Author Topic: Hyperspin and Dolphin?  (Read 5093 times)
sin360
  • Last login:May 11, 2023, 11:12:23 am
« on: November 20, 2014, 10:46:55 pm »
I need a little help. I have mame and the 2 pc games that I want working. The only thing I'm having problems with is setting up dolphin. I just want to use it for 2 games. I've searched everywhere I can't find any info on setting up Dolphin. I added Dolphin to the wheel got the xml file and put in the database folder. Then I go to hyperlaunchhq and see that dolphin is there, but when I select module is not in the list under dolphin. I see that it's in global, but I can't get in the new system that I added. So when I select default emulator the option to select dolphin is not there either. I would greatly appreciated if anyone could help. Thanks
« Last Edit: November 20, 2014, 11:02:55 pm by sin360 »
Skinnysloth
  • Last login:May 08, 2016, 08:38:26 pm
Re: Hyperspin and Dolphin?
« Reply #1 on: November 20, 2014, 11:31:56 pm »
What did you name your wheel?  I think for the dolphin module to show up, you need to name the wheel "Nintendo Gamecube" or "Nintendo Wii" (without the quotes).
sin360
« Reply #2 on: November 20, 2014, 11:37:47 pm »
I named it Dolphin because that's what the module is named. The xml file was named Nintendo Gamcube from the hyperlist, but I changed it to Dolphin also. I was assuming it needed to be name the same as the module. I'll try to change it an see what happens.
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
« Reply #3 on: November 20, 2014, 11:52:33 pm »
Yea, it should be called Nintendo Wii, not Dolphin. Another option is to uncheck show supported emu only in global setting so every emulator will show up in every tab.
sin360
« Reply #4 on: November 21, 2014, 12:13:39 am »
Yep that did it. It can be name Nintendo Wii or Nintendo Gamecube. I went with Nintendo Gamecube since that's what I have the xml for and those are the games I was trying to setup. Thank for the help
