Author Topic: Test Points Common Test points on logic boards and Monitor boards  (Read 2197 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
What are common tests points an arcade technician or board level technician would put his DVM meter or Oscilloscope probe on?
The Test points can be anywhere on the logic board or Monitor boards
lilshawn
  • Last login:August 27, 2026, 06:39:50 pm
Re: Test Points Common Test points on logic boards and Monitor boards
« Reply #1 on: December 31, 2014, 02:33:39 pm »
all of them.
yes, anywhere. look for them. they are often labeled as such. your particular boards schematic diagram or service manual will inform you of their proper output for comparison.
Also, what did you get for question 46?, I'm stumped on that one.
