Author Topic: bench tested a couple of games...  (Read 2764 times)
adder
« on: July 18, 2014, 06:13:38 pm »
Hi, i thought i would try a couple of benchmark tests with my groovymame (0153.015b) setup because i am using XP 64bit so wanted to check it was all installed/working ok, so i tried 3 different games (green beret, bad dudes, and sexy parodius), using both the 32bit and 64bit groovymame builds, on my XP 64bit PC (cpu is a core2duo E8400 3ghz)
i used 'mame <game> -bench 90' for all tests
Results:
sexyparo 32bit: Average speed: 171.20%
sexyparo 64bit: Average speed: 172.98%
gberet 32bit: Average speed: 5598.04%
gberet 64bit: Average speed: 5679.57%
baddudes 32bit: Average speed: 509.38%
baddudes 64bit: Average speed: 625.83%
Are these normal results? the reason i am paranoid is i remember reading about how one can expect a decent/noticeable increase in emulation speed between 32bit and 64bit mame builds. in reality, does that only apply to some of the drivers, or is there something amiss with my setup?
« Last Edit: July 18, 2014, 06:24:25 pm by jadder »
Calamity
  • Moderator
  • Last login:January 21, 2026, 10:59:40 am
  • Quote me with care
Re: bench tested a couple of games...
« Reply #1 on: July 21, 2014, 07:22:01 am »
Hi jadder,
I'd say the bigger difference is actually when using XP-32+MAME-32 vs XP-64+MAME-64, rather than MAME-32 vs MAME-64 on XP-64.
(in other words, it'd be a combination of the OS and MAME what performs better)
Steps to create a log:
