600 @ 56 : system mode
Switchres: [ 39]  800x 600 @ 60 : system mode
Switchres: [ 40]  800x 600 @ 70 : system mode
Switchres: [ 41]  800x 600 @ 72 : system mode
Switchres: [ 42]  800x 600 @ 75 : system mode
Switchres: [ 43]  800x 600 @ 85 : system mode
Switchres: [ 44]  800x 600 @ 90 : system mode
Switchres: [ 45]  800x 600 @100 : system mode
Switchres: [ 46]  800x 600 @120 : system mode
Switchres: [ 47]  800x 600 @160 : system mode
Switchres: [ 48]  800x 600 @200 : system mode
Switchres: [ 49] 1024x 768 @ 60 : system mode
Switchres: [ 50] 1024x 768 @ 70 : system mode
Switchres: [ 51] 1024x 768 @ 72 : system mode
Switchres: [ 52] 1024x 768 @ 75 : system mode
Switchres: [ 53] 1024x 768 @ 85 : system mode
Switchres: [ 54] 1024x 768 @ 90 : system mode
Switchres: [ 55] 1024x 768 @100 : system mode
Switchres: [ 56] 1024x 768 @120 : system mode
Switchres: [ 57] 1024x 768 @150 : system mode
Switchres: [ 58] 1024x 768 @160 : system mode
Switchres: [ 59] 1024x 768 @200 : system mode
Switchres: [ 60] 1152x 864 @ 60 : system mode
Switchres: [ 61] 1152x 864 @ 70 : system mode
Switchres: [ 62] 1152x 864 @ 75 : system mode
Switchres: [ 63] 1152x 864 @ 85 : system mode
Switchres: [ 64] 1152x 864 @100 : system mode
Switchres: [ 65] 1280x 720 @ 50 : system mode
Switchres: [ 66] 1280x 720 @ 59 : system mode
Switchres: [ 67] 1280x 720 @ 60 : system mode
Switchres: [ 68] 1280x 800 @ 60 : system mode
Switchres: [ 69] 1280x 800 @ 75 : system mode
Switchres: [ 70] 1280x 800 @ 85 : system mode
Switchres: [ 71] 1280x1024 @ 60 : system mode
Switchres: [ 72] 1280x1024 @ 70 : system mode
Switchres: [ 73] 1280x1024 @ 75 : system mode
Switchres: [ 74] 1280x1024 @ 85 : system mode
Switchres: [ 75] 1280x1024 @ 90 : system mode
Switchres: [ 76] 1280x1024 @100 : system mode
Switchres: [ 77] 1280x1024 @120 : system mode
Switchres: [ 78] 1280x1024 @160 : system mode
Switchres: [ 79] 1280x1024 @180 : system mode
Switchres: [ 80] 1600x1200 @ 60 : system mode
Switchres: [ 81] 1600x1200 @ 75 : system mode
Switchres: [ 82] 1600x1200 @ 85 : system mode
Switchres: [ 83] 1600x1200 @100 : system mode
Switchres: [ 84] 1600x1200 @120 : system mode
Switchres: [ 85] 1920x1080 @ 24 : system mode
Switchres: [ 86] 1920x1080 @ 28 : system mode
Switchres: [ 87] 1920x1080 @ 30 : system mode
SwitchRes: Found 24 custom of 87 active video modes
SwitchRes: -resolution was forced as 1600x0
SwitchRes: [ 512]x[ 448]_(60=59.9110Hz) - locked
SwitchRes: [ 512]x[ 478]_(50=49.9903Hz) - locked
SwitchRes: [ 512]x[ 480]_(54=55.3560Hz) - locked
SwitchRes: [ 512]x[ 512]_(54=55.3226Hz) - locked
SwitchRes: [ 640]x[ 480]_[60=59.9360Hz] - locked
SwitchRes: [ 640]x[ 480]_[90=90.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[100=100.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[120=120.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[160=160.0000Hz] - locked
SwitchRes: [ 640]x[ 480]_[200=200.0000Hz] - locked
SwitchRes: [ 720]x[ 480]_[30=30.0000Hz] - locked
SwitchRes: [ 720]x[ 576]_[24=24.0000Hz] - locked
SwitchRes: [ 768]x[ 512]_(54=55.3583Hz) - locked
SwitchRes: [ 800]x[ 600]_[90=90.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[100=100.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[120=120.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[160=160.0000Hz] - locked
SwitchRes: [ 800]x[ 600]_[200=200.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[90=90.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[100=100.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[120=120.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[150=150.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[160=160.0000Hz] - locked
SwitchRes: [1024]x[ 768]_[200=200.0000Hz] - locked
SwitchRes: [1152]x[ 864]_[100=100.0000Hz] - locked
SwitchRes: [1280]x[1024]_[90=90.0000Hz] - locked
SwitchRes: [1280]x[1024]_[100=100.0000Hz] - locked
SwitchRes: [1280]x[1024]_[120=120.0000Hz] - locked
SwitchRes: [1280]x[1024]_[160=160.0000Hz] - locked
SwitchRes: [1280]x[1024]_[180=180.0000Hz] - locked
   rng(0):  out of range
SwitchRes: [1600]x[1200]_[100=100.0000Hz]
SwitchRes: [1600]x[1200]_[120=120.0000Hz]
SwitchRes: [1920]x[1080]_[24=24.0000Hz] - locked
SwitchRes: [1920]x[1080]_[28=28.0000Hz] - locked
SwitchRes: [1920]x[1080]_[30=30.0000Hz] - locked
blit_unlock = TRUE
blit_lock = FALSE
blit_lock = TRUE
blit_lock = TRUE
Calamity
  • Moderator
« Reply #4 on: January 25, 2015, 02:20:40 pm »
Post your Modelines.txt file.
