Author Topic: vertical collapse hantarex?  (Read 1522 times)
« on: January 28, 2014, 09:32:40 pm »
So picked up this "Tekken 4" cab, lucky me its an MK3 cab, and Ive always wanted an excuse to convert my MKII back to an MKII (from a UMK3) so I started peeling stickers off and decided to take a break and play a little Tekken 4, welp, I guess I should have looked at the monitor better before buying cause theres some sort of collapse. Is there an obvious fix or do I need get a full on cap kit?  On a side note, Super Deformer Tekken looks hilarious.
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
Re: vertical collapse hantarex?
« Reply #1 on: January 28, 2014, 11:26:10 pm »
Of course caps are always a good idea to change and will fix a lot of these kinda things.
also check pin 14 of IC1, should be +20volts.
could be IC1 is bad
« Reply #2 on: January 29, 2014, 08:54:12 pm »
didnt have a chance to check the voltages yet, but I did take a closer look at the board after grantspain suggested I adjust this:
(or at least I hope that's the vertical linearity pot)
and then I noticed this:
What is it, and where do I get a new one. I KNEW I shouldnt have bought this machine! In addition to the toasted marshmallow, the board is chipped and the degauss wires are taped off.
Any advice?
mgb
  • North East, US
« Reply #3 on: January 29, 2014, 09:28:58 pm »
Eh, all things are repairable. As far as IC1 goes, the one time I had one with a bad IC1, it was completely collapsed.
