Author Topic: Ebay Trackball speed adjustment  (Read 2580 times)
jaharr01
« on: November 25, 2014, 10:21:25 pm »
Does anybody know how you can adjust one of these in windows 7:
http://www.ebay.com/itm/LED-2-1-4-Trackball-MAME-PS2-Arcade-Pc-Not-HAPP-/120966914183?pt=LH_DefaultDomain_0&hash=item1c2a30a087
I need to increase the trackballs speed. It moves way too slow to play any trackball games effectively. I figured there is probably a registry hack for it out there somewhere.
Slippyblade
Re: Ebay Trackball speed adjustment
« Reply #1 on: November 25, 2014, 10:30:20 pm »
You would adjust it in MAME, not windows.
jaharr01
« Reply #2 on: November 26, 2014, 06:48:27 am »
Oh heck I didn't think about that slippy blade, that will definitely help. I wish there was a way to adjust it for pc games and etc. I wonder if I get a ps2 to usb adapter then windows would recognize it and I could adjust it?
« Reply #3 on: November 26, 2014, 09:19:58 am »
Does it not even show up in the control panel?
If it does, then:
Start>Devices and Printers>right click on the mouse
select mouse settings
click the pointer options tab
adjust the pointer speed
This will only affect MAME if multimouse is not enabled in mame.ini
If multimouse is enabled, MAME will get raw input data from the individual mice before windows does anything with it.
If multimouse is not enabled, MAME gets the input from the "system mouse" downstream after these settings have been applied. (but there is only one system mouse, so you can't have multiple mice....at least not in windows 7 or older)
« Last Edit: November 26, 2014, 09:22:22 am by BadMouth »
eds1275
  • Last login:May 07, 2026, 09:09:18 am
  • Rock and Roll!
« Reply #4 on: November 26, 2014, 01:07:15 pm »
Since we are on this topic... I have a regular mouse and a trackball hooked up to the arcade. Sometimes I need the extra usb port on the computer so I unplug the mouse, which screws up the trackball by changing it's number around. Is there a way to set mame to just use input from all mice?
« Reply #5 on: November 26, 2014, 02:17:44 pm »
see above.
TL;DNR - multimouse=0 in mame.ini
jaharr01
« Reply #6 on: November 26, 2014, 06:27:26 pm »
If it does, then:
I went to devices and printer, not there. BTW it's a ps2 mouse. multi mouse must be enabled because I can use both mice on the desktop at the same time. I wonder if the PS2 is set wrong in the bios. I could probably get a ps2 to usb adapter, then it would show up.
« Reply #7 on: November 26, 2014, 07:25:47 pm »
That is always the case.  Has nothing to do with enabling multi-mouse in MAME.
If multimouse is enabled in MAME, you'll see a number after the mouse where the axis is mapped in MAME.
jaharr01
« Reply #8 on: November 27, 2014, 12:53:28 am »
Well, I wonder why it doesn't show up in devices?
JDFan
« Reply #9 on: November 27, 2014, 11:30:56 am »
^This -- in windows all mice (trackballs, etc.) will act as a single system mouse (so they all work but moving any one moves the cursor etc.) - Multi mouse setting in MAME allows MAME to intercept and interprete the multiple mouse devices as seperate devices, rather than seeing them as the same. So you want to change the system mouse setting in windows as described -- Here is a screenshot (sometimes easier to see rather than read !) of where to find the setting in window 7 (it is similar in Vista/XP IIRC)
It doesn't show up as a separate device because windows sees all mice as the same device.
« Last Edit: November 27, 2014, 11:34:16 am by JDFan »
jaharr01
Re: Ebay Trackball speed adjustment (Solved)
« Reply #10 on: November 28, 2014, 12:04:54 pm »
Thanks that worked finally
eds1275
  • Rock and Roll!
« Reply #11 on: November 28, 2014, 01:18:16 pm »
AHA. I tried mashing the button inside mameUI and it had no effect but changing it in the text file did. I haven't checked the guns, will this interfere with aimtraks?
« Reply #12 on: November 28, 2014, 03:05:17 pm »
If they're showing up as mice, they'll only be able to control one pointer.
Both guns will control the same crosshair.