MuguiWara
« Reply #5 on: January 25, 2015, 02:23:41 pm »
here the modeline.txt
Code: [Select]
Modeline "240x160_60 15.45KHz 59.66Hz" 4.820 240 256 280 312 160 201 204 259 -hsync -vsync
Modeline "240x200_60 15.45KHz 59.66Hz" 4.820 240 256 280 312 200 221 224 259 -hsync -vsync
Modeline "248x192_60 15.47KHz 59.95Hz" 4.950 248 264 288 320 192 216 219 258 -hsync -vsync
Modeline "256x192_60 15.43KHz 59.82Hz" 5.070 256 272 296 328 192 216 219 258 -hsync -vsync
Modeline "256x224_60 15.43KHz 59.82Hz" 5.070 256 272 296 328 224 232 235 258 -hsync -vsync
Modeline "257x224_60 15.43KHz 60.05Hz" 5.070 256 272 296 328 224 232 235 257 -hsync -vsync
Modeline "256x239_55 15.43KHz 54.93Hz" 5.070 256 272 296 328 239 251 254 281 -hsync -vsync
Modeline "256x240_55 15.43KHz 55.32Hz" 5.070 256 272 296 328 240 251 254 279 -hsync -vsync
Modeline "256x240_60 15.92KHz 60.06Hz" 5.600 256 280 312 352 240 244 247 265 -hsync -vsync
Modeline "256x244_60 16.05KHz 59.66Hz" 5.640 256 280 312 352 244 248 251 269 -hsync -vsync
Modeline "256x256_55 15.54KHz 55.50Hz" 5.080 256 272 296 328 256 259 262 280 -hsync -vsync
Modeline "320x224_60 15.48KHz 59.99Hz" 6.560 320 344 376 424 224 232 235 258 -hsync -vsync
Modeline "320x240_55 15.45KHz 54.99Hz" 6.550 320 344 376 424 240 252 255 281 -hsync -vsync
Modeline "320x244_60 16.01KHz 59.52Hz" 6.770 320 344 376 424 244 248 251 269 -hsync -vsync
Modeline "320x256_55 15.45KHz 54.99Hz" 6.550 320 344 376 424 256 260 263 281 -hsync -vsync
Modeline "336x224_60 15.47KHz 59.97Hz" 6.800 336 360 392 440 224 232 235 258 -hsync -vsync
Modeline "384x240_60 15.74KHz 59.61Hz" 7.930 384 408 448 504 240 243 246 264 -hsync -vsync
Modeline "512x448_60 15.52KHz 60.03Hz" 10.160 512 544 592 656 448 465 471 517 interlace -hsync -vsync
Modeline "512x478_50 15.50KHz 50.09Hz" 10.150 512 544 592 656 478 531 537 619 interlace -hsync -vsync
Modeline "512x480_55 15.50KHz 55.46Hz" 10.150 512 544 592 656 480 502 508 559 interlace -hsync -vsync
Modeline "512x512_55 15.55KHz 55.42Hz" 10.180 512 544 592 656 512 518 524 561 interlace -hsync -vsync
Modeline "544x242_60 16.00KHz 59.92Hz" 11.400 544 584 640 712 242 246 249 267 -hsync -vsync
Modeline "640x200_60 15.47KHz 59.97Hz" 12.740 640 680 744 824 200 220 223 258 -hsync -vsync
Modeline "640x480_60 15.94KHz 60.02Hz" 13.240 640 680 744 832 480 487 493 531 interlace -hsync -vsync
Modeline "768x512_55 15.56KHz 55.46Hz" 15.280 768 816 888 984 512 518 524 561 interlace -hsync -vsync
Calamity
  • Moderator
« Reply #6 on: January 25, 2015, 02:48:59 pm »
You're not creating the super resolutions. Did you rename the file containing them as "ReslList.txt"?
