Author Topic: Batch file to handle different settings for Daphne games?  (Read 1769 times)
arcadealex
  • Last login:December 17, 2004, 09:00:08 am
« on: December 11, 2003, 09:25:07 pm »
Now that I've got MW working with Daphne - (thanks Minwah!!)
I am trying to get Daphne to be able to play each laser game using specific command line settings depending on the game?
Has anyone done this? Minwah suggested something like:
if %1 = badlands then
    daphne badlands -latency 150 and -nohwaccel
if %1 = lair then
    daphne lair -whateveryouwant
I will give something like this a go on the weekend, but I was hoping someone out there has already tried it and has a solution ??
If so - could someone please post the code they use in the daphne.bat that MW uses to run the games?
Thanks again
Sandro, Australia.
  • Last login:July 13, 2025, 11:38:27 am
Re:Batch file to handle different settings for Daphne games?
« Reply #1 on: December 11, 2003, 11:11:56 pm »
skip the batch file, use one of the wrappers.... i believe i evne have one of the daphne configurations up as an example in the online docs
www.oscarcontrols.com/lazarus/
arcadealex
« Reply #2 on: December 12, 2003, 01:21:43 am »
Ok - thanks.. I think I understand it
So, from what I've read in the docs, I need to:
1. set up the daphne.cfg file that looks like similar to this:
extension=.txt
path=d:\daphne\
exe=daphne.exe
send rom path=0
send exit keys=0
command line options; vldp -fullscreen -framefile %.txt -x 1024 -y 768 -nohwaccel
Then in the lconfig.ini I need to set up specific entries (in the {cmdlist} section) for each Daphne game?
And as long as I have the entries match the framefile name it should be right?
If that's all correct, the only question I have is how to do I get MW to run this wrapper?  ???
Will I need tell MW that the executable for Daphne is the cmd-launch5.exe ?
« Reply #3 on: December 12, 2003, 08:22:25 pm »
yup you've got it
 and in the wrapper's lconfig.ini you tell it that the emulator is daphne.exe
