Author Topic: Geometry wars (PC) with analogs  (Read 2164 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: January 24, 2014, 11:50:57 pm »
Hey
I'm just wondering how I can use 2 analog joysticks (360's) for geometry wars for pc. I think the game only recognizes 1 game pad at a time, does each 360 act as a individual gamepad in windows?? I would like to remove my 2 8way joysticks and ipac for a complete analog setup in my geo wars cab. any ideas?? thanks in advance
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Fursphere
  • Last login:May 21, 2026, 12:33:23 pm
Re: Geometry wars (PC) with analogs
« Reply #1 on: January 25, 2014, 08:28:20 am »
It will work with keyboard inputs.
Get joy2key running for each stick, inputing keyboard inputs - set it up to match Geometry Wars default keyboard bindings.
Or you could probably use PPJoy to create a virtual joystick that merges both of your sticks into one.
MAME TIME
« Reply #2 on: January 25, 2014, 10:25:12 pm »
im just thinking if I use the keyboard outputs wouldn't I lose the functionality of analog?
Geometry Arcade
Neo Geo 360
MK2 standup
« Reply #3 on: January 25, 2014, 10:34:06 pm »
360s are individual so that's not a great solution for this game if it can't map the inputs but the KADE I used in the build for M had dual analogs and worked awesome in PC.  One as directional and other as POV hat on a gamepad.
http://forum.arcadecontrols.com/index.php/topic,135457.msg1399124.html#msg1399124
see also
http://forum.arcadecontrols.com/index.php/topic,134781.msg1390657.html#msg1390657
Scott just used two of the four available axes but does a great tutorial in that thread.
Finding the joys will be the trick, they can be stupid asspensive, or you can get some cheap-o PC flight sticks, hack them apart, add a bat top, and figure out how to get them to bottom mount to your CP and you'll be good to go.  I'd actually flip the base over, cut a hole through the plastic, run the rod stock into the housing and wire the pots backwards.  Could work.  Could crash and burn.  Either way should be a lot of fun!
I'm still kinda trying to figure out why you never went with one of the flight sticks that has a POV hat on the top, then you could play with one hand and drink beer/tea/whatever with the other.
MAME TIME
« Reply #4 on: January 26, 2014, 02:17:58 pm »
Hey Chuck thanks for the reply and info, i'd be willing to commission some one for this setup as im going through a house renovation and all my tools are buried in a storage locker. I think it would really complete this project. thanks again
Geometry Arcade
Neo Geo 360
MK2 standup