MuguiWara
« Reply #7 on: January 25, 2015, 03:02:37 pm »
Ok my bad  :banghead: , that's what was missing. I've renamed it and gone back to a 2560x configuration, it's all good now.
thanks a lot  :notworthy: .
here's the proof
Code: [Select]
Switchres: [  1]  640x 480 @ 60* : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.91KHz 59.94Hz" 13.24 640 680 744 832 480 487 493 531 interlace  -hsync -vsync
Switchres: [  2]  640x 480 @ 70 : system mode
Switchres: [  3]  640x 480 @ 72 : system mode
Switchres: [  4]  640x 480 @ 75 : system mode
Switchres: [  5]  640x 480 @ 85 : system mode
Switchres: [  6]  640x 480 @ 90 : system mode
Switchres: [  7]  640x 480 @100 : system mode
Switchres: [  8]  640x 480 @120 : system mode
Switchres: [  9]  640x 480 @140 : system mode
Switchres: [ 10]  640x 480 @150 : system mode
Switchres: [ 11]  640x 480 @160 : system mode
Switchres: [ 12]  640x 480 @200 : system mode
Switchres: [ 13]  688x 512 @ 50 : DALDTMCRTBCD688x512x0x51 - Modeline "688x512_50 15.45KHz 51.24Hz" 13.72 688 736 800 888 512 540 546 603 interlace  -hsync -vsync
Switchres: [ 14]  688x 512 @ 52 : DALDTMCRTBCD688x512x0x53 - Modeline "688x512_52 15.44KHz 52.60Hz" 13.71 688 736 800 888 512 532 538 587 interlace  -hsync -vsync
Switchres: [ 15]  688x 512 @ 54 : DALDTMCRTBCD688x512x0x54 - Modeline "688x512_54 15.48KHz 54.05Hz" 13.75 688 736 800 888 512 525 531 573 interlace  -hsync -vsync
Switchres: [ 16]  720x 480 @ 30 : system mode
Switchres: [ 17]  720x 480 @ 59 : system mode
Switchres: [ 18]  720x 480 @ 60 : system mode
Switchres: [ 19]  720x 576 @ 24 : system mode
Switchres: [ 20]  720x 576 @ 50 : system mode
Switchres: [ 21]  800x 600 @ 56 : system mode
Switchres: [ 22]  800x 600 @ 60 : system mode
Switchres: [ 23]  800x 600 @ 70 : system mode
Switchres: [ 24]  800x 600 @ 72 : system mode
Switchres: [ 25]  800x 600 @ 75 : system mode
Switchres: [ 26]  800x 600 @ 85 : system mode
Switchres: [ 27]  800x 600 @ 90 : system mode
Switchres: [ 28]  800x 600 @100 : system mode
Switchres: [ 29]  800x 600 @120 : system mode
Switchres: [ 30]  800x 600 @160 : system mode
Switchres: [ 31]  800x 600 @200 : system mode
Switchres: [ 32] 1024x 768 @ 60 : system mode
Switchres: [ 33] 1024x 768 @ 70 : system mode
Switchres: [ 34] 1024x 768 @ 72 : system mode
Switchres: [ 35] 1024x 768 @ 75 : system mode
Switchres: [ 36] 1024x 768 @ 85 : system mode
Switchres: [ 37] 1024x 768 @ 90 : system mode
Switchres: [ 38] 1024x 768 @100 : system mode
Switchres: [ 39] 1024x 768 @120 : system mode
Switchres: [ 40] 1024x 768 @150 : system mode
Switchres: [ 41] 1024x 768 @160 : system mode
Switchres: [ 42] 1024x 768 @200 : system mode
Switchres: [ 43] 1152x 864 @ 60 : system mode
Switchres: [ 44] 1152x 864 @ 70 : system mode
Switchres: [ 45] 1152x 864 @ 75 : system mode
Switchres: [ 46] 1152x 864 @ 85 : system mode
Switchres: [ 47] 1152x 864 @100 : system mode
Switchres: [ 48] 1280x 720 @ 50 : system mode
Switchres: [ 49] 1280x 720 @ 59 : system mode
Switchres: [ 50] 1280x 720 @ 60 : system mode
Switchres: [ 51] 1280x 800 @ 60 : system mode
Switchres: [ 52] 1280x 800 @ 75 : system mode
Switchres: [ 53] 1280x 800 @ 85 : system mode
Switchres: [ 54] 1280x1024 @ 60 : system mode
Switchres: [ 55] 1280x1024 @ 70 : system mode
Switchres: [ 56] 1280x1024 @ 75 : system mode
Switchres: [ 57] 1280x1024 @ 85 : system mode
Switchres: [ 58] 1280x1024 @ 90 : system mode
Switchres: [ 59] 1280x1024 @100 : system mode
Switchres: [ 60] 1280x1024 @120 : system mode
Switchres: [ 61] 1280x1024 @160 : system mode
Switchres: [ 62] 1280x1024 @180 : system mode
Switchres: [ 63] 1600x1200 @ 60 : system mode
Switchres: [ 64] 1600x1200 @ 75 : system mode
Switchres: [ 65] 1600x1200 @ 85 : system mode
Switchres: [ 66] 1600x1200 @100 : system mode
Switchres: [ 67] 1600x1200 @120 : system mode
Switchres: [ 68] 1920x1080 @ 24 : system mode
Switchres: [ 69] 1920x1080 @ 28 : system mode
Switchres: [ 70] 1920x1080 @ 30 : system mode
