Author Topic: Going to try and keep a build log. *DONE*  (Read 6078 times)
menace
« on: March 18, 2014, 08:08:57 am »
Just going to record time and materials for build I'm just starting:
Day1:
Cabinet pickup: 2.5 hrs (there and back).  Also stopped at starburst on way through
cabinet cost: $125 (u2000 monitor and golden tee fore boards inside-will sell later)
Controls cost: $45 ipac, $25 new happs sticks, $26 new buttons
Day 2:
clean-up: 1 hr (removed wiring, control panel overlay, stupid iso transformer double bolted to bottom, back door, misc screws etc.
repaired monitor: 1.5 hours--new cap kit, trial and error on repairs finally got it rock solid.  Cap kit $10
Day 3: 40 minutes there and back picked up 26" Lcd tv. $75
« Last Edit: April 04, 2014, 08:00:19 pm by menace »
jdbailey1206
Re: Going to try and keep a build log.
« Reply #1 on: March 18, 2014, 08:45:27 am »
Pictures or it didnt happen.
thomas_surles
« Reply #2 on: March 18, 2014, 08:59:00 am »
menace
« Reply #3 on: March 18, 2014, 11:29:41 am »
LOL--fine==pictures are on the way...
Today:
1.25 hours rebuilt back so it has a better door and is now flat.  Also cut two handles in the top--this is all about making it easier to move in my mini van..  Also got it into the house now that the wood working is done.
1/2 hr:  assembled artwork from other sources and sent them to printer (prints-mart on ebay...99 cents /sq ft. for glossy adhesive vinyl)
« Last Edit: March 18, 2014, 11:32:04 am by menace »
thomas_surles
« Reply #4 on: March 18, 2014, 11:38:49 am »
Love the cab. Hope it turns ou alright.
menace
« Reply #5 on: March 18, 2014, 08:04:27 pm »
Today :  2 hours cutting control panel...had some design issues so waffled a bit.  Re-did artwork to match
$37.37 for sideart, marquee and control panel art
2 hours setting up pc and configuring Mala
SavannahLion
« Reply #6 on: March 18, 2014, 08:32:55 pm »
Holy smokes. If I kept a log here just on the hours and days I put into the control system alone I would probably exceed the forum limits. Good luck.
menace
« Reply #7 on: March 19, 2014, 07:35:37 am »
Thanks!  I think I will be just as surprised as everyone else as to how long it really takes me to get a basic machine together...
EMDB
  • Project RetroCade
« Reply #8 on: March 19, 2014, 01:17:09 pm »
Based on most build threads running for months / years we already knew  >:D  As it is a hobby for most of us which may cost time and money I don't mind my build is already running for more than a year...  :applaud: :cheers:
jennifer
« Reply #9 on: March 19, 2014, 04:36:34 pm »
   I have over a decade into a few of my projects.... Lets see, Day 1, needed to find like 6 guys to help me move a jukebox, That's 2 kegs and gas money... and over the years, A river of time, money (and a few trips to Iowa) looking for obsolete parts... I give up, hope that log thing works out for you. Nice build BTW, it will be fun to see it done.
menace
« Reply #10 on: March 19, 2014, 08:03:13 pm »
Spent about 3-4 hours all told today:  Wired up power supply for speakers and coin door lights and got monitor mounted via its VESA mounts (involved trip to home depot).  I think it might be a smidgen too high...Also picked up parts to make the relay power supply.
$20 bucks in Misc. hardware and screws
I used the scrap MDF cause it was the perfect width and the notch in it makes no difference..
Still debating on height--its perfect for me but might be high for shorter person..dunno yet..
menace
« Reply #11 on: March 20, 2014, 07:54:01 pm »
1/2 hr today--lowered display by 1.5" and I like it much better.
« Last Edit: March 20, 2014, 07:57:55 pm by menace »
menace
« Reply #12 on: March 22, 2014, 11:57:28 am »
1/2 - 45 minutes this morning making a relay switch power supply.  (plug the power into the wall, half the outlet is "always on" the other half gets switched on with the pc 12V supply)  Costs me $5 if I don't have the parts already (Which I did in the case)
menace
« Reply #13 on: March 23, 2014, 05:20:30 pm »
$58 for glossy paint, roller, new tray
1hr, picking up supplies, light sanding and filled in holes with putty.  I wasn't going to paint it originally but after seeing it in full light, it was pretty patchy looking..
