Author Topic: WG7400 ticking  (Read 1409 times)
yukonblaze
  • Last login:February 16, 2023, 11:32:48 am
WG7400 ticking
« on: November 01, 2014, 05:27:41 pm »
Got a freebie and monitor ticking. B+ test at tp202 7-10 vdc. Any help appreciated. No neck glow. Game plays blind.
Jason
kardenm
  • Last login:June 13, 2019, 09:14:35 am
Re: WG7400 ticking
« Reply #1 on: November 05, 2014, 11:30:49 am »
I'm no expert but tp202 should be 117v.  Something gone in the power supply section.  :)
Many threads here on that symptom.  do a search of "ticking".
« Last Edit: November 05, 2014, 11:34:46 am by kardenm »
In theory, there is no difference between theory and practice, but in practice.....there is!!
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
Re: WG7400 ticking
« Reply #2 on: November 05, 2014, 03:53:45 pm »
flyback? Again, by far not an expert, but just my guess.
I agree, lots of posts here about "ticking".
yukonblaze
Re: WG7400 ticking
« Reply #3 on: November 06, 2014, 01:59:34 pm »
Have read every thread but not any I could find on low reading at tp202. Going to pull it and check on bench with a little more room.
MonMotha
Re: WG7400 ticking
« Reply #4 on: November 11, 2014, 03:36:02 am »
Generally speaking, something's shorted when you've got a ticking SMPS chassis.  Culprit is usually the vert IC or HOT but can be anything including the parts back in the power supply (output diodes, even the switch FET).  A common test is to isolate the power supply from the rest of the board and load it with a light bulb to test separately.
