Author Topic: VGA to RGB board GBS 8100 to old 15Khz Arcade Monitor help needed  (Read 7349 times)
waldo34
  • Last login:April 04, 2023, 12:40:43 pm
Hi, hoping someone can point me in the correct direction. I picked up a Glaxicain cocktail arcade that was parted out. With the remaining cabinet I decided to make a quick multicade for the kids and myself using a Raspberry Pi. Not very hard however I have encountered one issue.
How to wire the VGA to RGB board ( GBS 8100 ) to the monitor. I have found one posting on the internet however it was not much help.
http://thearcademan.net/connecting-a-raspberry-pi-to-an-old-15khz-arcade-monitor
Hoping someone can point me in the correct direction. Here are some pictures.
ed12
Re: VGA to RGB board GBS 8100 to old 15Khz Arcade Monitor help needed
« Reply #1 on: August 27, 2014, 12:15:37 am »
to strat with
as i explained to u in the other thread..comp out to rgb..the 5 pin plug u see >white< header
 u set a switch and the s/w >inculed< to do so..
the board can and will handle multi sync input..
second i turst u are running that chasic on a :iso: ?
because them black mark's i c means some one was not..dose it even fire up ?
ed
waldo34
« Reply #2 on: August 27, 2014, 01:45:24 pm »
Hi Ed thanks for the posting. I need to post a few more pictures but let me provide this feedback,
Glaxicain cocktail arcade - When I picked it up the game it had some issues, like bad/missing controls. i was able to turn it on re- attach a few wires and jimmy rig controls to play a few games. The monitor and electrical are all in complete working order. My hope is one day when I sell the game to complete a full original restore.
waldo what part of the plug did u miss ?
the plug from the GBS 8100 has the current standard of
r=red
g=green
b=blue
g=ground
s/c=sync
I expected to plug the GBS 8100 wire harness directly to the CRT board. However, the current Glaxicain arcade wire harness that plugs into the CRT has more wires (seen in my photos) and with different colors.
I was going to map the r,g,b,g,s to the Glaxicain arcade wire harness but thought i would post here first. My other thought was when looking at the CRT board i can see a r,g,b, and brown wire leading to the CRT (seen in photos) can I skip the board and map those wires to the GBS 8100 wire harness?
Waldo
ed12
« Reply #3 on: August 27, 2014, 02:23:32 pm »
that look's like a modified g07..
the top board there has me concered
is this where the r/g/b/g/syc hook into ?
if u could post a few more pic's and the exact model # of the chassic
we will get u set up
ed
waldo34
« Reply #4 on: August 27, 2014, 10:46:43 pm »
Ed,
Many thank yous for your help on this project.
As requested photos to follow.
Please let me know what else you need.
Walter
waldo34
« Reply #5 on: August 27, 2014, 10:49:07 pm »
More to follow
waldo34
« Reply #6 on: August 27, 2014, 10:52:04 pm »
still more
waldo34
« Reply #7 on: August 27, 2014, 10:54:21 pm »
final post sorry I didn't rotate the pictures.
ed12
« Reply #8 on: August 27, 2014, 10:57:12 pm »
its ok
in your post of the colse up,of the top board >white<
if u look at your picture,on the right is rgb/g/snc
if u follow it to the left,u will see a plug that goes right into the chassic
again from top down
r,g,b,gnd,sync..
below that should be a 3 pin header
gnd/-sync.>v</-sync>h<
the sync is what ever the board is putting out
most are native -sync
ed
ed12
« Reply #9 on: August 27, 2014, 11:01:39 pm »
yes that daughter board is a sync-amp-buffer-board
but the end that hook's to that chassic is your rgbg/sync
let's hope the 3 pin plug is below it ?
ed
waldo34
« Reply #10 on: August 27, 2014, 11:16:44 pm »
the daughter board that the 6 wire harness plugs into it (assuming I am talking about the correct board) does not have anything below it. What i am seeing is they trace over to the blue (3), green (2), red (1), brown (4) leads coming off the top of the board.
Is this as simple as walking the traces and connecting to those pins? Do you think brown equals sync?
ed12
« Reply #11 on: August 27, 2014, 11:39:05 pm »
ok in picture #3 of your second post
show's a mixed bag of color's going to the plug
on the main chassic..
but your orange's >last 2 pin's< to the left for me would be sync
the next 1 back ground
then blue/green/red >from left to right<
now if u tie in right there ? and u do not get sync ?
we may  stlll need that daughter board..
if this is the case then post me picture of where the 2 other header's go to
i can better help u
ed
waldo34
« Reply #12 on: August 29, 2014, 11:34:06 pm »
Hi, Had to chase down a loose wire tonight, tomorrow I need to figure out a place to wire the GBS 8100 (5 volt) and I hope to try out the monitor.
waldo34
« Reply #13 on: September 03, 2014, 10:40:57 pm »
Ed, Hi again, I have not made much progress with this Kitchener 19 Data MT. I tried the wires direct into the daughter board and I cut the red,blue,green,brown wires going direct to the back board on the tube.
i noticed a working Ms Pacman 19" Monitor Wells Gardner 19k4626 on Craigslist the picture make it look like a much more straight forward hookup to the standard red, blue, green, ground, sync.
Any thoughts on the the Wells Gardner?
Waldo
ed12
« Reply #14 on: September 03, 2014, 10:54:02 pm »
ya there is nothing wrong with it..
more straight foward hook up also
from the back right to left
r/g/b/gnd/sync
there board mayeven state it and or a piece of paper on the side as a rule show's it
no fuss no muss...
hope u did not pay alot or will  ?
ed
waldo34
« Reply #15 on: September 08, 2014, 01:46:14 pm »
Picked up the used monitor, I confirm the setup works. As you stated the hook up was very easy and straight forward. This article help for understanding how sync works.
http://arcadecontrols.com/BBBB/sync.html
One issue the monitor was only $25, from a Ms Pacman, while I was told it had lot of life.....it didn't.
During a trip to the local Goodwill I found a 19 LCD monitor with DVI for $5. Well I brought that home plugged it in to find out the screen was cracked. Back to Good Will for the refund.
While there I found a 19" CRT TV with line-in for .50 cents. After a CRT discharge, de-shell, and re-mounting using the original monitor mount hardware I finally have a working monitor.
Now to move forward with the build.
