Author Topic: Can't turn up the contrast, bleeding colors  (Read 2026 times)
copados33
  • Last login:March 07, 2025, 08:23:35 pm
« on: March 01, 2014, 08:36:31 pm »
I was making some tests with an arcade chassis that I just bought, until I forgot to connect the ground cable that goes from the tube to the yoke board while I was swapping the chassis into one of the compatible tubes that I have laying around, needless to say that  the signal deflection IC got fried.
The IC model is "DBL 2009" manufactured by Daewoo, I could not find a replacement so searched for similar IC's and I found that the Hitachi HA11235 is compatible with the Daewoo.
I soldered the Hitachi IC into the chassis and while it works again I can't turn up the contrast, if I move the pots I only get bleeding/blown colors, could be that the HA11235 is not 100% compatible with the DBL2009? or is there another component of the chassis that got fried??
« Last Edit: March 05, 2014, 02:32:53 pm by copados33 »
ed12
Re: Busted Signal deflection IC
« Reply #1 on: March 01, 2014, 11:43:00 pm »
ya u wacked more then just that ic.
u are dang lucky u did not snap off the neck of the tube ?,
how u got away with that is beyound me?
chk the d/c going to the chip make sure it is bang on
12volts d/c i do believe
btw did u get a prety blue glow from the neck of the tube ?
ed
copados33
« Reply #2 on: March 02, 2014, 04:36:12 am »
The tube is still in one piece, no blue glow.
I haven't checked the volts on the IC.
copados33
Re: Can't turn up the contrast, bleeding colors
« Reply #3 on: March 05, 2014, 02:33:09 pm »
Anyone?
