Author Topic: MAME lightgun crosshair question  (Read 8190 times)
epetti
  • Last login:September 14, 2023, 10:15:20 pm
« on: May 07, 2014, 05:17:03 pm »
I just got two light guns for my system, red and blue. I managed to successfully calibrate them and get them working with MAME. I also have them plugged in to match the color scheme of the rest of my control panel where all Player 1 controls are red and all Player 2 controls are blue. But, if I have crosshairs turned on, MAME seems to by default color the player 1 crosshair blue and the player 2 red. It's not the end of the world, but it's a little confusing to have those colors exactly swapped from the colors of the guns. I could swap the guns, but I'd rather not. Anyone know if there's either a setting or image somewhere for controlling the MAME crosshairs, either color or shape?
  • Last login:Today at 04:15:47 am
Re: MAME lightgun crosshair question
« Reply #1 on: May 07, 2014, 05:29:59 pm »
There is a MAME "Crosshair Options" menu that allows you to select the crosshair color for each player, but I'm not sure how to make a global change.
I guess the lazy way to do it is to swap filenames on the red and blue crosshair images in the MAME\crosshair folder.   :lol
EDIT: Works in MAMEUIFX, not regular MAME.   :banghead:
EDIT 2: Thanks, BadMouth.
« Last Edit: May 09, 2014, 02:42:22 pm by PL1 »
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #2 on: May 07, 2014, 05:52:50 pm »
That's what I would do if I were determined to change the cross-hair colors. I noticed the same issue with my light-gun set-up. Doesn't bother me enough to want to switch the cross-hair colors, but I think switching the graphic file names would be the best way to do it.
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
epetti
« Reply #3 on: May 08, 2014, 11:31:14 pm »
Hmm. Don't see a crosshair folder under MAME (I'm in .148. ). And under Crosshair Options it just lists DEFAULT for P1 and P2 Crosshairs with no way to change them.
« Last Edit: May 09, 2014, 12:49:33 am by epetti »
« Reply #4 on: May 09, 2014, 12:18:57 am »
D'oh.   :banghead:
Works for MAMEUIFX, not regular MAME.
EDIT: Thanks, BadMouth.
« Last Edit: May 09, 2014, 02:41:06 pm by PL1 »
  • Last login:Yesterday at 06:12:06 pm
« Reply #5 on: May 09, 2014, 09:10:12 am »
Scroll down to the crosshair section:
http://mrdo.mameworld.info/mame_artwork_supp.php
Check the crosshair path in mame.ini and make sure the name of the crosshair folder (which you create yourself) matches.
I seem to remember an issue with the name on mr do's page.
EDIT:
Mr Do's instructions say crsshair, but the default is now crosshair.  It can be changed in mame.ini
There are some alternative crosshairs attached to posts in this thread:
http://forum.arcadecontrols.com/index.php/topic,121412.msg1336407.html#msg1336407
I don't remember the last version of MAME that I utilized this on.
It was either 146 or 148.
« Last Edit: May 09, 2014, 10:22:12 am by BadMouth »
epetti
« Reply #6 on: May 10, 2014, 04:50:42 pm »
Worked great. Thank you.
