Author Topic: MS8-26SU vertical compression  (Read 3270 times)
copados33
  • Last login:March 07, 2025, 08:23:35 pm
« on: September 21, 2014, 03:29:02 pm »
Hi, I have recently received this chassis from Chad from arcadecup, and while the picture quality is stunning I have noticed that the image has some vertical range compression at the bottom, I have been messing around with the V-Size, V-Line and V-Pos. pots on the front of the chassis but couldn't fix it, I have also noted that the V-Pos pot seems to be faulty, clockwise it moves the image erratically, it can go up but doesn't move the image down, it is possible that the cause of the problem is a defective potentiometer?
notice how the "credits" letters are compressed:
« Last Edit: September 21, 2014, 04:09:56 pm by copados33 »
ed12
Re: MS8-26SU vertical compression
« Reply #1 on: September 21, 2014, 03:38:06 pm »
yes
try to use some contact cleaner on it first
or if have the skill's? just replace it.
ed
grantspain
« Reply #2 on: September 21, 2014, 04:26:58 pm »
was the original chassis a ms8-26 or a ms8-25?
what is the impedance of the vertical yoke?
if the original is a ms8-26u and you did a direct swap out then there are a couple of components on the ms8-26su that will cause this issue
copados33
« Reply #3 on: September 21, 2014, 04:43:24 pm »
This is the original chassis, a MS8-26SU, this monitor came installed on an Aero City Sega arcade cab, 26" Mitsubishi tube model A63...something.
Vertical impedance yoke is 81.3 mH
How do I know the model/value in ohms of the pot to replace it if its broken?
« Last Edit: September 21, 2014, 04:47:06 pm by copados33 »
grantspain
« Reply #4 on: September 21, 2014, 04:55:55 pm »
mh is the inductance reading,impedance is ohms-i think it is around 50 ohms on the vertical on ms-26
the pot should have a code on it like 102 or even have the exact value like 5k
ed12
« Reply #5 on: September 21, 2014, 04:59:33 pm »
right in the 50 ohm range 37-47 resit.
ed
copados33
« Reply #6 on: September 21, 2014, 05:29:48 pm »
I tried with a multimeter now, vertical winding reads 37 ohms.
grantspain
« Reply #7 on: September 21, 2014, 05:39:37 pm »
ok thats good,i would look at changing that pot first
does the problem clear after some time,for example after 30 mins
copados33
« Reply #8 on: September 21, 2014, 05:53:17 pm »
Nope, yesterday I had the cab turned on for the whole day (15+ hours)  and it was looking the same all the time.
grantspain
« Reply #9 on: September 21, 2014, 06:02:25 pm »
ms8-26su chassis are known for issues on the vertical deflection,there are a couple resistors and diodes that fail
the first sign of this is compression leading to foldover and then finally leading to full collapse
but that vertical shift pot should work irrespective of this so i suggest changing the pot or at least check for bad solder joints around that area
copados33
« Reply #10 on: September 21, 2014, 07:17:39 pm »
Electronic stores are closed by the weekends around here, so I'll look for a replacement tomorrow and post my results.
copados33
« Reply #11 on: September 22, 2014, 05:17:14 pm »
Changed the faulty pot and it didn't work, I still see the image compressed at the bottom.
copados33
« Reply #12 on: September 27, 2014, 07:29:14 pm »
Anyone? is it possible that this monitor has had a MS8-26A instead o an MS8-26SU? I got this cab as "not working" and I'm starting to think that the previous owner swapped the chassis, are 26's and SU's interchangeable?
grantspain
« Reply #13 on: September 28, 2014, 12:14:59 pm »
i have only seen one model of ms8-26,there is a ms8-25 which is a low impedance chassis but you would get much more extreme vertical issues
my advice is to look at the caps around the deflection transistors plus there are some resistors that break down
copados33
« Reply #14 on: September 28, 2014, 01:20:04 pm »
This is the list of components that had been replaced and or serviced:
chriso
  • Last login:June 22, 2015, 08:47:25 am
« Reply #15 on: September 28, 2014, 06:44:00 pm »
Vertical linearity control