Switchres: [ 71] 2560x 224 @ 60 : DALDTMCRTBCD2560x224x0x60 - Modeline "2560x224_60 15.48KHz 60.00Hz" 50.90 2560 2720 2960 3288 224 232 235 258   -hsync -vsync
Switchres: [ 72] 2560x 240 @ 60 : DALDTMCRTBCD2560x240x0x60 - Modeline "2560x240_60 15.90KHz 60.00Hz" 52.66 2560 2728 2976 3312 240 244 247 265   -hsync -vsync
Switchres: [ 73] 2560x 248 @ 59 : DALDTMCRTBCD2560x248x0x59 - Modeline "2560x248_59 16.05KHz 58.78Hz" 53.41 2560 2728 2984 3328 248 252 255 273   -hsync -vsync
Switchres: [ 74] 2560x 256 @ 57 : DALDTMCRTBCD2560x256x0x57 - Modeline "2560x256_57 16.05KHz 57.11Hz" 53.41 2560 2728 2984 3328 256 260 263 281   -hsync -vsync
Switchres: [ 75] 2560x 264 @ 56 : DALDTMCRTBCD2560x264x0x56 - Modeline "2560x264_56 16.05KHz 55.53Hz" 53.41 2560 2728 2984 3328 264 268 271 289   -hsync -vsync
Switchres: [ 76] 2560x 448 @ 60 : DALDTMCRTBCD2560x448x0x60 - Modeline "2560x448_60 15.51KHz 60.00Hz" 51.00 2560 2720 2960 3288 448 465 471 517 interlace  -hsync -vsync
Switchres: [ 77] 2560x 464 @ 60 : DALDTMCRTBCD2560x464x0x60 - Modeline "2560x464_60 15.51KHz 60.00Hz" 51.00 2560 2720 2960 3288 464 473 479 517 interlace  -hsync -vsync
Switchres: [ 78] 2560x 480 @ 60 : DALDTMCRTBCD2560x480x0x60 - Modeline "2560x480_60 15.93KHz 60.00Hz" 52.89 2560 2728 2976 3320 480 487 493 531 interlace  -hsync -vsync
SwitchRes: Found 12 custom of 78 active video modes
SwitchRes: [ 640]x[ 480]_(60=59.9360Hz) - locked
SwitchRes: [ 640]x[ 480]_(70=70.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(72=72.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(75=75.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(85=85.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(90=90.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(100=100.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(120=120.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(140=140.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(150=150.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(160=160.0000Hz) - locked
SwitchRes: [ 640]x[ 480]_(200=200.0000Hz) - locked
SwitchRes: [ 688]x[ 512]_(50=51.2438Hz) - locked
SwitchRes: [ 688]x[ 512]_(52=52.6031Hz) - locked
SwitchRes: [ 688]x[ 512]_(54=54.0454Hz) - locked
SwitchRes: [ 720]x[ 480]_(30=30.0000Hz) - locked
SwitchRes: [ 720]x[ 480]_(59=59.0000Hz) - locked
SwitchRes: [ 720]x[ 480]_(60=60.0000Hz) - locked
SwitchRes: [ 720]x[ 576]_(24=24.0000Hz) - locked
SwitchRes: [ 720]x[ 576]_(50=50.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(56=56.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(60=60.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(70=70.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(72=72.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(75=75.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(85=85.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(90=90.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(100=100.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(120=120.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(160=160.0000Hz) - locked
SwitchRes: [ 800]x[ 600]_(200=200.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(60=60.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(70=70.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(72=72.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(75=75.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(85=85.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(90=90.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(100=100.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(120=120.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(150=150.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(160=160.0000Hz) - locked
SwitchRes: [1024]x[ 768]_(200=200.0000Hz) - locked
SwitchRes: [1152]x[ 864]_(60=60.0000Hz) - locked
SwitchRes: [1152]x[ 864]_(70=70.0000Hz) - locked
SwitchRes: [1152]x[ 864]_(75=75.0000Hz) - locked
SwitchRes: [1152]x[ 864]_(85=85.0000Hz) - locked
