Author Topic: Turn on Monitor automatically  (Read 1645 times)
fsa317
  • Last login:January 02, 2015, 08:15:48 am
« on: December 28, 2014, 01:02:04 pm »
My monitor is a Magnavox LCD connected via HDMI to a raspberry pi. After powering off the whole system and powering on (by turning on power strip) the monitor doesn't turn on automatically, I have to hit the power button manually... not good. Is there a way around it?
  • Last login:Today at 02:38:17 pm
Re: Turn on Monitor automatically
« Reply #1 on: December 28, 2014, 01:28:45 pm »
Several possible ways to address this issue:
1. Check the LCD's menus for a "power on restore"-type setting.
2. Use a toothpick or small screw to wedge the LCD power button so it is always pressed. (works on some models, not on others)
3. Wire a switch in parallel with the LCD power switch.
    3a Wire a switch in parallel with the LCD power switch and plug the LCD into the master slot of a smart strip. (preferably one with a sensitivity adjustment screw like the Smart Strip brand ones have IIRC)
lamprey
« Reply #2 on: December 29, 2014, 02:50:09 pm »
Just to follow-up on Scotts post; If you don't have a "power on restore"-type setting on the normal menus your monitor might have a hidden/service menu that may have it. I had to do that on my TV for my cabinet.
Cheers!
  • Last login:May 15, 2026, 05:08:29 pm
« Reply #3 on: December 29, 2014, 02:57:16 pm »
Toothpick trick has always been a winner for me.
