Author Topic: Roms issues  (Read 3186 times)
nsvir
  • Last login:November 21, 2014, 07:05:00 am
Roms issues
« on: November 21, 2014, 06:43:18 am »
Hi!
I have just created a live USB with groovyMame.
Some (lots) of roms aren't recognized or have launching issues.
The websites says that the rom should be emulate with mame.
Here is [deleted again] example:
Why doesn't it work ? Is it because of mame, the rom ?
What roms really works ?
Thanks ion advance :)
« Last Edit: November 21, 2014, 06:49:23 am by Calamity »
Calamity
  • Moderator
  • Last login:July 19, 2026, 05:56:58 am
  • Quote me with care
Re: Roms issues
« Reply #1 on: November 21, 2014, 06:48:31 am »
Hi nsvir,
Sorry but posting links to rom files is not allowed.
The problem downloading single game roms is that some files are missing, because they are shared between clones of that game but just included in one of them. Other systems require their bios files too in order to run.
Steps to create a log:
nsvir
Re: Roms issues
« Reply #2 on: November 21, 2014, 06:52:18 am »
Thanks for your answer! Sorry for rom's link
Ok so what should I look for ?
I seek a bunch of popular arcade games for a one night fun.
sean_sk
  • Last login:August 06, 2019, 10:27:48 am
  • If quizzes are quizzical, then what are tests?
Re: Roms issues
« Reply #3 on: November 21, 2014, 08:57:49 am »
I could be wrong, but I'm not so sure this is an appropriate place to ask about what roms you need as you may not be able to get anyone to help you.
I'd suggest reading the forum rules here: http://arcadecontrols.com/arcade_message_rules.html
« Last Edit: November 21, 2014, 09:04:30 am by sean_skroht »
Slippyblade
Re: Roms issues
« Reply #4 on: November 21, 2014, 09:05:16 am »
Best thing to do is to run Mame directly from the command line.  When you tell it a rom to use, it will report back which parent rom you also need to supply.
Saneless
  • Last login:September 19, 2015, 12:29:26 pm
Re: Roms issues
« Reply #5 on: November 21, 2014, 09:38:34 am »
And a good rule of thumb is the ROM name will likely be the most simplest of the names.
For instance, The Simpsons is simply "simpsons.zip" - Teenage Mutant Ninja Turtles is "tmnt.zip"
When you see things like simpsons4pu, tmnt4a etc, you're not dealing with the base ROM.
