Author Topic: help is what i seek - sove this with me :)  (Read 3261 times)
DOC
  • Last login:June 30, 2004, 07:16:06 pm
  • I walk in the dark... But why am i afraid?
« on: December 05, 2003, 06:33:39 pm »
i just bought a cabinet " there was a Neo Geo game in it.. i think from 1992 - so it's not that old :D " including original monitor.
i want to hook the monitor up with my computer, " i heard ArcadeVGA'll do the trick? " but i'm beginnin' to doubt it a little since i don't know if all i need to do is purchase the ArcadeVGA - plug it in my computer - hook it up with monitor and of it goes :D...
the question is :
can i buy the ArcadeVGA and just plug it to the monitor and it will run?
" please respect my stupidity, i'm new.. and still a rookie :), i would apreciate all the help i can get from you guys :) "
« Last Edit: December 06, 2003, 06:39:53 am by DOC »
Learn we must.. Use the force... Abuse blonde woes...!!
Tailgunner
Re:Equpied'n'Armed.. why do i feel like a retard.. ?
« Reply #1 on: December 05, 2003, 07:05:01 pm »
Assuming the monitor is a standard resolution arcade monitor, then yes, it's pretty much plug and play.  Note you will have to wire the video cable up to the monitor's signal inputs. I'd suggest getting the cable from Ultimarc as the wires are labled and it will make connecting it easier.
DOC
« Reply #2 on: December 05, 2003, 07:06:58 pm »
sounds good to me..!!
what is the wire called?  Video Amplifier ?
« Last Edit: December 05, 2003, 07:12:26 pm by DOC »
Tailgunner
« Reply #3 on: December 05, 2003, 09:19:09 pm »
Actually you might not need that cable, depends on the existing wiring in the cab and your choice of interface. I believe a Neo Geo cab uses JAMMA wiring, which means the monitor would get it's signal through the JAMMA connector. Ultimarc's J-Pac would plug into the JAMMA connector, interfacing the computer to the control panel and the monitor. You'd still need the ArcadeVGA, which would plug into the J-Pac instead of directly to the monitor.
DOC
« Reply #4 on: December 05, 2003, 09:24:02 pm »
okay :) i've been reading alot about circuits and all that " nice stuff " i'm pretty new to this... but i've allready figured out how to hack some gamepads and bla bla :D " this is getting funny " anyways, i will take some pictures of this, as we think " JAMMA connector " then i'll show u and then you can tell me what i need, if u would be so kind   ::)...!!
i'mm off to bed... i'm stunned of all the reading.. =) i'll throw the pictures inhere tomorrow..!!
« Last Edit: December 06, 2003, 06:39:14 am by DOC »
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
No offense Doc, but change your Subject line and think about the things you say.
« Last Edit: December 05, 2003, 10:02:24 pm by Wienerdog »
This opinion was created from 100% post consumed information.
DOC
Re:help is what i seek - sove this with me :)
« Reply #6 on: December 06, 2003, 08:30:48 am »
aight :)...!! this is a little picture, is this what you're talking about?
if u
need more pictures then just say so * i've got loads of it  ;D *
« Last Edit: December 07, 2003, 05:17:23 pm by DOC »
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
« Reply #7 on: December 06, 2003, 06:27:19 pm »
http://stg.alamone.com/jamma.html
The first pic on that site is of a JAMMA cable and connector. I don't recommend messing around with that circled area in that pic you posted if you value the life of your monitor.
 The J-PAC is a circuit board that plugs in to the JAMMA harness. No need to touch the monitor at all.
Good luck on your project!
APf
DOC
« Reply #8 on: December 07, 2003, 01:23:56 pm »
:D now're talking !! i'll get some new pictures and show here very soon, then u can tell me if i'm right :)...!! but the zone i've showed you - what's up with it? u tell me i need to get my hands off it ? it would be great if u could explain about it, or give me a manual for a standard monitor perhaps ? " that would be great "
« Last Edit: December 07, 2003, 01:27:17 pm by DOC »
Tailgunner
« Reply #9 on: December 07, 2003, 03:37:42 pm »
I've pointed out what to look for.
Number 1 is the chassis board for your monitor. If you have to wire directly to the monitor, it would be to a connector on this board.
Number 2 points out the standoffs used to mount the original Neo Geo game board. If there's a JAMMA connector still in the cabinet, it will be hanging below these somewhere.
Number 3 is the wiring visible in the picture. Some of these should be  already connected to the monitor. There should be two wires that connect to the power, often there's an isolation transformer in the cab bottom that they connect to. There should also be another group that would run from the JAMMA connector to the monitor chassis board. These are the signal inputs that feed the picture to the monitor.
The thing you have circled in the lower picture is part of the picture tube's yoke. It's not what you're looking for, so ignore it for the time being.
DOC
« Reply #10 on: December 07, 2003, 04:39:22 pm »
ahhh god!! you're a genius  ;D now :) i've got this Jamma connector you're taling about. and yes, the board was placed like u said before :)
have a look at this :
this:
and this :
this :
this :
now you've seen it :) " hope'em pictures be good enough :)...!!
the only thing i would like to get my hands on now is : a little quick tutorial that could show me how to do this right :) and explanation on which of these cabels are the ones for use.. ::)
« Last Edit: December 07, 2003, 05:16:26 pm by DOC »
Tailgunner
« Reply #11 on: December 07, 2003, 06:17:42 pm »
Yep, that's the connector we're after. :)
Fitrst thing you should do is go here: http://www.klov.com/game_detail.php?letter=N&game_id=8846 and download the Neo-Geo operator's manual they have. In it you'll find a schematic showing what connects to where on the JAMMA connector. If you're going the J-Pac route hooking everything up will be simple and straight forward, you can check the J-Pac installation page at ultimarc.com site to see what's involved.
DOC
« Reply #12 on: December 08, 2003, 03:26:48 am »
ahhh!!! :) i've just been onto the manual " easy and simple "
i understand that part fully now..!! * u the man!! thanks :) *
i've also been lookin' at the JPAC! do i need to get the ArcadeVga card if i get the Jpac ?
anyways, i just made this little pic : when i saw the jpac i thought it might work this way " since ppl talk about " BLA BLA jamma and wolla " :D
i know this might be stupid, but i just want to make sure :)...!!
* btw, i've also discoverd' the adjustment switches on monitor board ;) * thanks *
* this picture may be a help to other Newbies outhere like me * ;)
« Last Edit: December 08, 2003, 03:29:09 am by DOC »
Tailgunner
« Reply #13 on: December 08, 2003, 05:49:10 pm »
Well, you'd need either the ArcadeVGA or another video card that's capable of outputting a 15KHz signal to use your arcade monitor. There are a few others that can do it, but the ArcadeVGA is much simpler to setup and use.
As for the connections:
DOC
« Reply #14 on: December 09, 2003, 02:14:57 am »
aight :) that's it then :) thank you very much for all your service in this topic * TAILGUNNER = very helpfull * :)
if nothings further then i think ,
CASE BE CLOSED  ;D
