Author Topic: LEDBlinky Version 6.1  (Read 3225 times)
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
« on: August 27, 2014, 11:48:57 pm »
Just a heads up - I've completed work on LEDBlinky v6.1
Along with support for new hardware (Wolfware Tech Howler and Ultimarc iPAC Ultimate I/O) included in v6.0, the latest release includes features and enhancements that have been requested over the past year or so. Plus a bunch of bug fixes  ::)
- Added option to speak and blink the start and coin buttons on game start.
- Added option to speak and blink the FE Controls on startup.
- Added option to run the FE start animation for a single loop or a variable time specified in seconds. This is useful if you need to sync the LED animation with a FE video animation.
- Added variable Game Start delay in seconds. This option will add a delay after the FE game start event before LEDBlinky runs the configured Game Start options.
- Added option to load MAME configuration files (mame.xml, controls.ini, colors.ini) at start-up rather than when the emulator (MAME) is selected for the first time.
- Added new command line option to manually set one or more ports. This allows you to custom control the LEDs via batch or script file.
- Improved performance when loading animation files.
- Improved default voice actions when speaking HyperSpin controls; added pause after "Player 1..." and "Player 2...".
See the readme file for the complete list of updates.
Please post any question on the main LEDBlinky Thread.
arzoo
« Last Edit: August 28, 2014, 07:04:09 am by arzoo »
Robots will kill you.
Arcade Addiction
thatpurplestuff
  • Last login:July 31, 2026, 02:12:32 pm
Re: LEDBlinky Version 6.1
« Reply #1 on: August 28, 2014, 12:35:49 am »
Awesome can't wait to try out the new manual command line controls with my Skeeball software!  Thanks for all your hard work!
arzoo
    • LEDBlinky
« Reply #2 on: August 28, 2014, 07:10:46 am »
Let me know how it works out! Also, you'll probably want to disable the "Preload MAME Files" option - no need to load mame.xml if you're not using it.
Arcade Addiction
rockyrocket
« Reply #3 on: September 26, 2014, 12:16:26 pm »
Is there any documentation on the new command line options arzoo?.
Thanks in advance.
arzoo
    • LEDBlinky
« Reply #4 on: September 26, 2014, 01:06:03 pm »
Thanks in advance.
Both the readme and Install Config pdf list all the command line options. But if something is not clear let me know.
Arcade Addiction
