Author Topic: Problem with ePSXe pad configuration  (Read 2179 times)
MrPoPo
  • Last login:March 10, 2004, 05:53:46 pm
« on: December 03, 2003, 05:34:05 pm »
Hi group !!
When I config the PSX controller in ePSXe, I assign the ALT key (first player second button in MAME) to one of the pad buttons.
When I play a game in the emu, if I push this button the emu pauses and need to push another time to run again.
How can I solve it ?
g3rg
  • Last login:December 22, 2003, 03:09:22 am
  • Marsupalami tastes great with cheese
Re:Problem with ePSXe pad configuration
« Reply #1 on: December 03, 2003, 08:24:51 pm »
I have no problem with this in my setup (Alt set as the square button on player1 controller). I am using ePSXe 1.6. Are you running it windowed or fullscreen? I can repeat your problem by running ePSXe SPU Core 1.5.2 in windowed mode, but in fullscreen there is no problem with Alt on my machine
MrPoPo
« Reply #2 on: December 04, 2003, 03:19:21 pm »
I have ePSXe 1.6 and run it at fullscreen.
I'm using Mamewah and launch a batch file from it for play the emu.
Can this be the problem?
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #3 on: December 05, 2003, 06:38:10 pm »
Alt keys are a bad idea for a emulators...key combinations can do nasty things. If you can assign something else, you should assign something else. Just my opinion...take it or leave it.  ;D
All Your Base Are Belong To Us!
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #4 on: December 05, 2003, 07:55:51 pm »
True, I assign 7,8,9,0 as P1 Button 1,2,3,4 on the JPAC custom (alt) settings to avoid all conflicts.  I configure mame and all other emulators accordingly and have no problems.
