June 26, 2026, 07:14:02 am
Now my question is if I had a marquee made up and incased in plexiglass to those dimensions the top and bottom 18mm will be hidden by my plastic angle bead holding it in place is this normal?
HiIve been making my cabinet for about 2 years now on and off I know its taking ages.. Anyway ive finally got an LCD mounted and started looking at the marquee. The opening I have is 660mm (26") wide and the height including the 18mm mdf thickness is 17cm . Now my question is if I had a marquee made up and incased in plexiglass to those dimensions the top and bottom 18mm will be hidden by my plastic angle bead holding it in place is this normal? I planned to get a street fighter 2 replica marquee made up but concerned about losing the top and bottom of it. Should I be asking for it to be made with a black 18mm strip at the top and bottom im a little confused?
Thanks all, now I just need some artwork in the right size which is proving harder than I thought.
