Author Topic: 18mm T Molding?  (Read 3205 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
18mm T Molding?
« on: March 30, 2014, 01:15:08 pm »
If I'm using 18mm MDF (because 19mm isn't readily available in the UK from what I can tell), then which T-molding size should I use? 3/4"? Because that's 19mm. Does that extra mm make a bit of difference or should I go for something else? Can you get 18mm thick T molding??
eds1275
  • Last login:July 13, 2025, 01:10:24 pm
  • Rock and Roll!
Re: 18mm T Molding?
« Reply #1 on: March 30, 2014, 01:57:55 pm »
There are many ways to trim t-molding.
s_busby_uk
Re: 18mm T Molding?
« Reply #2 on: March 30, 2014, 03:40:45 pm »
Nice! What tool is that?
  • Last login:Today at 05:41:51 am
Re: 18mm T Molding?
« Reply #3 on: March 30, 2014, 04:20:31 pm »
Looks like a one-sided edge-band trimming tool similar to the two-sided one BobA discussed here.
« Last Edit: March 30, 2014, 04:23:41 pm by PL1 »
