Author Topic: ArcadeOS sounds  (Read 2536 times)
abbot
ArcadeOS sounds
« on: March 05, 2002, 06:43:29 am »
After allowing my 2yr old to randomly bang around on the control panel, I no longer have AOS sounds (i.e. startup, exit, p1 button, etc.).  The actual game sounds work fine, just not the AOS sounds.  I tried editing the arcadeos.cfg file to make sure sounds=1 (as outlined in the readme file), but when I start up aos, still no sounds.  Then I look at the .cfg file and my edit is gone - as if the .cfg is overwritten with "default" settings.  Any ideas??  Thanks.
Lilwolf
  • Last login:May 23, 2026, 10:51:22 am
Re: ArcadeOS sounds
« Reply #1 on: March 05, 2002, 08:26:57 am »
I hear this a lot!
one of the reasons you cant configure JFront from the control panel.  You need a special key config to do anything :)
"like type in "secrentconfig" or whatever.   you get to choose it"
