July 29, 2026, 10:27:10 pm
Did you forget your attachment?
Hi there, I've mocked up a cabinet design in sketch-up I'm considering attempting and all seem straight forward for the exception of one curve. Below is a cross section view of where the controls will be mounted, the 'B' curve will be a chamfer using a router but I can't figure how best to create the 'A' curve. Any ideas?Thanks.
Lots of wood putty and sanding.
Quote from: yotsuya on November 07, 2014, 05:11:37 pmLots of wood putty and sanding. Yeah, that's be easy too. Could take a large dowel or some pvc pipe etc to wrap the sandpaper around to keep the curve consistant.
This is what I did: Freehand routing and sanding afterwards to get the curve really smooth:
Yeah, I don't think EMDB understood like the rest of us did.Honestly, I've only ever seen that piece curved on a metal panel. None of the wood ones I've ever seen have a curve like that.
