Author Topic: FCEUltraX not keeping video settings (nes emulator for Xbox)  (Read 2472 times)
Fig
  • Last login:January 25, 2026, 09:13:12 pm
  • (-_-)
« on: December 27, 2013, 11:32:37 pm »
I'm at a lost here guys! I'm trying to get the best pic with the filters within the emulator settings but for some reason after I make changes to the video settings then go and play any game the default settings are applied. Is there a master config save somewhere? Do I need to delete the config save file and have FCEUltraX make another cause overwriting isn't working. My Xbox is soft modded the monster component cable so I can run the emulators in HD.
Thanks for your time
ark_ader
  • I glow in the dark.
Re: FCEUltraX not keeping video settings (nes emulator for Xbox)
« Reply #1 on: December 27, 2013, 11:56:14 pm »
Check to see if the files are read only in FTP.
Fig
  • (-_-)
« Reply #2 on: December 28, 2013, 12:11:12 am »
Thank you for the reply
Are you talking about the config.ini file?
ark_ader
« Reply #3 on: December 28, 2013, 03:13:21 am »
I would check every file in the directory.  I had this problem once with CoinOPS.  Hope it helps.  ;D
Fig
  • (-_-)
« Reply #4 on: December 30, 2013, 09:04:02 am »
Ark_ader,
I would like to thank you for you help with me on this but in the end I just deleted the game saves folder in my E drive and started all over. It worked and able to keep my video setting from switching to one game to another.