SwitchRes: [1152]x[ 864]_(100=100.0000Hz) - locked
SwitchRes: [1280]x[ 720]_(50=50.0000Hz) - locked
SwitchRes: [1280]x[ 720]_(59=59.0000Hz) - locked
SwitchRes: [1280]x[ 720]_(60=60.0000Hz) - locked
SwitchRes: [1280]x[ 800]_(60=60.0000Hz) - locked
SwitchRes: [1280]x[ 800]_(75=75.0000Hz) - locked
SwitchRes: [1280]x[ 800]_(85=85.0000Hz) - locked
SwitchRes: [1280]x[1024]_(60=60.0000Hz) - locked
SwitchRes: [1280]x[1024]_(70=70.0000Hz) - locked
SwitchRes: [1280]x[1024]_(75=75.0000Hz) - locked
SwitchRes: [1280]x[1024]_(85=85.0000Hz) - locked
SwitchRes: [1280]x[1024]_(90=90.0000Hz) - locked
SwitchRes: [1280]x[1024]_(100=100.0000Hz) - locked
SwitchRes: [1280]x[1024]_(120=120.0000Hz) - locked
SwitchRes: [1280]x[1024]_(160=160.0000Hz) - locked
SwitchRes: [1280]x[1024]_(180=180.0000Hz) - locked
SwitchRes: [1600]x[1200]_(60=60.0000Hz) - locked
SwitchRes: [1600]x[1200]_(75=75.0000Hz) - locked
SwitchRes: [1600]x[1200]_(85=85.0000Hz) - locked
SwitchRes: [1600]x[1200]_(100=100.0000Hz) - locked
SwitchRes: [1600]x[1200]_(120=120.0000Hz) - locked
SwitchRes: [1920]x[1080]_(24=24.0000Hz) - locked
SwitchRes: [1920]x[1080]_(28=28.0000Hz) - locked
SwitchRes: [1920]x[1080]_(30=30.0000Hz) - locked
SwitchRes: [2560]x[ 224]_(60=60.0000Hz)
   rng(0): 2560 x 224_59.637p 15.506 [integ] scale(6, 1, 1) diff(10.00, 0.00, 0.0000) ratio(6.667, 1.000)
SwitchRes: [2560]x[ 240]_(60=59.9962Hz)
   rng(0): 2560 x 240_59.637p 15.744 [integ] scale(6, 1, 1) diff(10.00, 1.52, 0.0000) ratio(6.667, 1.071)
SwitchRes: [2560]x[ 248]_(59=58.7839Hz)
   rng(0): 2560 x 248_58.791p 16.050 [integ] scale(6, 1, 1) diff(10.00, 3.66, -0.8462) ratio(6.667, 1.107)
SwitchRes: [2560]x[ 256]_(57=57.1103Hz)
   rng(0): 2560 x 256_57.117p 16.050 [integ] scale(6, 1, 1) diff(10.00, 3.56, -2.5200) ratio(6.667, 1.143)
SwitchRes: [2560]x[ 264]_(56=55.5294Hz)
   rng(0): 2560 x 264_55.536p 16.050 [integ] scale(6, 1, 1) diff(10.00, 3.46, -4.1011) ratio(6.667, 1.179)
SwitchRes: [2560]x[ 448]_(60=60.0000Hz)
   rng(0): 2560 x 448_59.637i 15.536 [integ] scale(6, 2, 1) diff(10.00, 0.00, 0.0000) ratio(6.667, 2.000)
SwitchRes: [2560]x[ 464]_(60=60.0000Hz)
   rng(0): 2560 x 464_59.637i 15.536 [integ] scale(6, 2, 1) diff(10.00, 0.00, 0.0000) ratio(6.667, 2.071)
SwitchRes: [2560]x[ 480]_(60=60.0000Hz)
   rng(0): 2560 x 480_59.637i 15.774 [integ] scale(6, 2, 1) diff(10.00, 1.52, 0.0000) ratio(6.667, 2.143)
SwitchRes: [sf2ce] (1) horizontal (384x224@59.64)->(2560x224@59.64)
SwitchRes: Modeline "2560x224_60 15.51KHz 59.64Hz" 50.98 2560 2720 2960 3288 224 233 236 260   -hsync -vsync
Switchres: saving    DALDTMCRTBCD2560x224x0x60 - Modeline "2560x224_60 15.48KHz 60.00Hz" 50.90 2560 2720 2960 3288 224 232 235 258   -hsync -vsync
Switchres: updating  DALDTMCRTBCD2560x224x0x60 - Modeline "2560x224_60 15.51KHz 59.64Hz" 50.98 2560 2720 2960 3288 224 233 236 260   -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -multithreading
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nohwstretch
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nofilter
SwitchRes: Setting option -prescale 1
DirectDraw: primary surface created: 2560x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 2560x224
DirectDraw: blit surface created: 2560x224x32 (R=00FF0000 G=0000FF00 B=000000FF)
blit_unlock = TRUE
blit_lock = FALSE
Average speed: 100.06% (16 seconds)
Switchres: restoring DALDTMCRTBCD2560x224x0x60 - Modeline "2560x224_60 15.48KHz 60.00Hz" 50.90 2560 2720 2960 3288 224 232 235 258   -hsync -vsync
blit_lock = TRUE
blit_lock = TRUE
MuguiWara
« Reply #8 on: January 27, 2015, 04:00:07 pm »
Hello again,
I add some time to run a few more test, and i noticed that some games are running at a superior resolution than expected (vertical (224x320@58.97)->(2560x480@58.97) for vertical game mostly) ,
with further investigation it seems that vmmaker rules out some modelines (like 2560x320), and all my low resolution modelines are gone in arcadeOsd ( no resolutions under 640x480 after running vmmaker).
