Author Topic: Power button is not working  (Read 1288 times)
stepowell7
  • Last login:March 18, 2014, 08:54:26 pm
« on: March 18, 2014, 08:19:17 pm »
Hi guys,
first post, so hi :)
I bought a cabinet and for the most part its working.  However The button to power the computer on is not working.
I have traced the button to the component attached.  For some reason to power the computer on I have to press the tiny black button rather than the power button on the cabinet.  Any thoughts ?
image is here http://postimg.org/image/4fts4vad7/
  • Last login:May 30, 2026, 12:00:14 pm
Re: Power button is not working
« Reply #1 on: March 18, 2014, 08:22:51 pm »
Maybe a part on the big button that is supposed to push the black button is broken? Or maybe it is not aligned correctly.
404
« Reply #2 on: March 18, 2014, 08:38:56 pm »
the black wire in the front routed to the back seems like the issue. looks to me like someone soldered that wire in to set the power on the cab. trace those wires back to see if they are loose somewhere else.
  • Last login:Today at 12:36:30 pm
« Reply #3 on: March 18, 2014, 08:41:00 pm »
Welcome aboard, Stepowell7.
There are a number of threads about how to tap into the Dell front panel ribbon cable for an external power button.
Just use the search button up top and use "Dell ribbon cable".   :cheers:
stepowell7
« Reply #4 on: March 18, 2014, 08:54:56 pm »
wow, thank you for the fast replies.  I will check in the morning