Also drilled a new hole in the top for the new power button
menace
« Reply #14 on: March 25, 2014, 08:14:21 am »
Minor setback last night--was prepping the cabinet for paint and I kept getting loose flakes falling off.  I grabbed a scaper to see if I could get the loose stuff off...
1 hr later  :o
Every scrap of paint on both sides scraped off in large sheets--guess it's better it did it now rather than 6 months from now...
jennifer
« Reply #15 on: March 25, 2014, 10:31:11 am »
   ** Jennifer laughs quietly to herself... Your going to need a good sealer (over sanded primer)  before you paint that.
menace
« Reply #16 on: March 31, 2014, 07:30:47 am »
took about 2-3 hours (over the course of a few days) to sand and re-paint the cabinet.  Three coats of high gloss black with one sand in between (not going for an ond-like finish here  ;D)
$15 on 30 feet of T-molding
$5 on black poster board for the bezel area
1/2 hr cleaning the goo off the marquee plastic and glass
1/2 hr to re-wire PC speakers and get them attached
EMDB
  • Project RetroCade
« Reply #17 on: March 31, 2014, 07:42:55 am »
0 hr taking pictures to show my fellow forum members  >:D
menace
« Reply #18 on: March 31, 2014, 05:15:31 pm »
LOL ok mr. smartie-pants...
And here is mr. destructo wrecking stuff that I accidentally leave on the floor...
menace
« Reply #19 on: March 31, 2014, 05:20:21 pm »
As it sits right now...just need artwork and its done!
menace
« Reply #20 on: April 02, 2014, 08:25:31 am »
Time to date: 19.5 hrs
cost to date: $400 (paint price was reduced since I still have 3/4 of a can left)
Left do to--get artwork received and installed, wire control panel then minor tweaking.
menace
Re: Going to try and keep a build log. *DONE*
« Reply #21 on: April 04, 2014, 08:04:59 pm »
Had the day off and the weather was crappy so I decided to push through to the end
time spent today: 4-5 hrs assembling control panel, troubleshooting, installing the artwork, and of course taking pictures...
Adhesive vinyl overlay installed (yes I know its out of alignment--I made a measuring mistake when transferring the pattern GRRRRR
Installed.
Front shot:
Side shot:
A hearty Thank you to the byoacer's who share their wonderful artwork with the rest of us no-talent hacks  ;D
SavannahLion
« Reply #22 on: April 05, 2014, 05:15:54 pm »
Hmmm less than a month from start to finish. Takes me that long just have some of my parts shipped.
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #23 on: April 05, 2014, 09:41:20 pm »
Cool man. :) Sometimes I think doing a nice quick and clean project like this is better than spending months and tons of $$$ obsessing over getting everything a certain way.
I'm curious as to what you think about the quality of the printed vinyl...because that's pretty cheap. Full vinyl sides for an average size cab would be under $40 at that price.
menace
« Reply #24 on: April 06, 2014, 07:24:48 am »
I'm happy with the results although in fairness I don't have any other adhesive vinyl to compare it to.  Other suppliers may use thicker material but it does the job and the colors are good.  The only thing I don't like is that I usually work in RGB in photoshop but they print CMYK.  Its really hard to get a nice Royal blue in CMYK without it going all purple-y.  The finished product looks nice and is durable enough for a home use only control panel.  It wouldn't last long in an arcade setting though I don't think...
Regarding the the timing to put it together, I was able to get everything locally with the exception of the artwork.  If I had to ship everything I can see hitting some roadblocks where work couldn't proceed until I had X on hand...
I'm happy with it and can now remember why I don't normally bother with a trackball---I never use it.
nitz
« Reply #25 on: April 06, 2014, 10:37:53 pm »
Cool, thanks!
I'm sure the stuff from gameongrafix is awesome (never tried it myself), but man it's pricey if you want to do full on artwork - CP, bezel, and side art. This looks like it could be a good alternative, especially if your CP is covered with plexi.