Can you please tell me if this is an expected behavior due to the fact that my screen is horizontal  or if i still have something going on.
thank you for your help.
here some log for the tested game :
Code: [Select]
Switchres: [  1]  640x 480 @ 58 : DALDTMCRTBCD640x480x0x59 - Modeline "640x480_58 15.67KHz 59.03Hz" 13.04 640 680 744 832 480 487 493 531 interlace  -hsync -vsync
Switchres: [  2]  640x 480 @ 60* : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.91KHz 59.94Hz" 13.24 640 680 744 832 480 487 493 531 interlace  -hsync -vsync
Switchres: [  9]  640x 480 @160 : system mode
Switchres: [ 10]  640x 480 @200 : system mode
Switchres: [ 11]  688x 512 @ 50 : DALDTMCRTBCD688x512x0x51 - Modeline "688x512_50 15.45KHz 51.24Hz" 13.72 688 736 800 888 512 540 546 603 interlace  -hsync -vsync
Switchres: [ 12]  688x 512 @ 52 : DALDTMCRTBCD688x512x0x53 - Modeline "688x512_52 15.44KHz 52.60Hz" 13.71 688 736 800 888 512 532 538 587 interlace  -hsync -vsync
Switchres: [ 13]  688x 512 @ 54 : DALDTMCRTBCD688x512x0x54 - Modeline "688x512_54 15.48KHz 54.05Hz" 13.75 688 736 800 888 512 525 531 573 interlace  -hsync -vsync
Switchres: [ 14]  720x 480 @ 30 : system mode
Switchres: [ 15]  720x 480 @ 59 : system mode
Switchres: [ 16]  720x 480 @ 60 : system mode
Switchres: [ 17]  720x 576 @ 24 : system mode
Switchres: [ 18]  720x 576 @ 50 : system mode
Switchres: [ 19]  800x 600 @ 56 : system mode
Switchres: [ 20]  800x 600 @ 60 : system mode
Switchres: [ 21]  800x 600 @ 70 : system mode
Switchres: [ 22]  800x 600 @ 72 : system mode
Switchres: [ 23]  800x 600 @ 75 : system mode
Switchres: [ 24]  800x 600 @ 85 : system mode
Switchres: [ 25]  800x 600 @ 90 : system mode
Switchres: [ 26]  800x 600 @100 : system mode
Switchres: [ 27]  800x 600 @120 : system mode
Switchres: [ 28]  800x 600 @160 : system mode
Switchres: [ 29]  800x 600 @200 : system mode
Switchres: [ 30] 1024x 768 @ 60 : system mode
Switchres: [ 31] 1024x 768 @ 70 : system mode
Switchres: [ 32] 1024x 768 @ 72 : system mode
Switchres: [ 33] 1024x 768 @ 75 : system mode
Switchres: [ 34] 1024x 768 @ 85 : system mode
Switchres: [ 35] 1024x 768 @ 90 : system mode
Switchres: [ 36] 1024x 768 @100 : system mode
Switchres: [ 37] 1024x 768 @120 : system mode
Switchres: [ 38] 1024x 768 @150 : system mode
Switchres: [ 39] 1024x 768 @160 : system mode
Switchres: [ 40] 1024x 768 @200 : system mode
Switchres: [ 41] 1152x 864 @ 60 : system mode
Switchres: [ 42] 1152x 864 @ 70 : system mode
Switchres: [ 43] 1152x 864 @ 75 : system mode
Switchres: [ 44] 1152x 864 @ 85 : system mode
Switchres: [ 45] 1152x 864 @100 : system mode
Switchres: [ 46] 1280x 720 @ 50 : system mode
Switchres: [ 47] 1280x 720 @ 59 : system mode
Switchres: [ 48] 1280x 720 @ 60 : system mode
Switchres: [ 49] 1280x 800 @ 60 : system mode
Switchres: [ 50] 1280x 800 @ 75 : system mode
Switchres: [ 51] 1280x 800 @ 85 : system mode
Switchres: [ 52] 1280x1024 @ 60 : system mode
Switchres: [ 53] 1280x1024 @ 70 : system mode
Switchres: [ 54] 1280x1024 @ 75 : system mode
Switchres: [ 55] 1280x1024 @ 85 : system mode
Switchres: [ 56] 1280x1024 @ 90 : system mode
Switchres: [ 57] 1280x1024 @100 : system mode
Switchres: [ 58] 1280x1024 @120 : system mode
Switchres: [ 59] 1280x1024 @160 : system mode
Switchres: [ 60] 1280x1024 @180 : system mode
Switchres: [ 61] 1600x1200 @ 60 : system mode
Switchres: [ 62] 1600x1200 @ 75 : system mode
Switchres: [ 63] 1600x1200 @ 85 : system mode
Switchres: [ 64] 1600x1200 @100 : system mode
Switchres: [ 65] 1600x1200 @120 : system mode
Switchres: [ 66] 1920x1080 @ 24 : system mode
Switchres: [ 67] 1920x1080 @ 28 : system mode
Switchres: [ 68] 1920x1080 @ 30 : system mode
