Author Topic: Another Centipede Cabinet - FINISHED!  (Read 18492 times)
delta88
  • Last login:March 26, 2026, 05:48:35 pm
  • This place is still here?
Re:Another Centipede Cabinet - FINISHED!
« Reply #40 on: January 29, 2004, 04:23:43 pm »
i got a set from a guy for 15bux to cover the 3 dvds.. that was at .72  came the same week and didnt tie up my other dls.. well worth it. heh i did end up dling 22gigs of counsle roms though ;)
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
« Reply #41 on: February 04, 2004, 07:09:08 pm »
I was wondering about your control panel, I really like the layout and it dosen't seem to take up too much space. What's the deminsions of the top board of your CP? By the way awesome cabinet!
TheJohn
  • Last login:March 09, 2005, 05:30:59 pm
    • My Centipede Cabinet
« Reply #42 on: February 04, 2004, 07:29:39 pm »
The control panel is 24" wide and 9" deep. Unfortunately I don't have a diagram available. This photo provides the best view of the control layout:
and here it is installed:
dmsuchy
« Reply #43 on: February 04, 2004, 07:47:51 pm »
Thanks buddy! Looks like the track ball is in the exact center, right? And besides your player 1 and 2 buttons what other functions do the other buttons do? Thanks, your cabinet is really helping me design my own.
TheJohn
« Reply #44 on: February 05, 2004, 09:39:43 pm »
You bet. The trackball is centered. The buttons adjacent to the Player Start are the coin insert buttons. The two buttons above the trackball are the left and right mouse buttons. I use the Player One Start as a shift button to access the MAME admin commands.
dmsuchy
« Reply #45 on: February 12, 2004, 01:08:54 pm »
How wide is your cabinet?
TheJohn
« Reply #46 on: February 12, 2004, 01:17:32 pm »
DM, the control panel is 24.00" wide. I used 0.75" MDF, so the total width is 25.50".
dmsuchy
« Reply #47 on: February 12, 2004, 01:29:51 pm »
Thanks man, I start this weekend! I should of asked earlier but whats the dept and height also? Thanks, sorry for being a PAIN.
TheJohn
« Reply #48 on: February 12, 2004, 02:16:58 pm »
I envy you, being able to start construction on a new cabinet! Fun and exciting times await you!
I used the Centipede dimensions provided by Jakobud on his website: http://www.jakobud.com
The only change I made was to extend the control panel out by a couple inches to pack in all of the controls and give my palms a place to rest.
If you can't plot the drawings, you may want to go get a roll of butcher paper like I did and lay it out on a table. Transfer the dimensions using a long ruler and a t-square. This will help get you familiar with every side and angle - it'll also allow you to plan for things such as a keyboard drawer and whether or not your monitor will fit. Plan, plan, plan!!
The other benefit of having your plans on paper to exact scale is that when you get your big boards of MDF, you can just lay the paper over the boards, poke holes through them to mark the corners, and then pretty much play connect the dots with a rotary saw and jig saw.
Chances are your lines won't be straight, so get a palm sander too - it'll smooth everything out and is pretty good at making curves as well.
« Last Edit: February 12, 2004, 02:23:37 pm by TheJohn »
menace
« Reply #49 on: February 12, 2004, 02:40:03 pm »
Terrific looking cabinet--its too bad ones like these don't show up on tv instead of the half-assed ones you always see--so how long till withdrawl kicks in and you build another?
Hoopstar
  • Last login:June 12, 2004, 11:35:59 am
    • Hoopstars Garage
« Reply #50 on: February 15, 2004, 04:28:56 am »
Awesome cabinet TJ...!!
Are you able to give us the actual measurements of the "wings" either side of the CP - pweeeease..
Hoops
dmsuchy
« Reply #51 on: February 17, 2004, 07:14:02 pm »
Once again I have to bug ya, did you have any trouble fitting your 22" NEC monitor into Jacobud"s Centipide measurements for your cabinet? I bought and just got my 21" NEC monitor from poweron, thanks by the way for that great tip, and I'm wondering how deep I have to design my cabinet. The rough measurements for the thing is like 20" by 20" and I was figuring making the cab 26" deep to handle it. I'd rather go with 24" if I can get away with it.
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #52 on: February 27, 2004, 08:02:19 am »
Hey John, your Centipede turned out unbelievable - love it to look at these pictures!  :D
Somehow I should've kept the 2,25" trackball, it's very good integrated in the controlpanel and doesn't look disturbing at it looks on most "all-controlls-there"-panels! :)
Okay, when I'd do so I'd loose the reason to swap my controlpanels, so I never noticed the clean look with the trackball. ;)
Perfect work!  :D
pcdoctor
  • Last login:July 21, 2014, 06:44:02 am
  • I'm a Girl Gamer!
« Reply #53 on: March 06, 2004, 04:22:40 am »
Love your cabinet if I haven't already told you so.
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« Reply #54 on: March 06, 2004, 07:32:10 pm »
Black and white. Classy.
%$#@!&* machine took my quarter!
