Author Topic: A little help with my MaLa background  (Read 4654 times)
BorgDog
« on: December 14, 2014, 11:38:40 pm »
I am doing a spaceman spiff theme for my vigolix bartop and am putting together a simple MaLa layout to go along with it.  Below is the image I would like to use as the background.  It originally was an all white background that I flipped to black and doctored up to get it looking halfway decent.  i'm not looking for anythign terribly fancy, but i am stumped as to how to go about doing the canopy on the spaceship.  As you can see it is basically all white where as it should be see through and maybe some shadow/glare to give it shape, but damned if I know how to do it (art is not my strong point).
Thanks.
My Projects:
wol-nz
Re: A little help with my MaLa background
« Reply #1 on: December 15, 2014, 04:29:22 pm »
you could try a simple gradient, use magic wand tool in photoshop to make selection then drag a black to transparent (circular) gradent over the inside then repeat for the outter side.
JDFan
« Reply #2 on: December 15, 2014, 05:16:50 pm »
Something similar to this ?
I took the photo - quick masked the area and copy pasted a new layer with it -- Inverted the colors on it and added a bit of inner and outer glow (included settings used in second pic to give you an idea of what was done)
« Last Edit: December 15, 2014, 05:19:37 pm by JDFan »
Louis Tully
« Reply #3 on: December 15, 2014, 05:23:27 pm »
« Last Edit: February 12, 2015, 06:35:04 pm by Louis Tully »
wol-nz
« Reply #4 on: December 15, 2014, 09:25:08 pm »
^ yes that's it - glass.. so obvious now duh..  :lol
BorgDog
« Reply #5 on: December 15, 2014, 09:38:24 pm »
That's pretty nice LT.  I played around with it a bit before work, found an image of a transparent ball, stretched and chopped and got this.  hmmm maybe some combination of them.  :cheers:  The nice thing about it being a mala background is that it's easy to change at will, unlike a CPO or side art.
Thanks all.
« Last Edit: December 15, 2014, 09:40:58 pm by BorgDog »
My Projects:
Louis Tully
« Reply #6 on: December 16, 2014, 09:56:13 am »
« Last Edit: February 12, 2015, 06:35:12 pm by Louis Tully »
BorgDog
« Reply #7 on: December 16, 2014, 11:18:12 am »
bah, my stupid work internet filter blocks imgur  :badmood: (school district, "adult oriented content"), fortunately I can check it out on my phone.  Definitely getting closer LT, I do agree with you on the top of the dome, needs a little something, and you obviously have more of an idea of what you are doing than I do, I can cut and paste.  Thanks for your help on this.
My Projects:
Louis Tully
« Reply #8 on: December 16, 2014, 05:18:38 pm »
« Last Edit: February 12, 2015, 06:36:03 pm by Louis Tully »
BorgDog
« Reply #9 on: December 16, 2014, 10:10:45 pm »
I like it!  #2 it is.  thank you very much  :applaud:  :cheers:
My Projects:
BorgDog
« Reply #10 on: December 16, 2014, 11:24:16 pm »
I updated my MaLa layout using your new background, vertical similar.  Thanks again.
« Last Edit: December 16, 2014, 11:30:52 pm by BorgDog »
My Projects:
Louis Tully
« Reply #11 on: December 17, 2014, 03:52:34 am »
« Last Edit: February 12, 2015, 06:36:18 pm by Louis Tully »