Switchres: [ 69] 2560x 224 @ 60 : DALDTMCRTBCD2560x224x0x60 - Modeline "2560x224_60 15.48KHz 60.00Hz" 50.90 2560 2720 2960 3288 224 232 235 258   -hsync -vsync
Switchres: [ 70] 2560x 240 @ 60 : DALDTMCRTBCD2560x240x0x60 - Modeline "2560x240_60 15.90KHz 60.00Hz" 52.66 2560 2728 2976 3312 240 244 247 265   -hsync -vsync
Switchres: [ 71] 2560x 248 @ 59 : DALDTMCRTBCD2560x248x0x59 - Modeline "2560x248_59 16.05KHz 58.78Hz" 53.41 2560 2728 2984 3328 248 252 255 273   -hsync -vsync
Switchres: [ 72] 2560x 256 @ 57 : DALDTMCRTBCD2560x256x0x57 - Modeline "2560x256_57 16.05KHz 57.11Hz" 53.41 2560 2728 2984 3328 256 260 263 281   -hsync -vsync
Switchres: [ 73] 2560x 264 @ 56 : DALDTMCRTBCD2560x264x0x56 - Modeline "2560x264_56 16.05KHz 55.53Hz" 53.41 2560 2728 2984 3328 264 268 271 289   -hsync -vsync
Switchres: [ 74] 2560x 448 @ 60 : DALDTMCRTBCD2560x448x0x60 - Modeline "2560x448_60 15.51KHz 60.00Hz" 51.00 2560 2720 2960 3288 448 465 471 517 interlace  -hsync -vsync
Switchres: [ 75] 2560x 464 @ 60 : DALDTMCRTBCD2560x464x0x60 - Modeline "2560x464_60 15.51KHz 60.00Hz" 51.00 2560 2720 2960 3288 464 473 479 517 interlace  -hsync -vsync
Switchres: [ 76] 2560x 480 @ 60 : DALDTMCRTBCD2560x480x0x60 - Modeline "2560x480_60 15.93KHz 60.00Hz" 52.89 2560 2728 2976 3320 480 487 493 531 interlace  -hsync -vsync
SwitchRes: Found 13 custom of 76 active video modes
SwitchRes: v0.015d:[spcinv95] Calculating best video mode for 224x320@58.970001 orientation: rotated
SwitchRes: [ 640]x[ 480]_(58=59.0320Hz) - locked
SwitchRes: [1600]x[1200]_[100=100.0000Hz] - locked
SwitchRes: [1600]x[1200]_[120=120.0000Hz] - locked
   rng(0): 2560 x 224_58.970p 15.450 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.700)
   rng(0): 2560 x 240_58.970p 15.568 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.750)
   rng(0): 2560 x 248_58.791p 16.050 [fract] scale(6, 1, 1) diff(6.67, 0.00, -0.1788) ratio(11.429, 0.775)
   rng(0): 2560 x 256_57.117p 16.050 [fract] scale(6, 1, 1) diff(6.67, 0.00, -1.8526) ratio(11.429, 0.800)
   rng(0): 2560 x 264_55.536p 16.050 [fract] scale(6, 1, 1) diff(6.67, 0.00, -3.4337) ratio(11.429, 0.825)
   rng(0): 2560 x 448_58.970i 15.480 [fract] scale(6, 1, 1) diff(6.67, 48.85, 0.0000) ratio(11.429, 1.400)
   rng(0): 2560 x 464_58.970i 15.480 [fract] scale(6, 1, 1) diff(6.67, 48.85, 0.0000) ratio(11.429, 1.450)
   rng(0): 2560 x 480_58.970i 15.598 [fract] scale(6, 1, 1) diff(6.67, 49.24, 0.0000) ratio(11.429, 1.500)
SwitchRes: [spcinv95] (1) vertical (224x320@58.97)->(2560x480@58.97)
SwitchRes: Modeline "2560x480_60 15.60KHz 58.97Hz" 51.28 2560 2720 2960 3288 480 486 492 529 interlace  -hsync -vsync
Switchres: saving    DALDTMCRTBCD2560x480x0x60 - Modeline "2560x480_60 15.93KHz 60.00Hz" 52.89 2560 2728 2976 3320 480 487 493 531 interlace  -hsync -vsync
Switchres: updating  DALDTMCRTBCD2560x480x0x60 - Modeline "2560x480_60 15.60KHz 58.97Hz" 51.28 2560 2720 2960 3288 480 486 492 529 interlace  -hsync -vsync
SwitchRes: Setting option -noautoror
SwitchRes: Setting option -video ddraw
SwitchRes: Setting option -hwstretch
DirectDraw: primary surface created: 2560x480x32 (R=00FF0000 G=0000FF00 B=000000FF)
DirectDraw: New blit size = 224x320
DirectDraw: blit surface created: 224x320x32 (R=00FF0000 G=0000FF00 B=000000FF)
blit_unlock = TRUE
blit_lock = FALSE
Region ':gfx1' created
Region ':gfx2' created
Region ':ensoniq.0' created
Region ':plds' created
Starting Space Invaders '95: The Attack Of Lunar Loonies (Ver 2.5O 1995/06/14) ':'
Optional device 'oki' not found
Starting M68EC020 ':maincpu'
Starting Serial EEPROM 93C46 (64x16) ':eeprom'
Optional device 'finder_dummy_tag' not found
Starting Taito Ensoniq Sound System ':taito_en'
Starting M68000 ':audiocpu'
Starting MC68681 DUART ':duart68681'
