Author Topic: Vector.ini and GroovyMAME  (Read 4153 times)
vindic8r
  • Last login:January 10, 2024, 12:36:59 pm
    • MOTUMAME: A Masters of the Universe Arcade Cabinet
« on: December 02, 2013, 02:20:27 pm »
I have a vector.ini that I use to tweak brightness and vector-specific settings. It seems that it's not being read by GroovyMAME 0.149.
I'll upload it later, but figured I'd ask to see if this is a known issue or perhaps just my mistake in the configuration.
Until I get my Asteroids cocktail restored and working, I need my fix! And the vector games just aren't as pretty as they could be with a bit of tweaking.
Running on a WG U2000 w/ an AVGA 3000, FWIW.
Thanks in advance.
krick
  • Gotta have blue hair.
Re: Vector.ini and GroovyMAME
« Reply #1 on: December 03, 2013, 01:38:51 am »
Try putting this as the first line of your vector.ini file and let me know if it works....
hlsl_enable 0
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
vindic8r
« Reply #2 on: December 04, 2013, 12:35:21 am »
Nope. Put it right at the top. No dice. See attached for full .ini.
krick
« Reply #3 on: December 04, 2013, 01:42:46 am »
OK, I just downloaded and unzipped stock mame 0.149
then downloaded GroovyMAME 0.149 and dropped the exe into the folder (renamed to mame.exe).
I created a clean ini file using...   mame - cc
Then I created a file named vector.ini (see attachment, remove .txt from the filename) with ONLY the following contents and it worked as expected on vector games...
# CORE SCREEN OPTIONS
contrast 2.0
gamma 2.0
# CORE VECTOR OPTIONS
beam 2.0
Hantarex Polo 15KHz
vindic8r
« Reply #4 on: December 09, 2013, 12:11:29 am »
Man, I feel like an idiot. I copied the vector.ini into the /ini folder and it worked like a charm. DUH!
Thanks for the help, krick. This one was entirely user error.  :dizzy:
krick
« Reply #5 on: December 09, 2013, 12:55:31 am »
Did you modify your inipath in mame.ini or something?
I put vector.ini right in the root with mame.ini and mame.exe and it works fine here.
In fact, I don't even have a folder called "ini".
Hantarex Polo 15KHz