Starting MC68681 DUART CHANNEL ':duart68681:cha'
Starting MC68681 DUART CHANNEL ':duart68681:chb'
Starting MB87078 Volume Controller ':mb87078'
Starting Speaker ':lspeaker'
Starting Speaker ':rspeaker'
Starting ES5505 ':ensoniq'
Average speed: 100.04% (21 seconds)
Switchres: restoring DALDTMCRTBCD2560x480x0x60 - Modeline "2560x480_60 15.93KHz 60.00Hz" 52.89 2560 2728 2976 3320 480 487 493 531 interlace  -hsync -vsync
blit_lock = TRUE
blit_lock = TRUE
My modeline.txt
Code: [Select]
Modeline "640x480_59 15.67KHz 59.03Hz" 13.040 640 680 744 832 480 487 493 531 interlace -hsync -vsync
Modeline "688x512_51 15.47KHz 51.32Hz" 13.720 688 736 800 888 512 540 546 603 interlace -hsync -vsync
Modeline "688x512_53 15.44KHz 52.61Hz" 13.710 688 736 800 888 512 532 538 587 interlace -hsync -vsync
Modeline "688x512_54 15.47KHz 54.01Hz" 13.750 688 736 800 888 512 525 531 573 interlace -hsync -vsync
Modeline "688x512_55 15.47KHz 54.97Hz" 13.750 688 736 800 888 512 520 526 563 interlace -hsync -vsync
Modeline "2560x224_60 15.48KHz 60.00Hz" 50.900 2560 2720 2960 3288 224 232 235 258 -hsync -vsync
Modeline "2560x240_60 15.90KHz 60.00Hz" 52.660 2560 2728 2976 3312 240 244 247 265 -hsync -vsync
Modeline "2560x248_59 16.05KHz 58.79Hz" 53.410 2560 2728 2984 3328 248 252 255 273 -hsync -vsync
Modeline "2560x256_57 16.05KHz 57.11Hz" 53.410 2560 2728 2984 3328 256 260 263 281 -hsync -vsync
Modeline "2560x264_56 16.05KHz 55.53Hz" 53.410 2560 2728 2984 3328 264 268 271 289 -hsync -vsync
Modeline "2560x448_60 15.51KHz 60.00Hz" 51.000 2560 2720 2960 3288 448 465 471 517 interlace -hsync -vsync
Modeline "2560x464_60 15.51KHz 60.00Hz" 51.000 2560 2720 2960 3288 464 473 479 517 interlace -hsync -vsync
Modeline "2560x480_60 15.93KHz 60.00Hz" 52.890 2560 2728 2976 3320 480 487 493 531 interlace -hsync -vsync
and My ReslList.txt
Code: [Select]
# Instructions to enable "super resolutions"
#   - Delete or rename the original "ReslList.txt" file
#   - Rename this file as "ReslList.txt"
#   - Set up VMMaker, in vmmaker.ini edit:
#       ListFromXML = 0
#       GenerateXML = 0
#       ModeTableMethod_Custom = 0
#   - Run VMMaker (run as admin in Windows 7!), restart.
#   - Then set up GroovyMAME, edit mame.ini with these settings:
#       resolution 2560x0
#       cleanstretch 2
## Desktop ##
 640 x 480 @ 60.000000 desktop
## Super resolutions ##
2560 x 224 @ 60.000000 super
2560 x 240 @ 60.000000 super
2560 x 248 @ 60.000000 super
2560 x 256 @ 60.000000 super
2560 x 264 @ 60.000000 super
2560 x 272 @ 60.000000 super
2560 x 280 @ 60.000000 super
2560 x 288 @ 60.000000 super
2560 x 296 @ 60.000000 super
2560 x 304 @ 60.000000 super
2560 x 320 @ 60.000000 super
2560 x 336 @ 60.000000 super
2560 x 344 @ 60.000000 super
2560 x 352 @ 60.000000 super
2560 x 360 @ 60.000000 super
2560 x 368 @ 60.000000 super
2560 x 376 @ 60.000000 super
2560 x 384 @ 60.000000 super
2560 x 392 @ 60.000000 super
2560 x 400 @ 60.000000 super
2560 x 416 @ 60.000000 super
2560 x 432 @ 60.000000 super
2560 x 448 @ 60.000000 super
2560 x 464 @ 60.000000 super
2560 x 480 @ 60.000000 super
2560 x 496 @ 60.000000 super
2560 x 512 @ 59.000000 super
2560 x 544 @ 55.000000 super
2560 x 560 @ 54.000000 super
2560 x 768 @ 60.000000 super
2560 x 800 @ 60.000000 super
« Last Edit: January 28, 2015, 03:05:06 am by MuguiWara »
MuguiWara
Re: GroovyMame Super Resolution Win7 issue
« Reply #9 on: January 28, 2015, 06:16:02 am »
Ok nevermind, correct me if i'm wrong, i just understood that the 15khz range generate only 192 to 288 in Progressive and 448 to 576 in Interlaced, so no 320p for 15khz horizontal, but should work fine with rotated screen as it is 224p when rotated.
« Last Edit: January 29, 2015, 08:51:10 am by MuguiWara »
